Sponsored by:
Sponsored by: CARiD
00VI Help, AGAIN!!
Old Mar 13, 2007 | 12:14 PM
ghostmax301's Avatar
00VI Help, AGAIN!!
Ok, so i take advantage of this B-E-A-utiful day and go do a "check-up" on the UIM & LIM.... I discover that the VIAS cup has a LITTLE play(could that have been causing a problem? I will be fixing it though) AND 6 out of the 12 holes in the LIM (where the swirl control valve rod was) were open, the motor pulled the JB WELD OUT!!! It might have been a little oil in the hole to cause the JB to not stick but, dayum.... also, i have oil residue between my gaskets, LIM & UIM and inside the LIM runners.... what does this mean and is there ANY alternative to the JB Weld? I used the regular, "mix-yourself" package..
Thanks,
Aaron
Old Mar 13, 2007 | 07:46 PM
bump.............
Old Mar 13, 2007 | 07:54 PM
Tatanko's Avatar
Bacon Lover
JB weld is about as good as it is going to get. I would take the LIM off and clean it THOROUGHLY, then re-apply regular JB weld (not JB qwik or the stick stuff). You absolutely must let it set the recommended amount of time or preferably longer.
As for the oil, I'm not sure. I'll let someone else chime in on that.
Old Mar 14, 2007 | 02:23 PM
Cdg2125's Avatar
I'm with Pat. Take it off, clean and reweld. I have some oil in the seal around the tb as well. Never looked into it really. Should be a problem. Check the VIAS as well, jb might have come off.
Old Mar 14, 2007 | 02:27 PM
Kevlo911's Avatar
Kevlo for President
You can take it to an aluminum welder and get it welded.
Old Mar 14, 2007 | 03:25 PM
guess ill try to jbweld it again, idf that doesnt work then i get it welded or a non cali spec LIM
Old Mar 14, 2007 | 06:19 PM
goldtooth's Avatar
hmmmm, now ur making me nervous, if i should go check up on mine
Old Mar 15, 2007 | 04:58 AM
Ceasars Chariot's Avatar
Old Maxima Legend
on the lower i had the swirl valves as well. i spent bloody 80 dollars having it welded, guess its the best option but cost more
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
skinnypimp
Aug 28, 2015 11:45 AM
