Sponsored by:
Sponsored by: CARiD
torx sizes for vq studs?
Old Dec 25, 2007 | 08:24 PM
BLACKonBLACK98's Avatar
Former Vendor
gonna buy a set of sockets and wondering what sizes i will encounter. right now i'm just working on the heads, but i will be building a complete engine.
Old Dec 25, 2007 | 09:13 PM
maxpeed96plat.'s Avatar
I would PM Nealoc, I believe he knows which ones you'll need. Good luck
Old Dec 26, 2007 | 04:40 AM
pmohr's Avatar
No more Maximas...
Are you installing head studs or just trying to take out the head bolts?
If the latter: http://forums.maxima.org/showpost.ph...5&postcount=29. Not torx, but hex.
Unless you're asking for everything (i.e. bottom end too), in which case the girdle bolts are http://forums.maxima.org/showpost.ph...37&postcount=1
Old Dec 26, 2007 | 08:52 AM
nismology's Avatar
I was off by one size. They are in fact E12.
Old Dec 26, 2007 | 11:20 AM
Former Vendor
that settles it, might as well get the big set.
Old Jan 1, 2008 | 10:08 AM
nismology's Avatar
Just removed the crank today, was E14......
Old Jan 1, 2008 | 08:12 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
http://www.thetoolwarehouse.net/shop/GRY-1598HC.html
I ended up buying this kit to remove the cylinder heads off of the block, as I could not find a 1/2" impact grade 10 mm hex socket by itself.
I kept breaking the normal 10 mm hex sockets trying to remove those head bolts. With these I used my impact gun set on low to break the head bolt loose, then I loosened them in steps following the FSM removal pattern.
The kit is expensive but these work great and I've used the other sizes on different projects.
For the torx bolts I bought the "better quality" 3/8" Torx kit from Autozone.
I've taken apart a couple VQs with these and have not had any problems or broken parts.
Old Jan 1, 2008 | 09:09 PM
joebangaa's Avatar
Mine are E8...
Old Jan 1, 2008 | 09:18 PM
nismology's Avatar
For the main cap bolts? Unpossibel.
Old Jan 9, 2008 | 07:31 PM
MDeezy's Avatar
e12(3/8") for me
got them from pepboys. $7 (3/8th though)
Old Jan 9, 2008 | 07:53 PM
nismology's Avatar
Was E14 for me. My 3.5 is out of an 05 though.
Old Jan 9, 2008 | 07:55 PM
MDeezy's Avatar
mine was from an 03. Dont have fast installed but cant imagine Nissan changing the bolt size in 05. even the E12 worked on the 3.0
d'oh well....
Old Jan 9, 2008 | 08:01 PM
nismology's Avatar
I just checked and A32 -> A33 -> A33B = same part #. 04 and up has a different one.
Old Jan 9, 2008 | 08:02 PM
MDeezy's Avatar
that would explain it then...
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
dcam0326
Sep 26, 2015 05:20 AM
