Sponsored by:
Sponsored by: CARiD
5-spd auto into 4th gen??
Old May 6, 2008 | 10:38 AM
rxm6's Avatar
Question 5-spd auto into 4th gen??
Can it be done? With my 4spd on the way out it seems appropriate to put something better in there? I would probably take the tranny from a 6th gen and the tranny computer and I would most likely need an adapter plate no? Most important question is, will it fit? Also, do I need to get different axles?
And for the flamers, no I'm not going to swap a 3.5 in there because it will never pass CA **** emission laws. So if that is what you were going to say, no need
And for anyone else who is going to say to swap a 5-spd manny tranny in there, I don't need to hear that either.
Old May 6, 2008 | 10:52 AM
!PrjctMax!'s Avatar
Man, you're good on the last two paragraphs
Axles would be needed if you swapped out to a different transmission. Assuming that this would be the same case as a 6th gen swapping from a 5spd auto to a 6spd manual.
Old May 6, 2008 | 11:05 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=168625
http://forums.maxima.org/showthread.php?t=301536
http://forums.maxima.org/showthread.php?t=131717
Cliffs: It's been thought of, but never pursued. The main issues, IMO, would be software related. Considering all of the progress that Jime has been able to make recently re: software / electronically, it is very doable. tTe mechanical (hardware / fit issues) shouldn't be that extensive either.
Old May 6, 2008 | 04:04 PM
rxm6's Avatar
Ok, I'm going to noob-down for a second. I understand mechanics fairly well, but when it comes to auto ecu's my understanding gets a little foggy. In my mind there is a TCU (tranny) and an ECU and the TCU is telling the tranny what to do. So then, what does the TCU have to communicate with the ECU that it can't? Is it different programming? Why couldn't a 5-spd TCU communicate with our ECUs??
BTW: Those articles were very illuminating but seemed to be more of a chin scratcher than anything else.
Old May 6, 2008 | 08:41 PM
nismology's Avatar
5-speed TCM = A34 5AT ECU. Simple as that.
This is another option.
http://forums.maxima.org/showthread.php?t=547227
Old May 6, 2008 | 08:55 PM
Tatanko's Avatar
Bacon Lover
I thought Jime said the SupraStick was only capable of communicating with 4-speed autos (given that 5-speed autos are controlled differently)?
EDIT:
Originally Posted by Jime
As I stated earlier, this will not work on the 5spd auto as they use more than 2 shift solenoids.
Old May 7, 2008 | 06:13 AM
NmexMAX's Avatar
dot dot dot ...
I never said they couldn't. Maybe an A34 ECU would work.
It was only as little background on the subject. That is as far as we've gotten.
Old May 7, 2008 | 07:25 AM
nismology's Avatar
EDIT:
Well there ya go.
Old May 7, 2008 | 07:41 AM
rxm6's Avatar
Originally Posted by eng92
I was not aware that you could not drive an A33B in the state of California because of their "**** emission laws".
A full VQ35 swap (if done properly) will have no codes and will pass an emissions "sniffer" with no problems.
It doesn't matter whether or not it has no codes. The VQ35 never came in the A32 and it would be an illegal swap no matter how well it is done. Furthermore, A33's can do the swap because the VQ35 was CARB approved for the A33 and therefore, a legal upgrade.
Ok, another dumb question then, if the TCM=a34 5at ecu, could the a34 ecu be reflashed/reprogrammed with the a32 ratios and numbers for the 3.0L??
Old May 7, 2008 | 08:00 AM
eng92's Avatar
Your inspections must be a lot more comprehensive than ours. Without the engine cover on there, most people would not know how to identify what it was.
Also, from the various OBD-II scanners, I have used, neither the A32 or the A33B display any information which would give you up.
You want to match up an A34 ecu to the A32 motor???
If you cannot pass emissions with codes, then that will niot work.
Read up on Nissan's CAN system.
Old May 7, 2008 | 08:25 AM
MorpheusZero's Avatar
Yes, they actually put fluid down the intake tract, turn the crank 720*, catch the fluid out the exhaust and then measure the total displacement of your engine
If it's not exactly 2988cc then you're FAWKED
I think he just does not want to deal with hiding that it's a 3.5, etc
Old May 7, 2008 | 02:37 PM
mowgli29's Avatar
Horizontally opposed.
lmao
What would make this worth going thru so much trouble? Why not just get a replacement 4AT and call it a day?
Old May 7, 2008 | 03:05 PM
NmexMAX's Avatar
dot dot dot ...
Aside from this, I don't know. http://forums.maxima.org/showthread.php?t=140957
The OP has a small perspective. There are many other easier options.
Old May 7, 2008 | 03:14 PM
Tatanko's Avatar
Bacon Lover
Exactly. Open-diff. ones are plentiful and cheap
Old May 7, 2008 | 05:18 PM
rxm6's Avatar
*Sigh* This is the usual for every forum I post an idea in. 1 or 2 constructive responses and the rest are over opinionated and under educated responses.
