Sponsored by:
Sponsored by: CARiD
4th Gen TCU Wiring
Old Apr 30, 2007 | 02:28 PM
Tatanko's Avatar
Bacon Lover
4th Gen TCU Wiring
Sorry for all the threads lately, but it's becoming crunch time with some of my projects, and things are left unclear when explained originally or by the FSM. I have been using certain plugs in the engine bay as a source for wiring as far as the transmission goes (for shift_fast, for example) but want to switch to easier-to-work with TCU wires.
However, these wires don't appear to be the same in color, so I can't locate them. The wire colors match on the plugs in the engine bay, but don't seem to on the TCU (the TCU is the little black box on top, not the metal one on the bottom, right?).
Looking at the FSM, page AT-19, those are the wires I'm looking for. I can't find anything that seems to match though. A few wires match in color, but they aren't near each other like you'd think they would be. For example, solenoid "B" is light green/black as it says in the FSM for the plug in the engine bay. There does not appear to be a single light green/black wire on ANY of the plugs going into the TCM, let alone the plug that I think is correct.
So am I identifying the TCU correctly, and does anyone know which of these plugs has these wires and what color they should be?
Old Apr 30, 2007 | 02:35 PM
Kevlo911's Avatar
Kevlo for President
Check the color of the wires at the joint connector(there is a connect inbetween the tranny and the tcm)
Go to AT-10 and just compare the PIN# with w/e you need.
Old Apr 30, 2007 | 02:36 PM
Tatanko's Avatar
Bacon Lover
I did, that's the "plug" I'm referring to. That's where I had been tapping into the wires. Only SOME of those wires appear to match up on the TCM. For example, on the TCM wiring, I don't see a light green/black wire like I do on the joint connector (which is the wire for solenoid B).
I thought the wires were consistent in color throughout the whole harness?
Old Apr 30, 2007 | 02:38 PM
Kevlo911's Avatar
Kevlo for President
Check meh edit. I would assume they are but who knows with Nissan...
Old Apr 30, 2007 | 02:39 PM
Kevlo911's Avatar
Kevlo for President
TCM looks like a mini ECU BTW, the connector input is blue.
Old Apr 30, 2007 | 02:42 PM
Tatanko's Avatar
Bacon Lover
Ugh. No wonder. I'm looking at the wrong unit
Also, AT-10 for the 1995 FSM doesn't have a pin diagram on it
Old Apr 30, 2007 | 02:47 PM
Kevlo911's Avatar
Kevlo for President
Lemme get the pic... Pins should be the same.
Big pic but w/e
Old Apr 30, 2007 | 02:55 PM
nismology's Avatar
Meh that's the overview. Use the real wiring diagram.
Old Apr 30, 2007 | 02:58 PM
Tatanko's Avatar
Bacon Lover
I think I have it figured out. Keyword: think.
Sorry for the blurry pic, but:
Realizing that it's a tiny bit sideways, I assume that the wires go..
1 3 5 7...
2 4 6 8...
Like that, rather than straight across numerically. Am I right? If so, the wires match up. I can't seem to locate a green/black wire for the torque converter though in the location it says it should be
Old Apr 30, 2007 | 03:02 PM
nismology's Avatar
Old Apr 30, 2007 | 03:11 PM
Kevlo911's Avatar
Kevlo for President
Repost batman...
Old Apr 30, 2007 | 03:15 PM
Tatanko's Avatar
Bacon Lover
Originally Posted by nismology
Thanks. That clears it up for sure!
nismology's Avatar
Oh snapes...didn't realize the POS you posted before had the pinout.
Old Apr 30, 2007 | 03:30 PM
Tatanko's Avatar
Bacon Lover
I didn't catch that either. The one in the 1995 FSM doesn't have the pinout in the middle of the picture like that one does, and it was what I had printed out looking at.
Old Apr 30, 2007 | 06:27 PM
Tatanko's Avatar
Bacon Lover
Ahh, after countless interruptions, I got wiring in place for the torque converter (two wires and a 12v source). It got dark then, though, and I was tired, so I called it quits for the night. Now that everything is prepped and I have the knowledge, now, the rest of my wiring should all get done tomorrow.
Old Apr 30, 2007 | 06:32 PM
Kevlo911's Avatar
Kevlo for President
Sweet lemme know how it works.
Old Apr 30, 2007 | 06:40 PM
Tatanko's Avatar
Bacon Lover
I didn't test out the torque converter tonight, just wired it up and looped the wires back together for normal function until I put the switch panel in. I will test each "function" independently with a switch before installing the switch panel, though, just to make sure it all works. Perhaps next week, I'm busy the rest of this week and won't be home all weekend. Reliability and having the interior look nice is important this weekend haha.
Old May 1, 2007 | 09:18 AM
DandyMax's Avatar
3.5 in the works
Somebody's got a date.... lol
Old May 1, 2007 | 02:42 PM
Tatanko's Avatar
Bacon Lover
All my wiring is done except for the fan control switch. Going outside to finish that now
MAXSE5SPD
Sep 17, 2022 04:00 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Blackwind
Aug 5, 2015 06:35 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
