Sponsored by:
Sponsored by: CARiD
Engine harness removal question...pretty urgent.
Old Oct 12, 2006 | 01:07 PM
tavarish's Avatar
fwd gone rwd cr00
hey, im having trouble fitting the engine harness connector (ecu and tcm connector) through the grommet in the firewall. Should i just pull in everything from the engine to the inside? I need to remove this harness from this car, and install it into another car. It's pretty urgent, as I need to do this asap. I dont wanna dremel the hole in the firewall for fear of a wire stripping and grounding itself, but I need any tips that you guys might have to remove the engine harness completely. All the clips are off, and the engine harness is loose, it's just stuck on the hole in the firewall.
Any help is greatly appreciated.
Thanks,
-Freddy
Old Oct 12, 2006 | 01:36 PM
RA030726's Avatar
I'm nutty for Nissans
it should pull out through the hole. I had no issue pulling the ecu connector out on 2 other cars i worked on. Youll have to bend the wires pretty hard.
Old Oct 12, 2006 | 02:02 PM
JClaw's Avatar
Pull the plugs one at a time, and the big ECU plug last.
Old Oct 12, 2006 | 05:11 PM
tavarish's Avatar
fwd gone rwd cr00
i'll try that. i guess i have to feed more into the car to make room for the other connectors to fit through the hole.
Old Oct 12, 2006 | 05:40 PM
JClaw's Avatar
Maxima is the worst car ever to pull a harness. You basically need to be 4 foot 9 inches 88 pounds to fit under the dash and actual see the fawking hole. Damn japs.
I bought a harness recently, and the guy at the junkyard smashed the hell out of the dash and whole heater assembly just to pull the harness. He was really pissed.
It was pretty funny to watch, actually. But I'm a *****.
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
JoshG
Sep 5, 2015 10:10 PM
