Sponsored by:
Sponsored by: CARiD
3.5 swap fuel and napa injector harness connections
Old Mar 25, 2007 | 08:27 AM
chillin014's Avatar
Alright, i have a few more questions. First of all, i bought the NAPA S-10 injector harnesses and i know they have to be modified but i cant figure out how..anyone know? they arent sitting on the injectors and i dont want to go messing them up without knowing what i should be doing to them.
also, i'm kinda lost on how to hook up this FPR and convert to a returnless set up. The FPR came with a couple little plates with nipples attached to them and i'm just kinda clueless on what i should be doing with this thing. the fuel goes through the filter...and then a hose comes off the top and i'm supposed to put a "T" on that? and then what?
thanks guys. gonna be waiting for responses while i try to pop this axle back in to joint
Old Mar 25, 2007 | 08:37 AM
chillin014's Avatar
also i have a diagram of which nipple is the input and output on the fpr. so i got that covered i suppose just not sure what these extra plates are for...i guess cause its universal
Old Mar 25, 2007 | 09:52 AM
97_Roadrunner's Avatar
we in the EXACTLY the same process in the same at 13h09 in Quebec. Fuel system connections and injectors plugs...LOL super fun to do the smae things at the same time!!! Hope yours will run soon and well!! For the clips, we cut the wires, soldered them directly on the injectors pinouts. Sealed them with grey silicon...
Old Mar 25, 2007 | 10:07 AM
Nismo3112's Avatar
Custom User Title
Old Mar 25, 2007 | 12:57 PM
chillin014's Avatar
Originally Posted by Nismo3112
thank you!!
Old Mar 25, 2007 | 12:59 PM
chillin014's Avatar
haha you soldered straight into the pin outs your crazy. i have alot more to do actually, but these are the main things. i still have to find out how to route my coolant lines from the 3.5 oil cooler and make a TB adaptor plate.
good luck
Old Mar 26, 2007 | 12:54 AM
good luck
Well you'll think I'm even crazyer, because my 2001 QX4 TB is adapted to the IM with a WOOD plate with a 2.75 inches hole in the midle, made out of pine.
Pouhahahahhahahahahaahha!!!!!!
Old Mar 26, 2007 | 02:50 AM
matty's Avatar
wood, in your engine bay...thats just a no no
Old Mar 26, 2007 | 04:39 AM
chillin014's Avatar
Hahaha pine wood. I donno, I'd do it if I was desperate. These adaptor plates are a ***** to make and sometimes I don't have the patience and just want to see if the car is gonna work properly.
Old Mar 26, 2007 | 05:13 AM
chillin014's Avatar
So nobody knows how to customize the s-10 injector harnesses?
Old Mar 26, 2007 | 07:53 AM
Kevlo911's Avatar
Kevlo for President
If you can't figure out how to mod them, you can try to find some 350z injector connectors, that is what I used for my swap.
Old Mar 26, 2007 | 11:13 AM
Nismo3112's Avatar
Custom User Title
Why not stick them on the injector and see what needs to be done?
Old Mar 26, 2007 | 11:27 AM
chillin014's Avatar
Yeah I tried that but its just hard to tell I figured I'd ask before I went and started cutting them up.
Old Mar 27, 2007 | 06:32 PM
chillin014's Avatar
i had to murder those harnesses to get them to fit. i still feel uneasy about it and think i'll keep my eyes out for some stock ones in the future.
After running most of the necessary lines for the fuel and what not i have a little bit of a hose mess going on.
I didnt want to start a new thread to let everyone know i'm almost done, do i have to wait until i turn the car on before i can add more tranny fluid? ive put like 6 quarts in and some started leaking out the bottom.
The Frye
Sep 2, 2021 11:03 AM
BkGreen97
Apr 2, 2016 05:47 AM
I<3 A32's
Sep 10, 2015 11:07 AM
MaxLife17
Sep 8, 2015 02:36 PM
Maxboy23
Sep 4, 2015 06:04 PM
