Sponsored by:
Sponsored by: CARiD
Mfa60
Old Aug 27, 2009 | 12:25 PM
  #81
Kevlo911's Avatar
Kevlo for President
You would have to make sure the bolt pattern is the same and it will likely be engine dependent.
btw I too am on m6c
Old Aug 27, 2009 | 12:38 PM
  #82
Nealio's Avatar
Thanks Kevlo, I sent you a PM, but looking again, your last post was in January of 2008, guess I should've looked before sending you a message.
Old Aug 28, 2009 | 01:44 AM
  #83
Nealio's Avatar
So here's a question while I'm still waiting on the first, are all the 5-speed transmissions F50A's? Or are there some 5-speed MFA60s as well? If so, when did they switch over to the MFA60?
Old Aug 28, 2009 | 07:31 AM
  #84
SR20DEN's Avatar
VQ Wizard
All of the FWD cable shift manual transmissions used in the 2002+ Altima, Sentra and Maxima were called "MFA60" by the manufacturer. http://www.aichikikai.co.jp/english/index.html
Nissan has their own names for them:
RS6F51A
RS6F51H
RS5F51A
etc.
Perhaps Mazda and Hyundai also have their own naming scheme.
Old Aug 28, 2009 | 08:47 AM
  #85
Nealio's Avatar
RS6F51A
RS6F51H
RS5F51A
etc.
I know that Ford/Mazda call the Transmission the A65M-R. I can't really seem to find my information on the Hyundai Transmission though.
Do the clutch housings between the 5 and 6 speed O2+ Maximas interchage?
Old Aug 28, 2009 | 06:46 PM
  #86
SR20DEN's Avatar
VQ Wizard
Actually, there is no 5spd manual Maxima after 2001. But AFAIK, the anwser to your question is yes. Concerning the Altimas and Sentras, the clutches should be interchangeable.
Old Oct 8, 2009 | 02:08 PM
  #87
dzignr_tastz's Avatar
Hey SR20DEN! Check your visitor messages (as I guess PM doesn't work over here)...
dzignr_tastz = NewTiburon.com
Old Oct 8, 2009 | 05:37 PM
  #88
Nealoc187's Avatar
SLOW
They work, you might need more than 15 posts to be able to send them though.
BTW weird, I was just reading your thread on the tiburon site like a week ago.
Old Nov 7, 2009 | 08:22 AM
  #89
Yeah - that could be it. Don't want to troll just to send a message, though... LOL!!
And that's ironic. I've been trying to find someone locally for quite a while now who could mod the pinion shaft for me (thus, why I was trying to reach SR20DEN, as it's really holding up my rebuild), but I think I've finally found a reliable lead on a guy. In fact, I just called Dave Burnette to check on availability and try to get the parts in hand.
On a total side note... are you affiliated with DeatschWerks, or just a fan?
Old Nov 8, 2009 | 02:43 PM
  #90
Nealoc187's Avatar
SLOW
One of my best buddies is the co-owner of deatschwerks.
What did you need done to the pinion? I did race transmissions for 3.5 years so I'm curious.
Old Nov 22, 2009 | 09:48 PM
  #91
Oswald's Avatar
The splines may be different but I would assume they are the same if the transmission is from the same manufacturer. Also I know the bell housing would be different but is it possible to change the actual transmission for the Sentra 6spd unit? This would let you retain your present clutch and flywheel and just change the transmission.
Old Jul 20, 2012 | 08:32 PM
  #92
seb_versa's Avatar
Question
Hello,
Sorry to bring back this tread
But woulike know if RS6F52H will fit on MR20DE engine found In Sentra 2.0l 2007 +
If not could SR20DEN or some else could help me to found lower 6 gear for the tranmission RS6F94R
I found this tranmission it avaible on those car but could find the gear ration or any gear part number
Tiida/Tiida Latio/Versa • (HR15DE, HR16DE) • (MR18DE) • (RS6F94R)
Note • (HR15DE, HR16DE) • (RS6F94R)
Wingroad • (HR15DE) • (MR18DE)
Bluebird Sylphy • (HR15DE, HR16DE) • (MR20DE)
AD/AD Expert • (HR15DE) • (MR18DE)
Lafesta • (MR20DE)
Serena • (MR20DE)
Sentra • (MR20DE) • (RS6F94R)
Livina Geniss • (HR15DE) • (MR18DE) • (RS6F94R)
Qashqai/Dualis • (MR20DE) • (M9R) • (RS6F94R)
X-TRAIL • (MR20DE) • (M9R) • (RS6F94R)
thank for you help
Seb
300d50
Mar 23, 2015 03:33 PM
