Sponsored by:
Sponsored by: CARiD
So i run megasquirt // lets talk advance timming
Old Aug 18, 2007 | 11:23 AM
  #41
NmexMAX's Avatar
dot dot dot ...
Originally Posted by nismology
Dude isn't running CVTC so his VE curve is going to be different. Ignition timing should be different to match.
I was kinda replying to this: Kinda = mine isn't stock.
Originally Posted by Kevlo911
If you search around you will find stock A33b timing graphs
Old Aug 18, 2007 | 05:36 PM
  #42
rmh3093's Avatar
Only gentoo powered Maxima!
Originally Posted by hightuner
its still kind of a little bucky when warming up , but once it done it run pretty well. I had to get used to my act clutch too. i need to work on ,my accel , and a few other thing , I think i switch to ms extra soon ... and see how it goes , and try some goddies.
is your cold start issues due to you not spending time fixing that yet or is that the best you can do... the megatunix screenshot for the idle control + crank/warmup tabs looks complicated (lots of tunables).... is there any info in the factory service manual that would help iron out your cold start
... what version of the MS2 do you have v1 or v2... v1 has a green pcb, v2 has a blue one.... the v2 has CAN support which could be really sweet
Old Aug 19, 2007 | 07:13 AM
  #43
hightuner's Avatar
Nissan maniaco conpulsif
Hi rmh3093, in fact the car always start,
the fms manual is definaly very handy
thoses problems definally can be improve
the starter turn more time , i belive that can be sort out whit priming and cranking pulse
and the car run bucky un its 190f this can also be fix whit after start enrichisement
I havent really try either one yet.
i do not have idle valve at the moment but i plan to istall a simple on/off .
i use ms2 V3 board 2.862 b&g.
another great feature is data logging , and ve analyser it help you fine tune
sorry for the poor quality sample
Old Aug 19, 2007 | 08:00 AM
  #44
rmh3093's Avatar
a friend of mine said there is a guy here in Rochester that has a dyno shop, builds turbos, and he specializes in megasquirts (or at least uses them him self) I guess he is always talking about MS... anyway I very excited to hear there is a MS guru local to me.... I definately am getting my self a MS
EDIT: http://www.baldturbofreak.com/ is his site for anyone in buffalo, rochester, syracuse
Old Aug 19, 2007 | 08:50 AM
  #45
hightuner's Avatar
sweet
Old Jul 13, 2010 | 11:10 AM
  #46
fuscanet's Avatar
distributor and megasquirt
Hi
im installing a megasquirt 1 SnE into a maxima engine.
i want to controll ingition as well, but i cant find any wiring schematic for its distributor optical sensor.
here is a photo of it
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
