VQ30 Pathfinder Manifold install?
On my race car I am running a VQ30 bolted to a pathfinder bellhousing and mated up to a Jericho four speed. It bolts right up but I run a pathfinder starter and use the starter ring gear from the pathfinder. I am not sure how the stock oil pan would mate up since mine are highly modified for ground clearance
Scott
Scott
Originally Posted by d00df00d
liqidvenom, I think you two are speaking different languages. All he's saying is that boost won't fix that IM's deficiencies, per se. That's true. Now, correct me if I'm wrong, but it sounds like what you meant to say is that boost will make up for the deficiencies. That's true too, and it's not incompatible with what he's saying.
You're also saying that with FI, this manifold could give benefits that outweigh its disadvantages, so you'd like to see what it can do. What nismology is saying is that it probably won't be worth doing. That's really just an exchange of ideas, since as you both know the argument is purely academic at this point.
See? No need to get panties twisted, guys...
Originally Posted by Hoooper
ok...so are you saying neither would work? transverse is transverse, i dont see why they would change the block design and i KNOW that the murano engine is transverse
like doodfood said pathfinder is longitudinal meaning motor mounts are in completely different spots
Originally Posted by Zack342
i cant say for sure. The only that is apparent is the lower VQ30 IM looks the same port pattern.
Originally Posted by Weimar Ben
It is the same port pattern as the vq30. This is why some people use PF heads on a 3.5 swap so that they can use the 00vi.
I had a set...too bad i tossed them
MaxLife17
Jun 27, 2019 01:37 PM
carid
Sep 9, 2015 05:06 AM
lowpost99
Sep 8, 2015 05:06 AM
