Sponsored by:
Sponsored by: CARiD
How To: Correct jumped timing...
Old Jul 24, 2007 | 10:21 PM
KRRZ350's Avatar
Step 1: remove #1 coil/plug and position #1 cylinder at tdc on the compression stroke.
Step 2: Remove upper half of engine mount, and anything else that might get in the way of step 3
Step 3: Remove tensioner inspection cover.
Step3: Compress and lock tensioner, then remove it.
Step 4: Using a 19mm socket, rotate the crankshaft counterclockwise until you hear the chain skip a tooth.
Step 5: Re-install everything and verify correct ignition timing and vacuum reading
This only applies if you skipped timing upon initial cranking, and only if it skipped on the crank sprocket, but I believe that's where it skips everytime.
Old Jul 25, 2007 | 12:36 AM
Maximus_95's Avatar
how can we know 100% if our timing skipped a tooth?
Old Jul 25, 2007 | 04:24 AM
nismology's Avatar
Either check the base timing at idle with a scanner/logger or use a timing light.
litch
123
Jan 4, 2024 07:01 PM
Need help
23
Oct 2, 2015 08:56 AM
leatherneck
Sep 30, 2015 09:16 PM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
