Sponsored by:
Sponsored by: CARiD
VAFC 2 and ECU issues
Old Sep 24, 2007 | 02:03 AM
huffdaddy2008's Avatar
Ok a little background. When i first installed the piggyback a month or so ago this problem occured, then went away. I had the battery disconnected for roughly 6-8 hours. Hooked the piggyback up properly. Heres the problem, when i woudl start the car it would start fine, then immediately die, unless i gave it some gas. This happened for a few days then went away.
Again, i had the battery disconnected over the weekend. I was putting on new gaskets for my headers cuz i had a leak. It started up fine, i drove around some and then turned the car off to get some gas. When i started it up, it happened again. The car will not idle without me giving it gas. I have the stock ECU. Does anybody know what the ECU is doing during this re-learning process to make the car die like it is? All functions/guages of the unit seem to be working fine.
Old Sep 24, 2007 | 06:26 AM
NmexMAX's Avatar
dot dot dot ...
SES lights?
Old Sep 24, 2007 | 07:31 AM
Originally Posted by NmexMAX
SES lights?
Nope. Nada.
Old Sep 24, 2007 | 09:35 AM
95BLKMAX's Avatar
Could u tell us the settings you have on the AFC? to make sure you have the right car type/ MAF in/out, sensor type, etc...
Old Sep 24, 2007 | 10:48 AM
Car Select: 6 cylinder, NE arrow, V/T 1
Sensor No: 1 in, 1 out
Sensor Check: Pressure = 1.275 V, Throttle = .645 V
In Monitor mode: Pressure range goes from -12.xx psi to + 11.xx psi
An SES just popped up...im goin up to autozone right now.
Old Sep 24, 2007 | 10:51 AM
nismology's Avatar
Check the MAF in/out wiring. Maybe that or the MAF's on it's way out...
Old Sep 24, 2007 | 11:10 AM
SES codes were P0300 - multiple random misfires and P0327 - knock sensor circuit low voltage. Lol the exact same codes as last week. Dealership just replaced a coilpack and 4 spark plugs. Time to go back...
Old Sep 24, 2007 | 11:18 AM
gtr_rider's Avatar
192.168.1.1
did you happen to wire the KS into the VAFC install for whatever reason?
Hopefully once they see how the car starts up they'll replace the MAF
Old Sep 24, 2007 | 11:31 AM
Yes i did. Should i not have done this? I used Puppets wiring diagram: http://forums.maxima.org/showthread....wiring+diagram
Old Sep 24, 2007 | 12:32 PM
gtr_rider's Avatar
192.168.1.1
Remove that wire to the KS, i did the same and it caused some really nice hiccups while driving.
Old Sep 24, 2007 | 12:36 PM
dfownz's Avatar
Make sure you have it set to hot wire also. It couldn't hurt to go over the wiring again either.
DF
Old Sep 24, 2007 | 10:29 PM
Alright I will, thanks for the help guys. Its already back to starting and idling normal again. I really dont get it.
Old Oct 2, 2007 | 01:13 PM
DF
Cars running good now, no SES, start ups are good, but i had a question. What is having it set to hot wire?
Old Oct 3, 2007 | 06:56 AM
NmexMAX's Avatar
dot dot dot ...
HW = MAF type airflow sensor vs pressure type.
MAF/Karman/Pressure + ECU
Old Oct 3, 2007 | 08:19 AM
95BLKMAX's Avatar
oh yea thats a big issue, cant run pressure sensor type for us mate, thats only if you had a MAP sensor. We have a MAF (AKA, Hotwire)
Old Oct 3, 2007 | 09:07 AM
gtr_rider's Avatar
192.168.1.1
Since when can you set "Hotwire" instead of "Pressure" in a VAFC. I havent seen that option listed anywhere.
Old Oct 3, 2007 | 09:35 AM
dfownz's Avatar
Ohh didn't realize vafc didn't have hotwire.
I do it through etc. > sensor type > hotwire > 1in 1out
DF
Old Oct 3, 2007 | 10:08 AM
gtr_rider's Avatar
192.168.1.1
theres no hotwire selection
etc. > sensor type > 4in 4out
Old Oct 3, 2007 | 10:17 AM
NmexMAX's Avatar
dot dot dot ...
Old Oct 3, 2007 | 12:28 PM
gtr_rider's Avatar
192.168.1.1
lol
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
