Sponsored by:
Sponsored by: CARiD
Weird MAP Sensor/ Engine Problems
Old Apr 22, 2008 | 04:12 PM
mastercater7's Avatar
VQ35 FTW
My car is a 3.5L 4th gen. It is all on 4th gen timing and ecu. The VI is not hooked up and is permanently set to high end. I moved my 75 shot over to the 3.5L and everything had been going good. The spark plugs always checked out good. Anyways, a week or two ago I was racing and I started spraying in 2nd. When I made the shift into 4th my car started making a loud whistle noise and I pulled over. When I put my hand under the intake, I was leaking fuel from the short ram piping. I come to find out my buddy who helped me install, drilled a hole in the coupler and decided to cover it up with a small strand of duct tape. Unfortunately he never told me this and the duct tape busted off. Im sure this caused everything to go out of whack on the car. The next day I bought a new coupler but the car runs like crap. It had 2 cels P1105 (MAP/BARO Solenoid Valve) and another for the MAP sensor. I went home and realized the MAP sensor (boost sensor) was missing completely. I pulled these parts off my other car and the codes went away, yet it still ran like ****. Yesterday I went and checked codes again and P1105 showed up again. I read the fsm over and over again and I am out of ideas. Someone please help me out here. I have NO idea what is going on with the car. I know this involves nitrous but I feel that this forum fits better, seeing as it is some kind of motor problem.
Zack
Old Apr 22, 2008 | 09:34 PM
VQ35 FTW
bump.....
Old Apr 23, 2008 | 06:11 AM
VQ35 FTW
I forgot to mention that the intake sounds like its not getting enough air. It screams loud and sounds terrible.
Old Apr 23, 2008 | 01:19 PM
XAugusta MoonX's Avatar
Do you have a MAF hooked up? Are you running an aftermarket ECU? Check the specs on the Boost Sensor, check your MAF, check for vacuum leaks, cause that's what it really sounds like.
Old Apr 23, 2008 | 05:58 PM
VQ35 FTW
Everything is hooked up, MAP, MAF, Vacuum lines, and I have the stock ECU
Old Apr 24, 2008 | 04:01 AM
KRRZ350's Avatar
You could have blown your maf during that intake backfire, a classic move from fuel puddling and is why your map sensor and duct-tape went flying. But check to make sure that you're not sucking in unmetered air from some were else, or any other vacuum leaks (Hint: pcv valve) Or that your fuel selenoid isn't sticking open or activating.
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
