Sponsored by:
Sponsored by: CARiD
3.5 swap getting me angry now
Old Jul 6, 2007 | 06:01 PM
bkmax96's Avatar
ok so i finish the new clutch and and start the car and everytings fine...then the car just shuts off no rough idle just flat on its face...so i crank it again and the car will not start the starter is smoking and im getting pissed..l...i see a ground wire that is melted..(the one by the alternator where the headlight goes)...then i plug the little ground that goes in the back of the trans near the speed sensor and the car turns on and everythings fine...then today after a 40 mile drive i shut the car off and come back out to start it and it will not start... it will crank fast and then it sounds like the starter just does not want to work anymore..battery is new starter is 3 months old and as far as i can see all grounds are good...someone please help me before i part this shyt out and say Fack it....this swap has given me nothing but headaches
Old Jul 6, 2007 | 06:25 PM
STILLENGLE's Avatar
1. iam not trying to be an A$$ but if you though you couldnt handle something so big you should have had someone help or had someone with more experience do it.
2. check all your connections. you said you have a melted wire check that.
3. Dont give up
Old Jul 6, 2007 | 06:41 PM
bkmax96's Avatar
3. Dont give up
lol i can handle it im looking for some help
Old Jul 6, 2007 | 06:42 PM
STILLENGLE's Avatar
just look for people who have done it before there be glad to help lol.
Old Jul 6, 2007 | 09:07 PM
nismology's Avatar
Sounds like different grounding issues.
1. How is your harness ground? What is it grounded to?
2. Did you make sure the engine/tranny mating surfaces were clean before reassembly?
Old Jul 7, 2007 | 05:49 AM
Torgus's Avatar
i bet it's that.
Old Jul 7, 2007 | 02:04 PM
bkmax96's Avatar
yes i did nismo..the car will run fine when i popstart it but when i try to crank it normally ..it trys to start but wont turn over
Old Jul 7, 2007 | 02:15 PM
bkmax96's Avatar
i know its sometihng stupid but im getting my *** kicked trying to start it... the starter is getting a little too hot also......fuel seems fine because when i pop start the car it runs like a champ..
Old Jul 7, 2007 | 02:23 PM
speed racer's Avatar
Start looking at all the wires again. I'm sure its something overlooked.
Old Jul 7, 2007 | 05:36 PM
bkmax96's Avatar
so i got another starter and put it in and the thing still wont start have spark and fuel.....but no start.....someone please give me a diagram of some good grounding spots and please tell me anything i overlooked
Old Jul 8, 2007 | 08:12 AM
Did you check the relay. Look at the FSM and start looking at the electrical for the ignition system.
Old Jul 8, 2007 | 06:24 PM
bkmax96's Avatar
im good now i put new grounds and grounded my main ground to the trans
Old Jul 9, 2007 | 10:19 AM
Glad you figured it out. I was about to suggest cleaning and checking the bell housing/re-grounding the transmission. This seems to solve 98% of people's starting problems with your exact symptoms.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
