Sponsored by:
Sponsored by: CARiD
Bubbling Coolent?
Old Dec 6, 2006 | 06:06 PM
Wolf-Strong's Avatar
Bubbling Coolent?
This is not Maxima related, rather my brother's 96 Camry (4cyl).
My question is simple...what would cause coolent to bubble out the overflow tank if it is a 50/50 mix in California weather with the thermostat just being replaced. My thoughts was that a dirty coolent passage in the radiator/engine might be causing this. Any input?
Old Dec 6, 2006 | 08:12 PM
NmexMAX's Avatar
dot dot dot ...
What's coolent?
Is it bubbling out of the tank, or is it just bubbling in the tank? If it's the latter, then you should be fine, or your friend with the 4cyl Camry should be ok.
This thread doesn't belong anywhere near this forum....
Old Dec 6, 2006 | 08:18 PM
Originally Posted by NmexMAX
What's coolent?
Sorry it is just no one seems to have an answer to this.
Yes, the coolant* is bubbling out of the tank...almost as if it was just normal water and it was overheating. That is not the case though!
I am trying to do everything I can to help my brother out here...I do not want to see him spend $1000+ on something I know is very simple! I can not seem to pinpoint it!
I honestly think draining the coolent and CLEANING the engine/rediator would solve the problem, but I want to make sure I am right before anything else happens. Please help me...anyone. This means a great deal to me and the people on the camry forums seem to be brain dead or something.
Old Dec 7, 2006 | 06:50 AM
boostlogic's Avatar
4th gen
Why don't you get the air out first...if it didn't do this before you replaced the stat, then either the stat is faulty or you have an air pocket. Take the caps off the radiator, overflow, and any other entry to the coolant system and let the car idle for 15 mins or so. When it stops bubbling all the air is out, unless its bubbling because its f'ing boiling...then you might shut that little yoda off...
While were on topic I was thinking of dropping the 3L Camry motor into my 4th , anyone done this?
Old Dec 7, 2006 | 02:26 PM
nismology's Avatar
Blown head gasket is a possibility. Pull the spark plugs. If they are covered in green gunk, the HG's need to be replaced.
Miket2006
Mar 1, 2021 03:55 AM
rbuswell
Nov 17, 2016 04:54 AM
JoeWhit
Sep 20, 2015 08:01 PM
Balkins
Aug 12, 2015 06:39 AM
sunnyb32
Jun 29, 2001 08:44 AM
