Sponsored by:
Sponsored by: CARiD
VQ35 swapped cold start issue
Old Oct 19, 2007 | 01:17 PM
goldtooth's Avatar
How do you guys blockoff the PF TB? Just JB weld everywhere in the holes? or is there a plate or something? In the morning when I start the car, I have to hold the gas for about 2 min, otherwise the car shuts off. any advice? I am about to go reroute the 4th gen IACV as close as possible to the manifold. Remote start is pointless...... cuz as soon as it starts it shuts off.
Old Oct 19, 2007 | 10:24 PM
95BLKMAX's Avatar
I dont understand what you're saying. Do you HAVE the IACV hooked up? If so, is it working? I used to have to do that holding the gas thing at first cus my TPS was off calibration. Yes you can make a plate to sandwish bet'n the bottom of the TB and the PF IACV. Aluminum sheet metal with silicone worked just fine for me.
Old Oct 19, 2007 | 11:39 PM
goldtooth's Avatar
Yes, I have the IACV hooked up, but is it working? I dunno What is the easiest way to check? right now the car is somewaht taken apart so I cant test anything ATM. Perhaps by the end of Saturday it should be put back together
so the PF TB doesnt have a fast idle cam like the 4th gen TB, If I install a 4th gen TB would that help with anything(with the cold start issue)?
Old Oct 19, 2007 | 11:43 PM
95BLKMAX's Avatar
you'd have to get another adapter for that SMALLER TB... Or why dont you just say F the IACV and just use the idle adjustment screw on the TB itself . Makes life alot less complicated
Old Oct 20, 2007 | 05:20 AM
matty's Avatar
LEAVE THE SET SCREW ON THE THROTTLE BODY ALONE !!!!
You have to make sure your TPS is adjusted properly as per the directions on the website. If its out of spec it will severely mess up cold starts. (I KNOW) I have mine set perfect after LOTS of messing with.
On the Pathy TB, you should have a block off place on the bottom of the TB, where the pathfinder IACV was removed. I filled in all those passages with JB weld as well, then just plated it off on the bottom.
All your adjustments should come from the TPS after warming up the car. I used to take a ride, get the car warm, then remove the tb fast, go inside and ajust the TPS to spec. .5 at idle and 4 at WOT (something like that, check the website)
-matt
Old Oct 20, 2007 | 05:22 AM
goldtooth's Avatar
iight, i REALLY want to figure this out as i want the remote start to function as it progressively gets colder
Im gunna go play with it right now
Old Oct 20, 2007 | 09:52 PM
95BLKMAX's Avatar
-matt
I stand corrected. I should have remembered that being down here in Miami.... I HARDLY deal with cold-start issues that may arise from adjusting idle via the TB idle screw, as that WILL affect the TPS's reading, since obviously the position is changing.
I made a block off plate from a $5 hand saw from homedepot. Cut it to shape, smoothed edges, drilled the holes, put silicone around the outside and sandwished it bet'n the bottom of the TB and the PF IACV. No leaks there for almost a year.
Old Oct 21, 2007 | 12:10 AM
KRRZ350's Avatar
Just out of curiousity, does anyone else have the following issue......
Occasiionally, and only after long highway drives, my IACV goes 'tick tock tick tock tick tock' No lie, it sounds just like a clock, and it speeds up when I rev the engine a little. Kinda bugged me out the very first time. On the occasions when it does do it, the idle gets a little rough as well. Just curious if anyone else has noticed this, since I fear replacing it might not remedy, not that I care much as I have bigger fish to fry right now.
Old Oct 21, 2007 | 12:25 AM
nismology's Avatar
^^ You sure your ECU screw isn't in the self-Diagnostic position?
Old Oct 24, 2007 | 12:42 PM
Xservice0183's Avatar
goldtooth, Let me to see your project!
Old Oct 24, 2007 | 01:21 PM
goldtooth's Avatar
okay ECU screw is all the way counter clockwise, the TPS seems to be set correctly because the SAFC readout tells me .5V throttle closed and 4V throttle open....what else to try?
I was thinking, what if I had two hoses running from the IACV to the intake manifold instead of one? Would that accomplish anything? I shortened the hoses leading to the IACV and from it, and it seems like the idle stabilizes a bit quicker.
Ummm what else,,,,,AFPR is set at 34 psi at idle and goes up to about 40-42 psi at WOT.....
Old Oct 25, 2007 | 11:26 AM
goldtooth's Avatar
ttt
Old Oct 25, 2007 | 05:30 PM
Nismo3112's Avatar
Custom User Title
Who's car did you buy?
Old Oct 25, 2007 | 07:03 PM
goldtooth's Avatar
XJinCT's, I dunno if this project is more ghetto or urs.....LAWLERS
Old Oct 25, 2007 | 07:05 PM
Nismo3112's Avatar
Custom User Title
Mine wasn't ghetto, and worked 100%. It started in cold too. And the trans was awesome.
Old Oct 25, 2007 | 07:12 PM
goldtooth's Avatar
I dunno it just reminded me of when you found the ebay chip in there....lol and the elaborate network framework out of duct tape..... lmao, im only joking of course, its jjust hilarious reading some of the stuff the other guys come up with on the other fourm. On the other hand, would You have any other ideas to help me out?
Old Oct 25, 2007 | 07:22 PM
Nismo3112's Avatar
Custom User Title
My bad. I thought you were referring to my VQ35 swapped Maxima. My current Maxima however, yes. You won't find anyone more ghetto than Boob/Biggs.
Old Oct 25, 2007 | 07:24 PM
Nismo3112's Avatar
Custom User Title
No. But post #5 is a good start.
Old Oct 25, 2007 | 07:31 PM
goldtooth's Avatar
already tried and no go..... :cry: , but I will quadruple check at this point
Old Oct 28, 2007 | 07:06 PM
goldtooth's Avatar
ttt
Old Oct 29, 2007 | 06:47 PM
THT's Avatar
THT
Throbbing member
I relocated my IACV so there's literally only 2" of hose separating the IACV from the barb I put in the IM (right by the brake booster barb) and now my car fires up in the cold without much issue (when it's 30F overnight, I still have to feather the throttle for a second or two).
Old Oct 29, 2007 | 07:27 PM
goldtooth's Avatar
Im having my dad make me a IACV plate with 2 nipples instead of one, hopefully, it will show some improvements.
02PearlSE
Oct 7, 2015 02:12 AM
bc992164
Aug 26, 2015 12:19 PM
FlaMark
Aug 21, 2015 11:06 AM
kirkhilles
Aug 8, 2015 10:53 AM
