Sponsored by:
Sponsored by: CARiD
Emissions in VA, ECU not ready.
Old Mar 28, 2007 | 07:48 PM
oTranscendental's Avatar
I figured I'd ask the all motor heads cuz you probably have a precise answer....
I got the "not ready" on the four main tests for emissions (the main one being the catalyst). This is most likely because the car battery died over night (reset ecu logs) and I only drove 25 miles before going to emissions.
After "not ready" I drove 75 more miles to reach 100, but the ECU still was "not ready".
How many mile do you need to drive before the ecu is "Ready"?
PS: I have a 97 with vq35, but I'm running a 96Technosquare ECU.... could this be the problem? I know 97+ is OBD2, but are the 96 ECUs?
Old Mar 29, 2007 | 07:34 AM
NmexMAX's Avatar
dot dot dot ...
All 95+ ECU are OBDII.
Got any codes or anything like that?
Old Mar 29, 2007 | 07:41 AM
nismology's Avatar
Are you sure the rear o2 is working properly?
Old Mar 29, 2007 | 11:28 AM
Ok cool, Thanks for the info. All the o2 sesnors are working fine. Will have to drive more miles before its ready.
Old Mar 29, 2007 | 07:14 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Did you ever hook up the SMT-6? Having that installed will cause the o2 sensor and cat converter systems to not goto ready. I had to wire the ECU back to stock, so I could pass emissons testing here.
Old Mar 30, 2007 | 12:26 AM
I have the SMT wired in, but I'm running the bypass harness board instead of the SMT unit. Is this still going to make mine not ready?
When you rewired back to stock did you use extra lengths of wire?
Old Mar 30, 2007 | 10:19 AM
ps: the O2 sensors are different on 97+, but if that was the issue I would probably have a CEL right ?(which i don't).
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
