Sponsored by:
Sponsored by: CARiD
? Good cams for a 3.5 build ?
Old Oct 28, 2007 | 05:22 PM
  #121
grey99max's Avatar
LandShark has Cosworth
It's Alive!
I unloaded my car off the trailer Saturday and began the job of hooking everything back up. Got 'er dun this afternoon, and after fumbling through a few things that still needed hooking up, I got it started!
Video:
http://s48.photobucket.com/albums/f2...t=Dscn2527.flv
Saying goodbye to my MEVI:
http://s48.photobucket.com/albums/f2...t=Dscn2529.flv
I filled the auto w/4 1/2 qts of Mobil1, and it seems fine.
I'm going for a ride tonight. We shall see.
PS. The last engine blew at the strip: When the engine was yanked last week, my guy noticed the intake filter was puffed up - exploded.
You know how the MAF has a screen on one end?
http://i48.photobucket.com/albums/f2...d/Dscn2512.jpg
Well, the air filter looked like this:
http://i48.photobucket.com/albums/f2...d/Dscn2513.jpg
With the screen blown down into it:
http://i48.photobucket.com/albums/f2...d/Dscn2514.jpg
But - the MAF still works. I have a spare, but I did a temp install of the original and it seems to work fine. I checked it with a multimeter, and both MAFs measured the same, so I tried the screen-less MAF. The 3.5 is running on it now. Now I need a new air filter....
Old Oct 28, 2007 | 05:29 PM
  #122
SonicDust187's Avatar
Video:
My maf and filter looked the same when I had a nitrous backfire.
Old Oct 28, 2007 | 05:36 PM
  #123
grey99max's Avatar
I think it was caused by sucking nitrous into the crankcase when the piston collapsed - I got at least three loud explosions from the car before I let up on the spray.
You gotta admit, that's a weird place to find the MAF screen.
Old Oct 28, 2007 | 05:47 PM
  #124
It is. I am now 100% sure you had preignition and your nitrous backfired.
Old Oct 28, 2007 | 07:19 PM
  #125
95BLKMAX's Avatar
w000h0000!!! go grey!!!!!!!
Congratulations! Please come back with your ubber reports
Old Oct 28, 2007 | 10:23 PM
  #126
streetzlegend's Avatar
Great stuff, the bouncy idle at times, is that because of the cams? its cool lol
Old Oct 29, 2007 | 07:30 AM
  #127
grey99max's Avatar
Well, it's cammed up for sure, but I've still got to adjust a million things, like the TPS settings and connect the remaining sensors. No IACV either.
There is a definite lope when I get it warmed up and idling around 800. Heh.
Funny - it wouldn't start at first ( OH SH*T!) and there was no spark,but when I plugged in the MAP sensor from the old engine, it started right up. I connected some other stuff, but the EGR sensor and solenoids are on the list still. Probably other things as well.
I did take it out for a drive last night, but kinda around the block. Transmission works fine, engine warms OK, Headlights work ! , and I can really feel the extra torque at low speeds, even with the 2800 stall converter. And I started it this morning before leaving for work, and it fired right up at 38* outside temp -which is where the car was sitting. That's good - I had to baby it for a minute or so before it would idle by itself, but that's expected.
I'll swap in my spare MAF and see how that goes - I can't believe the original MAF even works after the screen blow-out...
Stiil,
Old Oct 29, 2007 | 10:28 AM
  #128
coinage's Avatar
just curious but what did you do for your cam break in? what i am reading is 30 mins above 1500rpms...
Old Oct 29, 2007 | 10:41 AM
  #129
DandyMax's Avatar
3.5 in the works
Cam manufacturers usually have specific instructions but most are usually something like 20 mins at 2000 rpm.
Old Oct 29, 2007 | 10:45 AM
  #130
coinage's Avatar
yeah thats what my brother said, 20 mins at 2000... i got the 1500 for 30 mins off of cranes website
Old Oct 29, 2007 | 01:59 PM
  #131
grey99max's Avatar
Break-in? I was gonna go out and spray it for break-in....
Those cams came with a coating on the lobes, so they shouldn't require break-in, right?
OK - I was just planning on some gentle highway driving, like to Kansas City and back, which is about 2 hours flight time. Then I'll change the oil and filter to get rid of all the misc. chunks I left in the engine.
Old Oct 29, 2007 | 07:53 PM
  #132
grey99max's Avatar
things are better....
I connected up the EGR temp sensor and replaced the blown-out MAF with my spare, and now it runs mucho better! After topping up the engine and tranny Mobil1 levels, I took it for a ride to the lickker store and the gas station.
Went out on the highway and tried the cruise - it works! It pulls hard from a stop now - nothing like a 3.0 - much more like my wife's '04 maxima. Power comes on early and it really like to rev - but I didn't push it tonight - well, maybe once, but with 225/55/16 BFGs, all I got was tire spin.
More to do, but the loping idle makes it all worth-while.
Old Oct 29, 2007 | 08:11 PM
  #133
Trader to use 3.0 guys. At least we still have Dandymax.
