Sponsored by:
Sponsored by: CARiD
5th gen clutch on EU'd 3.5: Almost a year later
Old Feb 20, 2007 | 04:34 PM
GoalieKeg's Avatar
I've had the 5th gen clutch running on the 3.5 for a bit now, and I promised you guys a long time ago that I'd give my feedback on this clutch. I didn't think it would last more than 2 months with the 3.5 torque, but boy was I wrong. I used all OEM parts, clutch disc, pressure plate, and 4th gen TOB on stock new flywheel. This clutch is incredible for an OEM clutch. For those debating (N/A tuned 3.5 swap) on whether to get a Stage 1 clutch for a 3.5 swap or go with a 5th gen clutch, I highly reccomend getting the 5th gen. I've put over 10k miles on the 3.5 swap now. This clutch outlasted a 4th gen tranny in good running order used with my 3.5 swap.
I know a few of you guys have questioned whether or not this clutch can handle the 3.5 torque. I took a risk and found out that it has some potential.
I also noticed that the stock SR20DET PP is extremely similar to the 5th gen PP. Any of those with SR20 experience besides me want to chime in?
Old Feb 20, 2007 | 08:07 PM
scrhale's Avatar
You mean 2000 clutch? WOW ... I am impressed it held up.
Old Feb 20, 2007 | 08:39 PM
dfownz's Avatar
They definetly have *****.
Old Feb 21, 2007 | 01:17 AM
krismax's Avatar
Father of the 00 VI
i still have the same ACT clutch ive had in my car since my swap 2 1/2 years ago.
do you think the 5th gen clutch would take high rpm clutch dumps?
Old Feb 21, 2007 | 05:06 AM
Stabone's Avatar
I'm untuned(I'll be using SAFCII soon)and I'm using the same setup as well. I have had 4k trouble free miles which 3/4 of'em are city. So far nothing funny, no burning clutch smell after dumping, nothing to make me nervous.
Overall wayyy better driveability than the Spec stage 2 i had before.
Old Feb 21, 2007 | 07:03 AM
scrhale's Avatar
Heh ... either my mechanic screwed me or I got a bad OEM 2K clutch. I am getting more chatter than a street construction worker with a jackhammer when I am starting in first.
Old Feb 21, 2007 | 07:20 AM
maximariceboi's Avatar
looks like i ll be reusing my clutch now =]
Old Feb 21, 2007 | 07:39 AM
Stabone's Avatar
Are you sure its not the key value clutch? My first go around I thought I had a 5th gen when it turned out to be a key value and I had similar problems including slipping. THEN someone posted pictures of what to look for on the disc and what do ya know.... key value junk.
Old Feb 21, 2007 | 08:37 AM
GodFather's Avatar
Made in Taiwan
There's 2 types of 5th gen clutch, the earlier versions made for production before Nov, 2000 are similar to stock 4th gen clutch. But it's got 200lbs more clamp force than 4th gen.
The second type is the "AE" clutch, made for cars production after Nov, 2000. The ending part numbers for both AE PP and CD are xxxxx-2Y920, IIRC. The AE clutch has 135lbs more clamp force than the original 5th gen clutch, and it's assembly is a little beefier and friction surface is larger than the original 5th gen. Additionally, this AE clutch is made by Exedy, I'm doubting it's a stage 1 that Nissan decides to use as an OEM part for their 2001 Maxima's.
Fitment: You can mix and match any of the 4th gen clutch parts to the original 5th gen assembly, but you cannot mix the AE clutch with any of the 4th gen or regular 5th gen clutch assembly because the friction ring of the AE is larger, thus making it impossible for a 4th or 5th gen CD to fit in. This fitment issue was addressed in a thread before, but I got it all figured out because at one point, I had all 3 clutches in front of me.
-Peter-
Old Feb 21, 2007 | 08:51 AM
nismology's Avatar
Handling WOT sprints on the street is one thing, but hard launches on slicks at the track is another. Curious to see how it'd handle the latter...
Edit: I didn't even think it'd do the first one, so this is good and surprising news.
Old Feb 21, 2007 | 11:27 AM
scrhale's Avatar
It is definitely not key value ... I purchased the products myself and gave them to the mechanic ... I wanted OEM 5th gen parts in my car.
Old Feb 21, 2007 | 04:39 PM
GoalieKeg's Avatar
EDIT: I would say no to either (depends on how much you race). I started the major damage on my tranny at the track with a 4500 clutch dump, I heard the gears skip a tooth. A few weeks later, first gear went completely.
WOT into 2nd gear on the street grabs great.
Old Feb 23, 2007 | 04:32 AM
d00df00d's Avatar
Old enuf to pick his own gears
Someone here once posted saying that the S15 Silvia uses the same PP as the 5th gen Maxima. He probably meant the post-11/00 PP that you mentioned... Is that the one you're asking about?
Old Feb 23, 2007 | 09:02 PM
GoalieKeg's Avatar
Yes, it is possible that it is that one.
Old Jun 7, 2013 | 10:50 AM
95maxrider's Avatar
Lightly modded
I know, I know, this is a very old thread. I'm just curious if the 5th gen clutch kept holding the 3.5 power or if it eventually started to slip.
I'm getting ready to put a 3.5 in my car that comes with a used/abused ACT clutch and stock flywheel, but I also have the option to reuse the 5th gen clutch/flywheel I paid $900 for last year with like 5,000 easy miles on them. I don't drag race or do clutch dumps, but I do auto-x on Hoosiers. Right now I'm leaning towards keeping the 5th gen clutch, but if more people chime in here with other reviews, I might change my mind.
Old Jun 17, 2013 | 07:46 AM
95maxrider's Avatar
Lightly modded
Anyone have any thoughts on this?
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
maxima-junky
Aug 13, 2015 09:59 AM
