Sponsored by:
Sponsored by: CARiD
tranny gurus please step in(3.5 swap)
Old Jun 4, 2007 | 03:22 PM
bkmax96's Avatar
ok so i take my 3.5 4th gen max for a ride after i finally had finished it on sat night..it drives nice for sat night and most of sunday...sunday night all of a sudden the car wont go in gear and the clutch starts acting all funny finally im done coasting and the car wont move....the car will go in gear when the car is off...when i put the car in gear when its off and try to start it the car jerks forward....clutch feels like it has no pressure can someone please elaborate on this..i tourqued everything to within specifications...im using a spec stage 2 clutch...?????????? pleaseeeeeee..lol ive worked so hard to get to this point... i dont want my work to go down the drain..
Old Jun 4, 2007 | 03:24 PM
Bufflomike's Avatar
Sexier Than Simpson
Sounds like a throw out bearing
Old Jun 4, 2007 | 03:48 PM
95BLKMAX's Avatar
I suspect throwout bearing as well.
I thought of maybe you got air in the clutch line (maybe you changed the slave cylinder and it got air in it). But if there was air in it I would think that you wouldnt be able to get it into gear with engine on OR off. Unless you're talkin about shiftin the tranny w/o pressing the clutch.
And dont worry meng. After what you've done at this point, dropping the tranny is no big deal, lol. But yea I know what you mean.
Old Jun 4, 2007 | 04:56 PM
pmohr's Avatar
No more Maximas...
Does the clutch pedal just drop to the floor, or does it still spring back? Check fluid level in the master cylinder, and see if the slave cylinder is pushing the fork like it's supposed to.
Old Jun 4, 2007 | 05:17 PM
bkmax96's Avatar
the fork is moving ..the pedal inside the car feels stiff and does not want to go in and out
Old Jun 5, 2007 | 08:14 AM
95BLKMAX's Avatar
did you put hi temp grease or anti seize on the imput shaft/ inner bore of the throw out bearing/ ears of the bearing+ends of the fork and its pivot point??
Old Jun 5, 2007 | 02:47 PM
bkmax96's Avatar
yes sir i did
Old Jun 5, 2007 | 02:52 PM
danman700's Avatar
torqued the clutch? I was damn pissed when i forgot to once and took me to pull the tranny out to realize that stupid mistake
Old Jun 5, 2007 | 03:29 PM
bkmax96's Avatar
yes tourqued the clutch and the flywheel to specifications
Old Jun 5, 2007 | 07:25 PM
Red Lion's Avatar
sounds to me like an issue with the slave cylinder. maybe the slave cyl is jammed. I had a similar incident happen where my slave cylinder wasn't engaging the fork/tob and it wouldn't go into gear (except it would when the car wasn't on). It was really hard to get it in gear when the car was on and I had to basically shove it in or rev match to get it into gear. The Slave Cyl just wasn't engaging that tob to move out far enough
Old Jun 5, 2007 | 08:54 PM
bkmax96's Avatar
yeah thats what a few other people have been saying also..what do you suggest? i do get a new slave cylinder?
Old Jun 6, 2007 | 01:07 PM
Red Lion's Avatar
well, first I'd make sure it's engaging the TOB fork (and arm on the outside of the transmission).
If it fully engages that arm and you still aren't getting anywhere with the shifting, you might have a problem inside the transmission.
If it doesn't engage the arm or doesn't engage it enough, bleed your hydraulic system and make sure the slave cyl is working properly. Take it off before you bleed it and have someone push the clutch pedal in to make sure it extends itself.
If that doesn't work and the arm still doesn't move, I'd refer back to what I said about it being something inside the transmission.
Old Jun 6, 2007 | 03:47 PM
bkmax96's Avatar
well shyt i hope its not the trans...im gonna rip[ it apart 2moro and see the damage
Old Jun 6, 2007 | 04:02 PM
XJinCT's Avatar
<3's the all motor section
i can assure you 100% its not the transmission. have no worries my friend.
just do what everyone else said. check for fluid...check for air in the line...you said the fork is moving...so i doubt its either of those. its probably just the throw out bearing.
Old Jun 7, 2007 | 05:12 PM
bkmax96's Avatar
ok well i checked the fluid again and the slave to see if it was moving in full and yes they are both good ..the clutch is still engaged im guessing?lol..what else could it be then?
Old Jun 7, 2007 | 05:18 PM
Bufflomike's Avatar
Sexier Than Simpson
This may be a repost...but the throw out bearing?
Old Jun 8, 2007 | 02:12 PM
bkmax96's Avatar
lol yeah im guessing thats it im going to take the car to my shop 2moro and rip it apart
Old Jun 11, 2007 | 09:13 PM
bkmax96's Avatar
LMAO u guys have got to see this....i have never seen anything like this evar...this is only after 50 BABIED miles....look at the springs.....i was furious earlier today but i guess i hafta live with it and just return it for another one...
[IMG][/IMG]
Old Jun 11, 2007 | 10:29 PM
matty's Avatar
Thats the second time I have seen that happen to a SPEC on here
-matt
Old Jun 11, 2007 | 11:12 PM
jcy98maxse's Avatar
Turbo is too much fun!
Sorry to see that... I think it's really a hit or miss thing with SPEC. I've seen some people go thru them like you do when other people like myself haven't had any problems with them. Sure makes me second guess about buying from them again.
Old Jun 11, 2007 | 11:26 PM
matty's Avatar
Do Specs chatter ??
Old Jun 11, 2007 | 11:28 PM
jcy98maxse's Avatar
My SPEC 3 chattered a little at first but after about 1K miles, and a blimp of throttle play, it went away. I have not had any problems with mine since I put it in a year and half/two years ago. Its been thru a 125shot and turbo now. It'll be in my 3.5 turbo until probably end of this year. I may go with something else next time.
Old Jun 12, 2007 | 12:52 PM
95BLKMAX's Avatar
wow yea this sucks. That first person that it happened to i believe it was tavarish when his car was stolen right after the swap.
But I have a Spec Stage2 and have had no problems at all. And same as jcy98maxse it did chatter a little the first thousand miles, but it went away after that. While it did it I would just rev it a bit higher during slippin the clutch for 1st gear and that avoided it. Im happy with it.
JoshG
51
Sep 21, 2015 10:41 PM
Socalstillen
Sep 20, 2015 11:46 PM
toyoking
Sep 16, 2015 07:05 AM
MaxRPM6
Sep 11, 2015 06:56 PM
pktaske
Sep 4, 2015 08:40 AM
