Sponsored by:
Sponsored by: CARiD
3.5 starts runs bad no fuel
Old Sep 25, 2006 | 09:16 AM
Biggs_02's Avatar
I got my 3.5 started. It ran fine the first day..then second day i put on my y-pipe and it ran like a piece fo s8it. I noticed that the front 3 banks are not firing...there is spark but nothing. I pull out the coil packs and it starts as though those coil packs are in. I check many times there is spark. There is a code p1336 i believe for the cps. I changed the cps to a working on...still the same thing. I'm using the 3.5 oilpan with the 3.5 cps wired into the 3.0 harness. I took off the y-pipe and then noticed that there was no smoke at all coming from the front banks, only cold air. The air didn't have a single hint of fuel in it at all. My fuel is set at around 52-55 psi. any help would be greatly appreciated :-(
Old Sep 26, 2006 | 06:46 AM
tavarish's Avatar
fwd gone rwd cr00
double check the wiring for the cps, and make sure the grounds are good for the injectors. I know grounds are a major issue on these cars.
Old Sep 26, 2006 | 07:36 AM
Biggs_02's Avatar
i'm gonna double check on the injectors grounds and the harness. I like double and quadrople checked the cps. I just did a compression test last night on the front bank and they were all getting 180 didn't get a chance to do the rear because i did it at 1am in the morning. Need to get my hand on a noid light so i can check the injectors.
Old Sep 26, 2006 | 11:25 AM
Biggs_02's Avatar
so i took out the intake and took a look at teh injectors and 2 of them were wired wrong. Got that fixed. I'm getting fuel in all the cylinders now. The front are firing. I confirm that by taking out all the coil packs for the back and turning on the car and it works. Now it just runs like *** video soon
Old Sep 26, 2006 | 11:30 AM
Nismo3112's Avatar
Custom User Title
Wait, so you got the fuel issue fixed, but now it runs like crap?
Old Sep 26, 2006 | 11:47 AM
Biggs_02's Avatar
dude it was getting 180 on the front bank. Now i'm waiting for the guy to bring the compression tester again so i cna test the rear. i doubt it's gonna be compression, but we'll see. i'm uploading the video now. mind you...this is with only headers and no y-pipe
Old Sep 26, 2006 | 11:48 AM
Biggs_02's Avatar
http://www.youtube.com/watch?v=Besu0Nu_XcQ
Old Sep 26, 2006 | 05:19 PM
Biggs_02's Avatar
i did a compression test today, i got 180 all around. so it's all good. But it still runs like ***....
Old Sep 26, 2006 | 05:55 PM
Biggs_02's Avatar
i'm getting a code p1320 right now. ignition problem. could be the coils but i just put in 6 different coils....
Old Sep 26, 2006 | 06:12 PM
scrhale's Avatar
Can you install all the exhaust so we can hear the true sound instead of extremely wierd sounds. When you say headers, do you also mean y-pipe (normally included with y-pipe ... duh) ... if no then my unborn sister could say that your O2's aren't working. Since you said the only code you are getting is ignition related then I am guessing it is safe to assume that you removed the cat and all back. Try installing those and then taking a sound clip. Perhaps the different/filtered sound will help us pin-point the problem
Old Sep 26, 2006 | 06:15 PM
Biggs_02's Avatar
i installed the y-pipe today still sounds like a piece of ****...does sound better. and i stated.....only headers no y-pipe
Old Sep 26, 2006 | 07:10 PM
scrhale's Avatar
Well then how do you have O2 sensors installed without a y-pipe? I mean now that you installed the Y-Pipe it isn't the case. I recommend finishing the exhaust. It really isn't hard to remove if you have to take it out again.
Old Sep 26, 2006 | 07:11 PM
Biggs_02's Avatar
http://youtube.com/watch?v=AGB4XuDLQT0
engine running with "knock" noise
http://www.youtube.com/watch?v=2h_lZAQ22kk
engine at idle
Old Sep 26, 2006 | 07:13 PM
Biggs_02's Avatar
I neve said i installed the 02 sensor...it ran like this even when i had the y-pipe installed and i took it off when i made the video.
Got code p0300 multicylinder misfire
would anyone say that this is due to timing being off....?
Old Sep 26, 2006 | 07:36 PM
scrhale's Avatar
I am just saying that having the O2s would help with how rough it is. Bad O2/absense of do not create misfire, but it also just eliminates another possibility of chain reactions.
Old Sep 26, 2006 | 09:44 PM
tavarish's Avatar
fwd gone rwd cr00
get a new harness, man. That looks like a clusterf'uck.
Old Sep 27, 2006 | 05:28 AM
scrhale's Avatar
Is your timing all lined up? Remember that long thread about the timing case that jumped like 2 teeth or something like that and the car was running like royal *&^%
Old Sep 27, 2006 | 07:42 AM
Biggs_02's Avatar
so today i woke up went outside fire up the car. Of course it ran the same. Then i went and unplug the cps from the timing case and it ran the same. Does this tell me something is screwed up inside the timing case...maybe wrong timing something jumpped a tooth or something?
Old Sep 27, 2006 | 08:19 AM
Biggs_02's Avatar
i'm gonna say that the timing chain jumped a tooth or two. Is there anyway to ensure that the timing chain will not jump a tooth or two? seems like lots of people are having this problem.
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
vanebecker
Aug 19, 2015 09:45 AM
Balkins
Aug 12, 2015 06:39 AM