Old Oct 29, 2007 | 08:13 PM
  #134
coinage's Avatar
I'm fairly certain that the break in is what was said,
the coating was either assembly lube or something of the sort...
Old Oct 30, 2007 | 07:46 PM
  #135
grey99max's Avatar
I think I've taken care of the cams break-in thing. I went out tonight and let 'er eat through 1st and 2nd gears. It's like punching a big-block Chevy - the car gets through 1st gear in a heartbeat, hits fuel-cut before going into 2nd, and pulls to 80MPH in a very short time.
The car feels like it's twisting in first gear while spinning and sliding around (street, remember?) the road, bangs 2nd, then hits the afterburner. Without nitrous. I really like this motor.
This upgrade is gonna take a while to figure out, and I was using the stock automatic shifting points - no pressure boost. Whew.
Old Oct 30, 2007 | 08:01 PM
  #136
coinage's Avatar
man... this makes me want to swap my new motor in asap...lol
Old Oct 30, 2007 | 08:05 PM
  #137
Talking
Wow man, that sounds great. Your drop resistor mod is still active when doing these runs right? Be careful how you drive at part throttle, since now you have more part throttle power (where the drop resistor mod is not being used and can risk a slip and dead tranny).
Congrats, awesome to see another auto 3.5
Old Oct 30, 2007 | 08:16 PM
  #138
grey99max's Avatar
Oh, it's worth all the work and worry..... Oh, yeah..
Old Oct 30, 2007 | 08:23 PM
  #139
grey99max's Avatar
Congrats, awesome to see another auto 3.0
Nope - no DR mod hooked up right now. Don't worry - I know about automatics, remember? Besides, I've got a spare VLSD for when I trash the 13.158 ET VLSD. It seems fine -at the moment. I don't usually scr*w around on the street, but I needed to try this beast.
And it's now a 3.5 auto.. Remember me?
Old Oct 30, 2007 | 08:30 PM
  #140
lol edited my post sorry, im used to typing 3.0 haha
Old Oct 30, 2007 | 08:39 PM
  #141
grey99max's Avatar
It's all good..... I'm not used to this 3.5 stuff yet. Yet...
I've got a short stub of an air intake and the custom OBX headers connected to the up-cammed 3.5. It can breathe purty well, I'd say. Plus it idles niicceeee....
Old Oct 30, 2007 | 09:00 PM
  #142
coinage's Avatar
yeah i hope so...i am coming from a 3.5 and going to a cammed 3.5 (JWT C-2 Race grind baby) so i guess it will be different, but not that different... i guess we will see....
i better get some nice idle lope lol... BTW, did you bump you idle up? i saw jwt and others recommending putting the target idle at 850...
Old Oct 31, 2007 | 06:31 AM
  #143
grey99max's Avatar
Yes I did - 800 RPMs is the absolute minimum now, for these S1 clone cams. 900 is better. And they lope
Old Oct 31, 2007 | 09:15 AM
  #144
Tatanko's Avatar
Bacon Lover
Glad to see the car is back in action grey! Sucks it's the end of October already though There is a chance I may have some tricks up my sleeve over the winter, though
Old Oct 31, 2007 | 10:44 AM
  #145
DandyMax's Avatar
3.5 in the works
I got mine idling at 650 nicely...
http://youtube.com/watch?v=Cxsxw8R3DLA
Old Oct 31, 2007 | 12:51 PM
  #146
grey99max's Avatar
It ain't over in Kansas CIty 'til December. If the suns shines, it's over 40*F, and the creek don't rise, they'll be racing at KCIR on Sunday afternoons in November!
What you doin' Tatanko? Buyin' a Chevy?
Old Oct 31, 2007 | 12:59 PM
  #147
grey99max's Avatar
[kidding] I bet you set your TPS. Someday I must learn the mystic secrets of EU tuning, as well. Of course, you still have that small 3.0 as well - maybe little motors idle easier. [/end kidding].
[serious] man, if you work the same magic on a 3.5 as you did to that poor 3.0, well, you can sell tickets to that track outing. [/serious]
Old Oct 31, 2007 | 01:12 PM
  #148
DandyMax's Avatar
3.5 in the works
My TPS setting is as per stock/FSM, no trickery there, in fact it should idle worse with a light flywheel, but the key is the EU adjustments and cam timing somewhat too...
Right now the plan is to put the 3.5 in during the dog days of next summer (say July or so). Or maybe a little earlier depending on what else I feel like doing (or don't) to this 3L. But in the mean time, the DEK should go faster yet, maybe even this weekend if the weather holds... That 12.8 was not by any means the apex, I had a lot of issues that day and overall it was a crappy day even though I managed to hit 12's a couple runs.
BTW I better see at LEAST low 12's out of your cammed 3.5 on spray...
Old Oct 31, 2007 | 01:35 PM
  #149
Tatanko's Avatar
Bacon Lover
Oh no, this is all Maxima business. I intend to have more area under the curve for next spring, though. That includes a new intake setup, some revisions to my manifold, some A/F tuning, a CRAPLOAD of maintenance, some revisions to things that should have been done differently in the first place, and uhhh...something else
I demand 11's
Old Oct 31, 2007 | 02:31 PM
  #150
grey99max's Avatar
Or like a Fourth-of-July rocket - whoosh ! BOOM! Oh, wait, I've done that already......
