Sponsored by:
Sponsored by: CARiD
Well it was the oil pump...
Old May 21, 2007 | 10:33 AM
DandyMax's Avatar
3.5 in the works
Finally got a chance to pull my seized engine out and as soon as I got the pans off it became clear... oil pump, just like I (and most of us probably) thought.
Check out the pics below... cracked the casing in 4 places and shredded the teeth. In the 2nd pic those loose pieces off by themselves I found in the strainer..
Old May 21, 2007 | 10:40 AM
Kevlo911's Avatar
Kevlo for President
Old May 21, 2007 | 10:41 AM
KRRZ350's Avatar
What were you pushing for rev's? On a side note that engine appears to have low miles or have been well taken care of.
Old May 21, 2007 | 10:43 AM
DandyMax's Avatar
3.5 in the works
Kev I only see 3 cracks on that one...
KRRZ350: the engine had somewhere around 115k miles on it, it had lived on quality synthetic its entire life AFAIK. I was usually revving only to 7300-7500 but did hit higher a few times. It just fatigued I think, because it didn't actually fail at that high of a rev, I was around 4000-5000 during a burnout when it seized.
Old May 21, 2007 | 10:52 AM
95BLKMAX's Avatar
oh wow what a bad one. This is new to me to seea VQ oil pump go out like that (or to go out at all for that matter) nice pictures tho! lol
Old May 21, 2007 | 10:58 AM
1FSTMAX's Avatar
i cant see the pictars!...
Old May 21, 2007 | 11:01 AM
DandyMax's Avatar
3.5 in the works
Sorry.. fixed it (I think)
Old May 21, 2007 | 11:17 AM
1FSTMAX's Avatar
works now.. +1 on the clean engine.. So what is you next enine set up going to be?
Old May 21, 2007 | 11:23 AM
d00df00d's Avatar
Old enuf to pick his own gears
It has happened before with extended use with a really high rev limiter.
Old May 21, 2007 | 11:50 AM
gtr_rider's Avatar
192.168.1.1
I wonder what my beat 233k mile oil pump looks like :-x
Old May 21, 2007 | 12:02 PM
DandyMax's Avatar
3.5 in the works
works now.. +1 on the clean engine.. So what is your next engine set up going to be?
To get me through this season, a DEK out of an 01 with about 55k on it that I will modify a bit...
Old May 21, 2007 | 01:16 PM
Tatanko's Avatar
Bacon Lover
We better see a 12-second time slip
Old May 21, 2007 | 02:29 PM
JClaw's Avatar
Cams in a DEK will put this guy in the 12s! Once he has set the bar impossibly high for everyone else, hes gonna move on to the 3.5 and do the same thing.
Old May 21, 2007 | 02:32 PM
grey99max's Avatar
LandShark has Cosworth
Clever Canadians... J/K
Old May 21, 2007 | 02:52 PM
Zack342's Avatar
can you use a reved up oil pump?
Old May 21, 2007 | 03:22 PM
tavarish's Avatar
fwd gone rwd cr00
I think the air in canada is ideal for maximas, for some odd reason.
Old May 21, 2007 | 03:54 PM
SPiG's Avatar
SomePsychoGuy
Looks like some one needs a Rev up or HR oil pump?
Krismax blew his pump with a 8000rpm rev limit.
Old May 21, 2007 | 03:55 PM
DandyMax's Avatar
3.5 in the works
Tell me about it! I was so disappointed to be .007 away on that run before it seized...
BWAHAHA... you have discovered my evil master plan!
But I will need my secret weapon - Canadian "20% nitrous" air - to pull it off!
LOL. J/K... but in all seriousness, I am 100% sure I could have hit 12's with that engine on stock internals if it hadn't seized. I just figure now that since I have to swap in another engine I might as well tweak it a bit to increase my chances.
Old May 21, 2007 | 04:45 PM
speed racer's Avatar
Damn. that oil pump exploded. Great to hear your still considering the 3.0 platform. I feel that there's still unchartered HP that can be have from the 3.0.
Are you going aggressive with cams or just dropping in the 3.5 one's?
Old May 21, 2007 | 06:15 PM
GoalieKeg's Avatar
I figured it was your oil pump. Time for a revup one.
Old May 21, 2007 | 06:16 PM
nismology's Avatar
The standard 3.5 oil pump would be fine.
Old May 21, 2007 | 08:44 PM
Nealoc187's Avatar
SLOW
Why do folks suggest the Revup pump over the stock 3.5 pump? I've heard it suggested before but don't know the reasoning.
Old May 21, 2007 | 08:47 PM
GoalieKeg's Avatar
My logic is since revup motors take higher revs easier, then the revup oil pump must be either equal if not superior to the stock VQ35 non-revup pump.
Old May 21, 2007 | 08:52 PM
nismology's Avatar
The revup oil pump has like 17% efficiency over the standard 3.5 oil pump, but would be overkill for a 3.0. The standard 3.5 oil pump is good for 7500+ RPM and has to provide oil for the VTC sprockets and the piston oil jets. Subtract the VTC's and the jets and it's clear that the standard 3.5 pump would be sufficient.
