Sponsored by:
Sponsored by: CARiD
3.5 finally runs- Now a coolant leak
Old Jun 15, 2008 | 10:13 AM
wagesgt903's Avatar
So i fixed the air gap on the cps and it fired right up finally. Now ive got a coolant leak from where the inner timing cover meets the lower oil pan. I think it was to cold outside when i put the rtv on. Has anyone ever tried pulling the timing cover in the vehicle or had this problem? Should I just go ahead and pull the motor?
Old Jun 15, 2008 | 10:26 AM
95BLKMAX's Avatar
pulling the timing covers with the engine in the car is possible, but its a bia...
Did you change the water pump when you swap'd? because when water pumps go bad, what you're describing is exactly the sign- leaking bet'n block and timing cover. Its designed to do it like that.
To change it, you do not have to remove the timing covers, just the 2 cover plates for the timing chain tensioner (that has to come off), and the water pump. Not much room to work around in order for the pump to come out/ new one in, but it IS possible. Just have to turn it and twist you hand in some weird ways, but it works, lol.
Old Jun 15, 2008 | 02:12 PM
pmohr's Avatar
No more Maximas...
That's really the only place coolant should come into contact with the timing covers...at the water pump area. Most likely it's a damaged o-ring on the water pump, or just a bad pump.
Old Jun 15, 2008 | 10:16 PM
95BLKMAX's Avatar
indeed. my pump gave out a year and a few months after the swap. I made the cheap-o mistake of re-using the stock pump when for $45 from Autozone I could have just put in the new one from then, but n000000.... Took it out with nismology's help, one of the o-rings on it was flacking and stiff as a rock. I didnt bother prying it off the pump, it just broke into pieces
Old Jun 16, 2008 | 04:59 AM
wagesgt903's Avatar
If its just that ill just lift the motor out to do it. I work at a shop but i had to do the entire swap until now in my garage at home so pulling it in my bay at work will be no problem. I just hope thats it i dont want to have to pull and clean the covers again, I cant wait to drive it.
I didnt realize how damn good it would sound!
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
homeofbacon
Sep 23, 2015 07:17 PM
pears
Sep 18, 2015 05:25 AM
Hdnseek
Sep 9, 2015 05:55 AM
