hard starting "IS IT THE CAMS"
I have few problem the last couple of months my car is hard starting, hesitating during start up, it sometimes takes me 2 tries or 6 tries due to this its killing my start quick, I did a full tune up...not to sure what to do next if I need more time on the dyno or a heavy duty starter since I have the JWT CAMS WITH ECU TUNED....DOES ANYONE HAVE ANY RESULTS...
Go to walmart get a fuel pressure and compression tester use them and the return them...
Back on topic, key the ignition on a couple times to prime the fuel pump before you actually crank it over. If it fires right up you may have a fuel pump getting weak on you.
Lol the CAMS didnt set me back, I got the CAMS from JWT by the way if I could remember I got them from $1100
You have all these mods and not a VI... wow that thing must b a torq monster. Check fuel pressure, spark, and compression. These are the main things that make your car start. Go to walmart get a fuel pressure and compression tester use them and the return them... I think autozone sells something to check your spark. I think a multimeter would work though. Also check your injectors to see if there okay. Alot of this can be eliminated by trouble codes. But i think since you replaced the cams maybe a gasket got broken which is causing a compression leak maybe??
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
trungg86
Sep 4, 2015 04:58 AM