Old May 21, 2007 | 08:53 PM
GoalieKeg's Avatar
So in other words my logic is correct...stfu n00b lol
Old May 21, 2007 | 09:11 PM
nismology's Avatar
Want a scooby snack?
Old May 21, 2007 | 09:17 PM
DandyMax's Avatar
3.5 in the works
I haven't decided what I'm doing yet. I need to do some measuring and analysis first... it will depend on $$ also.
Old May 21, 2007 | 09:34 PM
nismology's Avatar
Flow volume yes but what about ~8000-8200 rpm? Think the standard 3.5 will be as good as the rev-up at that level? Or would that be pushing it on both? ie will they hold together, assuming they can flow enough.. I'm trying to remember what pump 350zlover used on his high-rpm build (I'll search later if you don't recall)
He went with a revup oil pump shimmed to raise the "pop-off" pressure.
Your dilemma is something I've though for a while now. Do oil pumps fail due to mechanical failures (the internals physically not being able to handle it) or due to insufficient flow at high revs due to design issues, thus starving itself and the rest of the motor? Maybe they cavitate and cause the oil to foam at excessive revs? I wish I knew the answer...
Old May 21, 2007 | 10:40 PM
KRRZ350's Avatar
I'm voting for mechanical failure of the pump, but that's just my .02 cents.....
Mustang dohc failed oil-pump, on these engines they fail because of a weak powdered metal used in the gears, billet oil-pump gears take care of that. Please don't flame, I just thought that this was at least somewhat relevant to this thread.
Old May 21, 2007 | 10:50 PM
DandyMax's Avatar
3.5 in the works
Oh it was shimmed? Any more details on that (how much etc)? I didn't know that but I did realize he'd used the rev-up pump (which is why I deleted that part of the post).
But yeah, I'm wondering too about what failed. Cavitation could be a possibility, the resulting large pressure differentials behind the impeller teeth... Another thing is that crank torsional vibrations will only get worse with high rpm, resonant frequencies can become an issue and if one has a UDP that's not damped...? Or is it a mechanical issue (ie stresses/metal failure/fatigue simply related to the high speed)?
One thing I will say, that 3L pump casing seems thin/not rigid or reinforced enough to me... I'll be looking forward to comparing a rev-up pump in a few days.
Old May 21, 2007 | 10:54 PM
DandyMax's Avatar
3.5 in the works
No worries, it is.
Unless I'm mistaken though (small pic), it looks like the casing held together even though the innards 'sploded (how's that for a technical description lol), it looks a lot more rigid/reinforced than the VQ30.
Old Jun 11, 2007 | 12:33 PM
DandyMax's Avatar
3.5 in the works
Bump. Rev-up pump is now here... anybody want pics of it posted up?
Old Jun 11, 2007 | 12:57 PM
Red Lion's Avatar
...sure!
Old Jun 11, 2007 | 02:09 PM
Tatanko's Avatar
Bacon Lover
While you're at it, update us with your full progress. I know you were going to throw a DE-K in, but I don't know if you ever said whether you were going to put cams in or change anything else from your previous setup. So, fill us in
Old Jun 11, 2007 | 02:19 PM
nismology's Avatar
Pics of the guts? Sure...
Old Jun 12, 2007 | 06:43 PM
DandyMax's Avatar
3.5 in the works
Alrighty, so here's some pics. The casings are nearly identical and the rev up pump should fit right in place of the 3.0 pump (haven't put it in yet though).
The most noticeable difference is the depth of the inner/outer gears (by depth I mean thickness parallel to the axis of rotation - just look at the pics lol). The rev up gears are about 3 mm thicker. However, the tooth patterning is the same on both pumps.
I may shim the regulator yet before I put it in. Have to look up some info on that. BTW, the revup pump part number is 15010-AC700 in case anyone wants it.
Old Jun 12, 2007 | 06:45 PM
DandyMax's Avatar
3.5 in the works
Not much to update yet, progress has been slow due to other projects on the go with the house, doing work for local guys etc. I can tell you the DEK cams will be getting switched out though.
Old Jun 12, 2007 | 06:51 PM
I guess it being thicker means that it can handle more stress at higher revs without with minimal failure. It sounds like there may be some tinkering to get it in and working.
Old Nov 5, 2007 | 02:56 PM
DandyMax's Avatar
3.5 in the works
Some pics to complete the thread
Here are some pics of the #2 rod bearing that seized my DE engine (after the oil pump went). Always meant to post these but never got to it. Seeing as Neal posted his funky piston shots up today, I figured why not continue the engine carnage theme..
The other half was so bad I couldn't get the cap off the journal..
Old Nov 5, 2007 | 03:08 PM
Nealoc187's Avatar
SLOW
yyyyyiiiiikes....
