Sponsored by:
Sponsored by: CARiD
Reved Up Vq35 Question
Old Jan 8, 2007 | 09:48 AM
Zack342's Avatar
Does anyone know the differences between the reved up VQ 35 and the regular VQ35 in the G35/Z's?
Also what is the fuel cut on the reved up motor. Not the redline but the actual fuel cut.
Old Jan 8, 2007 | 10:02 AM
jcy98maxse's Avatar
Turbo is too much fun!
Cams for sure are different, I'm quite certain about the fuel cut.
Old Jan 8, 2007 | 10:21 AM
NmexMAX's Avatar
dot dot dot ...
Cams, LIM, VTC's, according to Nissan it (max engine speed) is 7000. I've heard of 7100
http://www.nissannews.com/
Old Jan 8, 2007 | 10:23 AM
nismology's Avatar
Better oil pump as well.
Old Jan 8, 2007 | 01:20 PM
Zack342's Avatar
See no none can answer it. My 2006 G35 coupe has this engine and the "redline" is 7000rpm but it winds all the way up to 7600rpm and i couldn't feel an ignition cut. I posted this question on G35driver but no one responded.
Also are the heads different?
Old Jan 8, 2007 | 01:27 PM
nismology's Avatar
^^ All that proves is that the tachometer is inaccurate.
Old Jan 8, 2007 | 01:43 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
nismology is correct. my g35 auto will shift at redline 6600 in drive but manumatic mode it has not hit the rev limiter at 7100-7200. Just like my maxima, the tach is way off in upper rpms.
Old Jan 8, 2007 | 01:44 PM
Puppetmaster's Avatar
And that wouldn't be anything new either.
My tach shows fuel cut to be 6800-6900 while my VAFC-II shows fuel cut to be more like 6650. I think several other 5.5 Gens have seen the same thing as well.
Old Jan 8, 2007 | 01:49 PM
NmexMAX's Avatar
dot dot dot ...
Get a datalogger and get REAL data. My car's stock rev limit was verified @ 6650, tach indicated ~ 6800 RPM.
Now, rev limit is @ 7100, and the tach indicates ~ 7500. Seems like the tach begins to become more and more 'off' as revs increase. Cruising around town, anything under 3500 is dead on (data with respect to tach reading) anything after that and it becomes more and more inaccurate.
Old Jan 8, 2007 | 02:04 PM
krismax's Avatar
Father of the 00 VI
my tach has always been dead on when i hit indicated 7900 rpm my fuel would cut and my cut is suppose to be 8k
Old Jan 8, 2007 | 02:11 PM
nismology's Avatar
You have an A32 tachometer. This doesn't necessarily apply to you.
Old Jan 8, 2007 | 02:46 PM
NmexMAX's Avatar
dot dot dot ...
My A32 tach is much more accurate that the one in my A33B.
Old Jan 8, 2007 | 04:51 PM
Zack342's Avatar
i have have my buddy hook up the consult III next time i am in the dealership. I wish someone knew the published valve for sure since i am not keen on reving it up there i just would like to know.
Does anyone knwo if the heads are different?
Old Jan 8, 2007 | 05:17 PM
nismology's Avatar
The heads will have a different part number simply because of the different (stronger) valve springs and retainers. Everything else in the head is exactly the same.
Old Jan 8, 2007 | 05:33 PM
Zack342's Avatar
The reason i ask is i have a set of VQ35DE heads from a FX35 I wanted to get ported but I wasn't sure if they are the same. I know my reved up motor has VTC on exhaust and Intake cams. I know the FX engine did not.
JClaw's Avatar
Dont they have stronger rod bolts too (like the ARP ones)?
Old Jan 8, 2007 | 05:38 PM
nismology's Avatar
Originally Posted by JClaw
Dont they have stronger rod bolts (like the ARP ones) too?
Yes they do, but their likely the nismo bolts which wouldn't be as strong as the ARP bolts IMO. This is no matter though because we were talking about the heads in particular, not general differences.
Old Jan 8, 2007 | 07:03 PM
Zack342's Avatar
i am planning on dynoing once i have 5k on the clock so we will see how this does compared to the non reved up vq35 de
i have my brothers old 03 VQ35DE G35 dynos
Old Jan 11, 2007 | 09:12 AM
NmexMAX's Avatar
dot dot dot ...
http://www2.freshalloy.com/showpost....7&postcount=36
From 2005+, the 6MT has used a different engine than the 5AT. Both are VQ35DE's, but the 6MT (or rev-up) has a different design on the upper / lower intake plenum, camshafts, etc. Rev-up is more of an internal term to Nissan. Its not an official designation, but for the aftermarket world it helps to differentiate the two engines.
Here's the list of parts that they changed for the 300 hp 6MT engine vs the 287 5AT.
LH Exhaust Camshaft
LH Intake Camshaft
RH Exhaust Camshaft
RH Intake Camshaft
Connecting Rod
Connecting Rod Bolt
Crankshaft: Uses the same connecting rod bearings and main bearings / thrust washers as other crank.
Crankshaft Assembly
Cylinder Head Assembly - LH
Cylinder Head Assembly - RH
Pistons - STD 1, 2, 3, & OS0.20
Pistion Ring Set STD
Piston Ring Set OS 0.20
Valve Spring
Track Valve Spring Retainer
VTC Pulley & Cover Kit LH (does not include gasket or bolts)
VTC Pulley & Cover Kit RH (does not include gasket or bolts)
VTC Cover Gasket LH
VTC Cover Gasket RH
VTC Cover Bolt
This allows it the 7000 rpm redline vs 6600 rpm and improved top end power.
Old Jan 11, 2007 | 10:08 AM
nismology's Avatar
That list sounds like preliminary speculation based on a simple part number search, not something that nissan said or individual research.
Connecting rod - Highly doubt it. Since the connecting rod is sold as an assembly complete with the rod bolts it would have a different part number because the rod bolts are different.
Crankshaft - Highly doubt it. The OEM crank is good for 10k revs when balanced. I doubt they'd change it. The part number might have changed due to it being made in a different country. Much like some A34 engine parts having different part numbers but being exactly the same. For instance, the A34 intake manifold has a different part number and is cheaper than the A33B's because it was made stateside.
Cylinder head - This hasn't been confirmed. The cylinder head will have a different part number than the regular VQ's simply due to different valve springs and retainers. Remember it is sold as an assembly.
Piston - Highly doubt it again. The compression ratio didn't change so why would the pistons change? The piston ring set has a different part number (and also inferior IMO since ALOT more revups are burning oil, relatively speaking) so maybe the pistons are sold as an assembly complete with rings and the whole assembly has a diffferent part number.
Since he's asking about the heads, we'd have to see if the actual casting is different with the revup. I'm looking for pictures as we speak.
Old Jan 11, 2007 | 12:14 PM
NmexMAX's Avatar
dot dot dot ...
I agree with ^^ just googling and came across it.
Also has an EGR port that the A33B does not have.
Old Jan 11, 2007 | 12:20 PM
nismology's Avatar
Oh yea. I forgot about that.
That's why the part number is different. It's cheaper though because it's made in the US.
mclasser
22
Nov 12, 2020 01:58 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
