Sponsored by:
Sponsored by: CARiD
Just put motor and tranny back in and the car will not pull!!WTF
Old Aug 20, 2007 | 04:37 PM
95turbo gxe's Avatar
Ok Just got dont changing timing ring and making a new turbo set up. Got it all done and fired it up to drive. I put it in gear and the car just revs up and will not pull at all. The car sound like its going in to gear but will not pull or grind or nothing just free rev. Im pretty sure The clutch is in the right direction. But what eles can I trouble shoot or what did I do wrong?
The car will go into gear with it running and will not move. Also you can cut the car off and put it in gear and the car will just free roll.
Old Aug 20, 2007 | 04:55 PM
hightuner's Avatar
Nissan maniaco conpulsif
humm that odd.
forgot the axles lol ?
seriously are you sure your clutch engage crrectly . check the clutch salve cylinder.
cable might shot.
Old Aug 20, 2007 | 05:11 PM
Originally Posted by hightuner
humm that odd.
cable might shot.
The slave moves over about a inch or so
Old Aug 20, 2007 | 05:45 PM
pmohr's Avatar
No more Maximas...
VLSD or open diff? If open diff, check to make sure you have the right axles (unless you used the same ones) and that they're fully seated in the trans.
It's either a clutch or axle problem, and I don't believe you can even physically fit the pressure plate over the clutch disk if it's in backwards... That's how it is on most cars that I've worked on, anyway, never done a 5MT Max.
Old Aug 20, 2007 | 05:49 PM
Kevlo911's Avatar
Kevlo for President
Sounds like axles.. I didn't see how you can mess up the clutch install when I did mine.
Old Aug 20, 2007 | 05:58 PM
But im using the same axles as before. It they was not in wouldnt it leak like hell And dont both wheels pull Im for sure the passenger is in all the way!
Just throwing some ideas out!
Old Aug 20, 2007 | 06:07 PM
pmohr's Avatar
No more Maximas...
It should leak like a sieve if the axles aren't fully seated, yes. That's the only thing I can think of though. Although I guess it's possible that one of the CV joints completely obliterated itself and is spinning seperately inside the boot, but the chances of that even being remotely likely are...slim to none.
For now, I'd say jack her up, put it in gear and see what happens underneath.
EDIT: You did...hook up the shift linkage, right? I know, the shifter would all kinds of just move around without it hooked up, but simple things first...
Old Aug 20, 2007 | 07:17 PM
KRRZ350's Avatar
Did you compare the old TOB with the new? Ask me how I know about that possibility.................
Old Aug 20, 2007 | 08:03 PM
Yeah I did not change clutches or anything they have less than a thousand miles on them.
But I found that the passenger axel is broke. SO i got to get another tommorow Thanks for the help guys
Old Aug 20, 2007 | 08:44 PM
DasYears
if you dont have vlsd, then you can very much be putting all the power to the axle that is not connected. it LOVES to do that. (giant one leggers FTMFL)
Lakersallday24
Jun 16, 2019 01:35 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
sc10692
Aug 9, 2015 09:37 AM
MikesChevelle
Aug 6, 2015 11:36 AM
laparka66
Aug 6, 2015 09:36 AM
