Sponsored by:
Sponsored by: CARiD
Timing Chain Rattling on 1st start..how long
Old Aug 6, 2007 | 04:48 PM
danman700's Avatar
How long does the tensioner rattle for on 1st start up. I thought i was all done messing with my 3.5 swap, but i started it and got her idleing waiting for the rattleing to go away, and its been over a half hour. It either the chain or i got some serious valve problems. It does increase with engine rpm so idk what is going on, any input guys?
Old Aug 6, 2007 | 04:55 PM
DasYears
hows the oil level? low oil can cause a rattle on start-up, maybe really low oil causes it to continue? did you prime the tensioner? get a s***hescope and put it to the block and find exactly where the rattling comes from
Old Aug 6, 2007 | 07:01 PM
danman700's Avatar
I put 5qt's in. This is getting werid, I hooked up the cruse control, and for some reason when i started it the engine went straight to redline. So i unhooked the cruise control, it was to tight, and started it again..noise gone. I had a few more little things like tighting down my throttle cable brackets to do before my 1st test drive, so i do all the little things, start it up get 2 houses away and i punched it in 2nd a little bit, nothing serious. The damn noise came right back. It sounds like somethings rattling around, tomorrows another day, i'll figure it out then
Old Aug 6, 2007 | 07:08 PM
NmexMAX's Avatar
dot dot dot ...
I'm guessing you somehow set-up the CC incorrectly (throttle cable must have got caught up somewhere and caused the throttle to go @ or near WOT during start-up.)
Now I'm wondering if it's not a heat shield/exhaust rattle vs timing chain. Pinpoint the noise using a stethoscope as DasYears pointed out. Or even a rubber hose.
Old Aug 6, 2007 | 07:28 PM
XJinCT's Avatar
<3's the all motor section
my chain rattles occasionally on hot days when i first start it up. i put in 5w-30 to start with. im switching to a thicker oil next oil change, should solve it.
congrats on getting it running finally though man.
Old Aug 6, 2007 | 09:09 PM
Nealoc187's Avatar
SLOW
when I did a swap with a junkyard VQ, it rattled really loud for probably 15 seconds and then went silent.
Old Aug 7, 2007 | 12:53 PM
nismology's Avatar
A short video clip would REALLY help, if possible.
Old Aug 9, 2007 | 08:46 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
You should REALLY prime the motor before you start it. Every time I do timing chains and water pump on customers Maxima's I do this. The last 2 handfull chain jobs I've done have rattled for approx 1 minute till all the noise went away. I've done it where I forgot to prime the motor- kinda in the hurry to get it done, and the motor rattled for approx 5 min. I just put a screw driver in the throttle body drum, let the car run at 2400RPM for 2 min and it would go away.
How is your oil pressure ? I seen one too many VQs with bad oil pumps.
Old Aug 24, 2007 | 11:51 PM
andrei3333's Avatar
^ i have the vq30de 97 and i think i might also have thie timing chain rattle. Usually on the first start of the day, or after work. It does it for about 15-30 seconds and goes away. but i have a feel of the noise on my foot when u touch the brake peal too.
no oil is leaking on the floor, so i think the oil pressure sensor is still fine. but i know its a known issue.
Old Aug 25, 2007 | 12:09 AM
accordingtou's Avatar
VQ30 DE T
Imo timing chain guide & tensioner maybe?
Sure fixed my rattle attle.
Old Aug 25, 2007 | 10:22 PM
andrei3333's Avatar
i dont think i could do that myself, and it would cost me a pretty penny to get it done at a shop.
is it ok to leave it like it is ?
Old Aug 26, 2007 | 08:34 AM
1chewabacha1's Avatar
You could leave it... But the rattling will only get worst. Just change it out yourself it's actually pretty easy.
Hondarydr
Dec 30, 2024 06:15 PM
Matt93SE
May 24, 2019 02:58 PM
maxinout93
Oct 27, 2015 01:29 PM
kingw323
20
Oct 21, 2015 08:36 AM
criminalslang810
Aug 16, 2015 08:12 AM
