Sponsored by:
Sponsored by: CARiD
6speed bell housing
Old Mar 9, 2007 | 03:46 PM
95turbo gxe's Avatar
6speed bell housing
Does any one know how to get the bell housing off of a 6speed tranny. I got all the bolts out and started prying the case away from the housing but it still seems to be hooked some how! Iv got it almost 1" apart all the way around but what could make it not want to come on apart?
Old Mar 9, 2007 | 03:48 PM
Kevlo911's Avatar
Kevlo for President
You check the FSM?
Old Mar 9, 2007 | 03:52 PM
Originally Posted by Kevlo911
You check the FSM?
No sorry dont have one any more my dog rip it all to hell yesterday!
Old Mar 9, 2007 | 04:04 PM
Kevlo911's Avatar
Kevlo for President
www.phatg20.net
Old Mar 9, 2007 | 04:25 PM
Yeah every time i try to use one they never work!
Old Mar 9, 2007 | 04:59 PM
eng92's Avatar
You have to spread the mainshaft retaining ring before you can separate the transmission halves.
I presume you are swapping an A33B/A34 clutch housing onto a Spec-V tranny. You do realize that you have to recheck all clearances and re-shim as required.
I looked at going that route, but an A34 tranny was only $100 more with less miles on it.
Old Mar 9, 2007 | 05:18 PM
Ok im taking it to a tranny shop to get them to do it. If I take them a full spec tranny will they have everything they need to do it! Also can they use the shims from the spec becasue I only have the maxima bell housing nothing else
Old Mar 9, 2007 | 05:31 PM
eng92's Avatar
That is something nobody can tell you. They have to measure all the clearances and if they are not within spec, then different shims must be ordered and installed.
Is your maxima clutch housing new? If so, it would have new input shaft and RH drive axle seals. You need to replace the LH axle seal.
Old Mar 9, 2007 | 06:03 PM
Why do I need to replace the LH axel seal?
Old Mar 9, 2007 | 06:48 PM
eng92's Avatar
Well you do not have to, but standard practice on any tranny you get from a wrecker is to replace both axle seals.
The dismantlers generally do not take as much care as they should when removing the axles. An axle seal would be considered a normal wear-and-tear item so that if it leaks, the wrecker will not warranty its replacement.
You can order one and drive it in yourself when the tranny comes back from the shop.
For the few dollars that an axle seal costs, I would consider it cheap insurance.
Old Mar 9, 2007 | 07:07 PM
nismology's Avatar
Going with the 6-speed too?
Old Mar 9, 2007 | 07:18 PM
eng92's Avatar
Yeah, I found some smokin' deals on some parts, that I could not pass up.
It was originally going to be a winter 07 project but it will probably all come together within the month.
Old Mar 9, 2007 | 07:25 PM
JClaw's Avatar
Sounds nice. When do you think you will hit the track with your setup? You went the extra mile (6-speed + VTCs) so im very interested in seeing what times you put down, or at least what you trap if traction is a problem.
Old Mar 10, 2007 | 06:59 AM
SR20DEN's Avatar
VQ Wizard
IIRC
There is a rubber freeze plug on the back side of the input shaft housing. Pop that plug out with a flathead screwdriver and you will see the input shaft bearing and a snap ring which holds it in place. You need to spread out the snap ring with a good set of snap ring plyers right before you lift/separate the trans cover off of the bellhousing.
Also dont remove the snap ring from the cover once the cover is off and don't forget it's there when you reassemble.
Old Mar 10, 2007 | 07:03 AM
SR20DEN's Avatar
VQ Wizard
Because the axle seals are cheap and easy to do, you should always replace them when you put in new axles. Better safe than sorry.
And if you've never replaced them before it is wise to buy a few of them. The first one can ruined while you 'practice'. Also get yourself a seal puller.
my03maxima
Jul 28, 2024 07:40 AM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Marc2theMax
Sep 28, 2015 08:13 AM
