please help me find the rod weight
i cannot find the vq 35 rod weight anywhere ,and ive never been known for being a good net searcher .
but iam up to something and i really need the weight of the vq35de rod
and if noone knows then maybe i can buy or borrow a rod off one of my fellow orgians. because i happen to have a scale that measures in grams that will be here in a day or two. and with that i can find the weight .
thanks
thanks
ok i just weighed the dek rod with bearing shims and rod bolts and nuts 582 grams. i didnt know the 3.0 and 3.5 weights were so close.
nissan says the 3.5 rod bolts are much lighter than the 3.0 bolt and nut design i just weighed the dek 3.0 rod bolt and nut at 30 grams (24G for the bolt and 6 G for the nut)
what iam getting at is the carrillo A beam rods are in the 490 G range with ARP rod bolts .
iam wondering what a 600 gram reduction would do for the power curve? and high rev worrys would be a thing of the past. as far as rod concerns go.
Either way, you'd be hard pressed to feel the difference between one rod and the next for all practical purposes. It might help response slightly in the lower gears, but i doubt it'd show up on a dyno or at the track.
Originally Posted by nismology
600 gram? Where's this number coming from?
That's a fairly large chunk of reciprocating weight in the engine. that's worse than rotating weight.. you don't just have to spin it up once like the flywheel. you have to change the direction of these things moving many (up to 250) times per second. If removing 1lb from the flywheel is noticeable, which it is, this will be much more so.
You'd be hard-pressed NOT to see a difference in swapping rods.
The theory is sound, there's no denying that. UDP's make a difference in theory too. But i'm afraid that's all it is.
On the other hand, i didn't discredit lighter rods completely either.
I'd love to be directed to a link or magazine article where there was a HP increase recorded or 1/4 mile times dropped with lighter rods alone.
6spd4dsc
Mar 4, 2016 05:19 PM
pears
Sep 18, 2015 05:25 AM
ef9
Sep 10, 2015 10:35 PM
MikesChevelle
Sep 7, 2015 09:11 AM
