Sponsored by:
Sponsored by: CARiD
UTEC is in..........
Old Oct 19, 2008 | 07:43 PM
  #41
Deckdout2's Avatar
Play with my balls
Good luck bud! A group of locals are going to the dyno and 1/8 within the next 2 weeks. I have yet to tune mine at all. I'm not even running the base Z map, just stock setup from the ecu. I will have a baseline soon, and then I will tune, and run it again. Hope you get some good numbers from the tune, cause that hopefully will mean I will as well.
Old Oct 20, 2008 | 11:26 AM
  #42
SurraTT's Avatar
HR Swap Pioneer
yoooooooooooooooooooooooooooooooooooooooo
i got a few pics...
and on that time note, it was a ***** to do, took ~6-8 hours of total work, but i did it oer a week...
the hardest part is breakin ya neck installing it in the car..
utec is def the best route for 5.5+ max ill get one!!! after i find some $$$$
Old Oct 21, 2008 | 08:00 AM
  #43
VqMoNsTeR's Avatar
y does the second pic look like ur not using all of the ecu pinouts? does the utec only have to see certain pins?
Old Oct 21, 2008 | 10:03 AM
  #44
Deckdout2's Avatar
Play with my balls
That's correct. You don't have to use every single pinout. Just the ones for what you need to control. Actually, we used the EU also as a guide as to what needs to be used.
Old Oct 21, 2008 | 12:57 PM
  #45
VqMoNsTeR's Avatar
could u let me know how many and which pins need to be used? and the rest u just taped?
Old Oct 21, 2008 | 08:34 PM
  #46
Deckdout2's Avatar
Play with my balls
I'll ask Darren (SurraTT) to chime in since he's the one that did it for me.
Old Oct 22, 2008 | 10:21 AM
  #47
SurraTT's Avatar
HR Swap Pioneer
going from memory here
injector 1 2 3 4 5 6
ignition signal 1 2 3 4 5 6
ecm ground
power for ecm
maf sensor
knock sensor
tps sensor
crank sensor
mabey other, but i think thats the basics
Old Oct 22, 2008 | 10:22 AM
  #48
SurraTT's Avatar
HR Swap Pioneer
and i grouped the wires together
like injectors were red,
ign coils were green
others were diff color
Old Oct 22, 2008 | 11:06 AM
  #49
VqMoNsTeR's Avatar
any quick links to the 350z fsm you used?
Old Oct 22, 2008 | 01:05 PM
  #50
SurraTT's Avatar
HR Swap Pioneer
http://i173.photobucket.com/albums/w...pinoutcopy.gif
Old Oct 22, 2008 | 03:29 PM
  #51
VqMoNsTeR's Avatar
good lookin, thanks for the help!
Old Oct 22, 2008 | 07:29 PM
  #52
VqMoNsTeR's Avatar
ecm ground
power for ecm
maf sensor
knock sensor
tps sensor
crank sensor
cam sensor? i read that it adjust cam timing by the coils. but does it need to see the cam sensor?
Old Nov 4, 2008 | 11:21 AM
  #53
VQpwrdSpeC's Avatar
This is awesome I will be looking in the near future to do this with my sentra
Old Apr 14, 2009 | 01:15 PM
  #54
hot_wax_tree's Avatar
Am I missing anything here? Can I yield higher power with anything else?
you were prob being faceshis but you could bore it out.
Jake
Old Oct 13, 2013 | 08:27 AM
  #55
Blue Coupe's Avatar
Thumbs up
Great thread!
This is the best Tech I can find for UTECH for a 5.5 generation Maximas.
Time to revive this thread!
I bought a 350z UTECH that I plan to use this thread's tech to convert it to an '03 6spd Maxima connectors.
Any tips further on the Pinouts or should I consider the above as complete.
Does anyone have a UTECH All motor MAP for an '02/'03 Maxima to share? I see there are some challenges making the base 350z map to work out of the box.
Thanks!
Old Oct 14, 2013 | 07:35 PM
  #56
SurraTT's Avatar
HR Swap Pioneer
Originally Posted by Blue Coupe
Great thread!
Thanks!
I make a utec plug and play harness for 02 03 maxima.
visit my website.
Old Nov 8, 2013 | 01:51 PM
  #57
MrEous's Avatar
^ Jeff™
Great thread!
Thanks!
It's UTEC...no H
Check the 4" intake thread. http://forums.maxima.org/all-motor/6...2-08-vq35.html
I've got maps
Old Nov 10, 2013 | 10:03 PM
  #58
Blue Coupe's Avatar
Surra, pm me a price on the harness 03 Max 6spd.
MrEous, I added the "h" for high power!
Thanks for the link to your MAPs, I see I would have to swap injectors to get in the ball park.
I read there were issues running Utec on 03 Maxima's when cold, was this ever sorted out?
Old Nov 11, 2013 | 03:28 PM
  #59
SurraTT's Avatar
HR Swap Pioneer
pm sent
Cotozic
Jun 28, 2017 08:01 PM
MaxInfamy
Forced Induction
Aug 24, 2015 12:01 PM
SurraTT
277
May 24, 2013 06:30 AM
Gemner
43
Feb 5, 2011 12:26 PM
sparks03max
Mar 20, 2009 12:04 PM