1.) For those of your saying its legal in California to swap a 3.5 in than read these.
This is a quick run-down of federal regulations: http://www.epa.gov/compliance/resour.../engswitch.pdf
This is a quick run-down on California regulations: http://www.bar.ca.gov/80_BARResource...ns_Part_2.html
Notice the last item in "Can I change the engine in my vehicle?" about USEPA? The short answer for a 3.5 in an A32 is no, it has not.
2.) I clearly stated in my post that I didn't need to hear about 3.5's or manual transmissions, but a few of you apparently have some difficulty with reading comprehension and that's OK, it clearly can't be avoided. I myself am guilty of not thoroughly reading posts.
3.) What could have have been a technical discussion on the difficulty/implausibility/capability of performing this swap has turned into a thread akin to something you might find on a 240sx forum.
4.) i30t, locking-diff, VLSD, neither plentiful or cheap
Old May 7, 2008 | 07:51 PM
grey99max's Avatar
LandShark has Cosworth
Checking car-part.com, I find a boat-load of 95-99 RE4F04V VLSD trannys. Price range is $350-$1,000+, with one showing 12K miles for $1,000. There's one in Kentucky with 42K for $650. There are also '01 AE VLSD trannys available. I have one in my garage for a spare when my sprayed 3.5 blows the '99 VLSD I have right now... Some 2002 Altimas show having a VLSD occasionally.
IMHO, this upgrade is do-able, compared to the massive problems of installing a 5-spd auto. IMHO....
Old May 7, 2008 | 07:56 PM
mowgli29's Avatar
I wasn't meaning to get off topic or bash your idea...it just seemed to me that the whole "difficulty/implausibility/capability of performing this swap" wasn't looking good. That made me wonder..."if it's not gonna be easy at all, what's he wanting to do it for? There must be some sort of decent benefit..." Therefore, I asked. I know curiosity killed the cat, but I didn't think it would kill the thread...
Old May 7, 2008 | 08:10 PM
Tatanko's Avatar
Bacon Lover
They are indeed not too difficult to find. Also, who says you HAVE to put a VLSD tranny back in? It's not like it's really going to hurt the resale value (like anyone would care that isn't an I30 fanatic) and you live in Cali so it's not like you'd have the benefit of it for snow or something. Throw an open-diff. one in for cheap and call it a day.
We've already explained to you it's not really plausible or cheap (way more expensive than even a locking-diff. 4-speed) to put the 5-speed in. Don't go bashing us because your idea didn't turn out to be a realistic one. If you have such a problem with this forum then leave. No one is going to cry about losing you.
Old May 7, 2008 | 10:18 PM
made in china's Avatar
I think if you completely swapped the 3.5 drivetrain into your car wholly, i.e. no adapters, no hacks, just a total 5.5 Gen conversion, you'd be OK in CA. The only codes my car throws (full conversion) are 2 CAN codes related to not being able to talk to the ABS system, which the ECU uses for TCS.
I read deeper into those rules, and they had an example of gas to diesel conversion and mentioned it would be OK to do IF you swapped ALL the parts from a like diesel version into the gas version.
I think they just don't want you to go backwards or half-butt with adapters and shortcuts. Anyway, CA is not my cup of tea, and I may be wrong but I have heard that a full update to a car (like a full 2004 drivetrain in a 1997 car) is allowed, they just prefer to avoid mentioning it as they would prefer you don't modify your car at all.
As for the 5AT: The TCM from the 5AT donor would be incompatible with the TCM in your A32/33. Most of the 5AT Nissan's have full CAN, and they need to communicate via CAN. In your sig, it appears you have an A32, which uses analog data for the TCM/ECU interface. So, no, it won't work with your A32 ECU, and as you know using an A34 ECU in a A32 chassis would definitely violately your CA emission rules. Besides, an A34 ECU likely would refuse to operate in a car without FULL CAN AND NATS system.
Another prob is that the 5AT likely has different mounting point for the trans mount, as the Altima and A34 are totally different from the A32/33. While the A32/33 are close brothers, I would not be surprised that the A34 drivetrain mounts are not compatible with the A32/33 chassis.
And then the driveaxles,
And then.....
Old May 8, 2008 | 12:54 AM
rxm6's Avatar
And then.....
Thank you.
And CA is not my cup of tea either, I've been reading the vehicle code extensively this evening and it contradicts and turns on itself at every turn making it really difficult to get a straight answer.
Old May 8, 2008 | 05:11 AM
goldtooth's Avatar
Sorry to stray off topic, but after the full 3.5 swap, for emission testing, they do the gas cap test and the OBD-II test for any CELs in IL as far as I'm concerned. Will my title be changed to like "hot rod" because of the new computer showing a new updated model and vin? Or would they not notice that?
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
