Sponsored by:
Sponsored by: CARiD
5.0 Gen Valve Body vs 4th gen valve body?
Old Feb 15, 2007 | 02:40 PM
TDotMax's Avatar
Are they the same? I have someone interested in my Maxxtunning VB and he owns a 4th gen. Can we do the swap, or are the VB's different? When I did the install I used a 4th gen write up and it was the exact same in regards to install directions.
Old Feb 15, 2007 | 03:04 PM
Kevlo911's Avatar
Kevlo for President
90% sure they are the same.
Old Feb 16, 2007 | 07:22 AM
renman's Avatar
Kevin, I was just about to post here as well. I'm going to PM Jay and give Vic Simone a ring this weekend, and find out. I'm pretty sure its the same VB as well, since our engines are almost identical with the exception of the IM.
I'll get back to you shortly on TMEC, within a week. How's that sound?
Old Feb 16, 2007 | 08:17 AM
TDotMax's Avatar
Sounds good, was trying to get the info for yah
Old Feb 18, 2007 | 01:39 PM
MDeezy's Avatar
I'd imagine they are the same. Tranny's are pretty much the same from 95-01.
Old Feb 18, 2007 | 06:31 PM
pmohr's Avatar
No more Maximas...
When I got an '01 trans from Dixit a while back (he had already sold the VB so I put my own in) the harness connector for the solenoids was different. It disconnected inside the case as well as the usual connector right outside the case. I had to remove that harness and install the A32 solenoid harness. Check the pinout and connector type between A32 and A33, beyond that they should be the same.
Old Apr 28, 2007 | 12:41 AM
elemax's Avatar
The valve bodies are different due to the differences in shift solenoid packs. For 2000-2001, one of the ports in the valve body for the solenoids is smaller in diameter (shift solenoid A) than the 4th gen and the shift solenoids operate within slightly different resistance perimeters with the TCM. This means you can swap valve bodies, but the solenoids have to stay with their corresponding valve body, which means the solenoids have to stay with their corresponding TCM due to different solenoid resistance values between 4th and 5th gens.
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
lux97Max
19
Aug 27, 2015 07:48 PM
criminalslang810
Aug 9, 2015 03:35 PM
