Sponsored by:
Sponsored by: CARiD
Keep popping coils, help
Old Dec 6, 2007 | 06:39 AM
1997 GA16DE's Avatar
Ok, this is getting expensive now. First off, I'm running standalone, 1-4, 2-5, and 3-6 are in pairs and fire with a wasted spark on an AEM EMS. The problem is if one coil dies, it takes out its partner.
The engine was running just fine. All of a sudden I'm running on 4 cylinders. the 3-6 pair died on me in a pop and then burning electrical smell, the result is a bulge in the side of each coil:
I figured it was 1 bad apple and I replaced both in the pair, ran the car just fine, once, then they both went again.
I need to know. WHAT CAUSES A COIL TO BLOW LIKE THAT? is it a bad spark plug or is it one of the 3 wires (positive, signal, ground)? Could it be the EMS?
I don't want to keep trial and error, used ones cost me $20ea plus shipping and new ones are $65-95. Double that, considering 2 go at once.
Old Dec 6, 2007 | 02:48 PM
bump
Old Dec 6, 2007 | 02:49 PM
NmexMAX's Avatar
dot dot dot ...
Post this thread in here:
http://forums.maxima.org/forumdispla...aysprune=&f=61
Old Dec 6, 2007 | 02:52 PM
good idea, could a mod plz move this?
Old Dec 6, 2007 | 03:18 PM
NmexMAX's Avatar
dot dot dot ...
PM a Moderator or Admin, they'll do it in a jiffy.
Old Dec 6, 2007 | 11:06 PM
bump
Old Dec 7, 2007 | 06:28 AM
NmexMAX's Avatar
dot dot dot ...
Delete this thread, and just post the thread in the AM section, Jesus.
Old Dec 7, 2007 | 07:00 AM
blkrx7's Avatar
I've seen this in DSM's when we try and use a regular coil over plug module, in waste spark setups. They overheat, sometimes shorting and sometimes going open. In either case, it could potentially cause damage to it's paired coil.
They're overheating because they're exceeding their duty cycle and weren't intended to work as waste spark.
Paul
Old Dec 7, 2007 | 10:58 AM
JeEvE's Avatar
A friends coils did exactly that on a 3.5 swapped car. It ended up being a bad ground in the engine harness for the coils.
Old Dec 7, 2007 | 12:18 PM
Thanks. I think I'm going to reground all 6 coils. And send a new signal to the 2 that are acting up. Also going to change 2 of the plugs just in case.
Old Dec 7, 2007 | 04:46 PM
Alright, the 2 that were giving me problems:
2 new plugs, 2 new grounds, 2 new signal wires from the ECU.
So far, no problems but only time will tell, I've started it up, run it outside, high, medium and low throttle, idled it for about 5-10 minutes, shut it down. Let it cool a little, started it up, revved it a little, let it idle, etc.
Old Dec 7, 2007 | 06:39 PM
irish44j's Avatar
retired moderator
moving to All Motor...
Old Dec 7, 2007 | 08:36 PM
DandyMax's Avatar
3.5 in the works
^^^^^ That could very well be the case...
But something else to consider, are you certain your setup parameters are correct in the AEM? I'm not that familiar with AEM as I am with a couple others but for example I'm talking about things like current output selection, and especially dwell time.
Old Dec 7, 2007 | 09:44 PM
Nea, the other coils have held just fine, it's just the coils on that 1 signal. Also, many are using this setup on the 350Z.
I'm thinking it was either a bad ground or something bad on the line, it's working so far., the other coils have been running for months now with no problems.
TallTom
57
Oct 14, 2025 05:16 PM
Mahmuth
Aug 16, 2024 08:23 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
zmcneely13
Sep 26, 2015 02:26 PM