Much as I'd like to, I need to install a wideband before I spray this one. But I can still track it while NA.... I would REALLY like to do that yet this season.
Old Oct 31, 2007 | 06:53 PM
  #151
DandyMax's Avatar
3.5 in the works
Yeah you should do it N/A a couple times, just for fun, get a baseline etc...
Old Oct 31, 2007 | 10:04 PM
  #152
95BLKMAX's Avatar
I second this motion grey. dont get too trigger happy with nitrous from the get-go. Have some fun with it NA before
Old Nov 1, 2007 | 07:38 AM
  #153
grey99max's Avatar
Looks like I've been out-voted on the spray. Actually, I've got several things to do yet, including gutting the intake and installing a wideband, so no spray on the track this season for me.
I can use the NA setup to recalibrate the Shift_Fast_2 and clean up CEL codes and such. Heck, I've never opened the cutout on the headers, yet. In the garage doesn't count, right?
Some NA track-time would be a good way to end the season, and maybe a chassis dyno pull or two for a baseline. Yeah, I'm gonna do that.
Old Nov 2, 2007 | 07:30 AM
  #154
grey99max's Avatar
Went out to play last night ...
I restored the manual control wiring for the VLSD automatic last night, and went out to test a couple of on-ramps I'm familiar with. On street tires, not even DRs.
The car pulls hard, and seems to be about as fast as the 3.0 with one 75-shot stage of nitrous. I do miss the kick-in-the-back feeling you get with nitrous, but the way the engine pulls over 4K makes up for it. This one likes to rev hard and fast to fuel-cut!
Somebody tell me - with stock 3.5 injectors and 43 psi fuel pressure, is the A/F gonna be in the normal range? I'm thinking about taking the car to a track on Sunday but don't have any way to check it - unless I can get a Saturday dyno time locally. Huummmmm....
Hock your guns, sell the kids, burn down the house for insurance money, whatever it takes, but put a 3.5 in your Max.
Old Nov 2, 2007 | 07:45 AM
  #155
DandyMax's Avatar
3.5 in the works
Sounds like someone's got swap afterglow...
Old Nov 2, 2007 | 08:08 AM
  #156
Great stuff grey, how ever, I dont think you should gut your intake. To be honest I dont think its worth it unless you have 7K+ shiftpoints which you dont, by gutting it and not having higher rev limiter your actually going to lack power more than gain. Your mid range power is going to be weak which is something you dont want specially with the auto.
gutted intake==> Your going to be at the line, brake torquing at 3,000. You launch, rpm's starts to reach mid 3k and you bog, then little by little start to build up power, bye bye 60'.
I say leave it as is.
Old Nov 2, 2007 | 09:16 AM
  #157
grey99max's Avatar
Or I could gut it and spray it... that should take care of the midrange.
Yeah, one thing at a time. For now, anyway, what with winter coming quickly here.
Old Nov 2, 2007 | 09:22 AM
  #158
grey99max's Avatar
Hah! that's it! A warm cozy feeling, all cuddled up to my .. 3.5 ???
I think that moving from a much-modded 3.0 to a modded 3.5 has been such an education that I'm still excited about it. Plus, I tore that motor down to the block/crank/rods/pistons and put it back together and it runs!
Now for the next one...
Old Nov 2, 2007 | 09:51 AM
  #159
95BLKMAX's Avatar
The educational experience of going through the labor that it takes to prep the motor, and undergo the swap process, is simply priceless. Probably more rewarding than the power gained from the swap (although that power increase IS quite nice hahaha).
and as far as gutting the manifold goes, this is a dyno from yesterday. Me=Blue, a friend with an 02 6spd with JUST an intake=Red.
Of course this isnt a fair comparison as far as gutted IM and properly working IM goes. There are other things going on there, like my SSIM, my lack of VCTs, my 3.0 ECU's lower Ign timing advance (relative to the A33b's ECU).
I was actually looking at a dyno from before I did the SSIM (Although the IM wasnt gutted, it wasnt working either, it was on its default open position- just like Grey99s IM currently is), and the dyno I did after doing the SSIM, and really.... the dip in the midrange was always there, same drop after the SSIM.
Before SSIM (default-open IM)= http://i32.photobucket.com/albums/d4...-1n4-Feb22.jpg
^^notive that the whole graph is showing lower #s due to the SAE cor factor^^
After SSIM= http://i32.photobucket.com/albums/d4...yno4-7-07a.jpg
^^STD cor factor, so yes #s are higher, but we're not lookin at raw #s, we're looking at the shape of the curves^^
So AS FAR AS SSIM'ing APPLIES TO US SWAPERS WITH THE 3.0 ECU AND TIMING EQUIPMENT... gutting the IM isnt doing any more harm at all to the midrange than is running the IM on its default open position.
Old Nov 2, 2007 | 09:54 AM
  #160
NmexMAX's Avatar
dot dot dot ...
5MT > 4AT. . . . .
