Sponsored by:
Sponsored by: CARiD
VQ30DE-K swap for Dummies
Old Jun 4, 2009 | 07:42 PM
  #121
pmohr's Avatar
No more Maximas...
Originally Posted by DAVE Sz
They seem to be routed to where the fuel pressure sending unit is. I'm not worried about them as I didn't touch them. Just mentioned them as reference. Thanks...
None of these cars have a fuel pressure sending unit
The other wires in the rear injector subharness go to the CKPS REF and (IIRC) the OPS.
And yes/no on the red wire. It is a common wire for the injectors, but it's power, not ground.
Old Jun 5, 2009 | 05:01 PM
  #122
DAVE Sz's Avatar
Hooooooonda.....
my bad, I meant the oil pressure switch. As for the wires, wiring is still correct though, I just got my polarities mixed up, right?
Old Jun 5, 2009 | 07:50 PM
  #123
pmohr's Avatar
No more Maximas...
What do you mean? As far as the above mentioned colors being the ground wires for the injectors, and the big red one being B+?
Old Oct 23, 2009 | 12:38 AM
  #124
ford92racer's Avatar
dek help
im doing the dek swap in my 99 maxima and need to know if the wiring harness out of the 00-01 maxima will plug up to the 3 plugs under the dash and work everything rite or if i have to modify some stuff . thanks
Old Oct 23, 2009 | 03:26 PM
  #125
ajcool2's Avatar
Why are you using the 00-01 wiring harness?
Old Oct 24, 2009 | 11:08 AM
  #126
The Russian's Avatar
goodluck. ha.
Old Oct 29, 2009 | 02:37 AM
  #127
i changed my mind on tha 5th gen harness and ecu. i bought a msd rpm switch and a 5000 chip thanks for tha help
Old Mar 8, 2010 | 07:25 PM
  #128
Ceasars Chariot's Avatar
Old Maxima Legend
Hey guys, sorry about the condition of this thread. The Chariot sat for 2 years, and ended up sending it to a shop to finish the work. Family things just got more important than the car, but its all good now.
The new clutch is strong.
The new engine DE-K (31,000 Miles) runs very strong, beautiful sounding engine and exhaust. Pulls very hard uptop (switch over) past redline vs the old 170,000+ aged DE.
I forget about the differences in the two engines, but the DE-K sure feels better uptop than the DE ever did with 00VI.
Well, its good to be back, now for some easy miles on that clutch. And really need to sort out the cold start. Once she warms up everything is ok, but on cold start engine just dies over and over, same old thing with the old setup. Will need to do a search and find out how to fix that.
Thanks Everyone.
ceasar
Old Mar 10, 2010 | 06:05 AM
  #129
streetzlegend's Avatar
Thanks Everyone.
ceasar
Good to have you back man, I started to miss your video and race footage every few months lol.
Old Mar 10, 2010 | 09:51 PM
  #130
Old Maxima Legend
ha, thats is funny. no doubt i will be in some sort of drag battle soon..
Old Mar 18, 2010 | 07:53 PM
  #131
Jason R's Avatar
aka UNCDooD
nice! glad to hear the chariot is up and running! I sure miss mine.
Old Jan 24, 2011 | 10:21 AM
  #132
Old Maxima Legend
she stays parked up in a garage out back. I pull her out to keep putting miles on the clutch done over 500 miles now on the back roads..
edit: you just cant get on these cars with street tires and not lose traction. on the second run i push her and she needs the stickies.
Video with DE-K swapped and running
http://www.youtube.com/watch?v=-Y18mA3ChWY
Old Jul 11, 2011 | 09:20 PM
  #133
kajeno's Avatar
Originally Posted by DandyMax
Yeah the 4th gen used 2 complicated vacuum galleries bolted to the coolant log (unnecessary if you ask me.. ) The DEK doesn't, and its coolant log is different. If you compare them you'll see there's an extra water outlet coming off the valley at the back of the block on the DEK. You'll want to use the DEK coolant log, so the easiest thing to do is trash the 4th gen vacuum galleries and just run new hoses or metal hardlines of your own (some brake line tubing works great). In spite of all the complicated looks of the 4th gen galleries, there are only really 3 main devices those things connect, plus the FPR. They are the EVAP solenoid, the MAP/BARO solenoid, and the EGR solenoid. I just put them all together on a simple bracket coming off the new DEK log. These solenoids have 3 lines to each one, but since you're not using EGR, you can eliminate any hoses to that one, and just leave it connected somewhere (same with the EGR temp sensor) if you don't want CEL's, or if you don't care about that then just remove it. And also make sure you don't trash the little round check valve on the EVAP vacuum line. I can take some pics or provide a routing diagram for you later on for how to run all the vacuum/air stuff.
Dandy, how about some pictures showing what you did for the vacuum lines.
Old Jul 25, 2012 | 09:44 AM
  #134
MadManMax-M3's Avatar
I see no one has commented on this thread in a while but hopefully I can get a reply :-)
I am helping a buddy of mine who is considering doing this swap and we were debating whether it is better to use the 4th or 5th gen computer and harness when doing the swap. Could I hear for you all what you think...
Old Jul 28, 2012 | 06:50 AM
  #135
hornepirate's Avatar
Just use the stock harness and if he decides to use 5th injectors splice them in.
Old Sep 1, 2012 | 03:58 PM
  #136
MAXIMA_STYLE's Avatar
Domeone needs to make a newer thread anx take ALOT of pics..this thread is very informative but so many people getnoff topic and talk about unrelated stuff it gets confusing... easiest way is to do the swap take pics and do a complete writeup on everything that needs to be switched or wired etc and talk to a mod to lock it and sticky it
Old Oct 27, 2015 | 01:26 AM
  #137
Diesel_hunter's Avatar
well i have to deal with the transmission which is going to slow things down since i got to order (as for as I know) my clutch kit from the states, ive also got to get the flywheel machined. so it could be as long as two weeks. im not sure what to do about the input shaft bearing in the transmission, im pretty sure its a mess.
as soon as i get that sorted then we will just put the de-k in !
ACT-NM1-HDMM Clutch Kit
http://www.modacar.com/products/Nissan/Maxima/MODACLS/
can anyone recommend a reliable place online to buy this clutch ? these days im a bit out of the loop on where to buy our mods ??
Input shaft bearing and front cover are super simple sir, remove the front cover bolts and front cover, remove the snap ring holding the IS at the base, then smack that sucker right on the point with a hefty hammer and it will release from the trans, then remove the snap ring holding the bearing in, remove bearing, clean surfaces with emery cloth and reinstall in reverse order, dont forget the snap ring for the bearing
Old Nov 10, 2015 | 09:35 AM
  #138
maxima92se's Avatar
I think you are a little late there Diesel_hunter(Look at the date of the post for an explanation).
Old Dec 12, 2015 | 05:28 PM
  #139
mr 503's Avatar
I'm about to do a de-k from and infiniti i30. Will there be any difference with the swap? Most should be a direct fit I'm assuming. I just need a list of things my mechanic and I need to go over as fat as trouble shooting.. Any help would be appreciated. Thanks
Old Dec 12, 2015 | 05:31 PM
  #140
mr 503's Avatar
I know the injector clips and the exhaust
Cams. Everything
Else is stock. Do I need a vafc?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
