Sponsored by:
Sponsored by: CARiD
3.5 Swap midrange LOSS!!
Old Sep 18, 2008 | 05:27 AM
  #81
pmohr's Avatar
No more Maximas...
Originally Posted by ghostmax301
yea, i think i actually broke the gear.. was going through the gears, didnt even go to 3rd hard, as soon as it got in, i heard a crack and pop and the rpms shot up.. took it out of 3rd, put it back in..Car acted as if it was in neutral.
Ill look around for you, i think i might
Glass trans FTL.
Old Sep 18, 2008 | 05:38 AM
  #82
chillin014's Avatar
dang bad luck
Old Sep 19, 2008 | 06:37 PM
  #83
ghostmax301's Avatar
yea...might just put nitrous on it and act like i never had a midrange loss.. LMAO j/p
pulling out tranny tomorrow morning..update coming soon
Old Sep 19, 2008 | 06:49 PM
  #84
ajcool2's Avatar
Interesting....
Old Sep 19, 2008 | 07:00 PM
  #85
nooo.. YOU'RE interesting Mister!!!! i saw what you did there! a-he-ahehe
Old Sep 21, 2008 | 10:36 PM
  #86
CMax03's Avatar
Either your pump isn't able to keep up with the volume or you have a defective AFPR. By the way where is your vacuum source coming from?
Old Sep 22, 2008 | 10:54 AM
  #87
vacuum is coming from manifold.. what should a defective afpr do under load...im going to get a external fuel psi gauge to watch it while in motion
Old Sep 22, 2008 | 12:51 PM
  #88
t6378tp's Avatar
Turbo 3.5
as your vac decreases the fuel psi should increase
Old Sep 22, 2008 | 02:30 PM
  #89
ok..that's happening when I rev it in neutral so I expect it to do the same under load...guess its not the afpr
*sigh*
maybe it is exhaust leak, flexpipe is busted and I believe its leaking between the manifold and ypipe
Old Oct 23, 2008 | 02:50 PM
  #90
UPDATE!
got the car back on the road and still suffer from the loss.
I've recently changed 6 of the coilpacks for another set.
Knock sensor & knock sensor harness.all 6 injectors to 290cc DE-K injectors and no new codes.
but I ask this. What are some ways to check a coilpack that's on the way out? With the IGN on and engine off, they all show the same reading with the ohm meter but still worried that 1 might be slightly failing
Old Oct 23, 2008 | 03:22 PM
  #91
93altima's Avatar
Turbo 4th Gen
my car had the same prob and it was the rear middle coil pack i forgot how to check it but from what iam reading iam strongly leaning towards 1 out of the 6 coilpacks
Old Oct 23, 2008 | 09:04 PM
  #92
accordingtou's Avatar
VQ30 DE T
Do you have a cat on there?( may be clogged)
Check your plugs gap & for signs of fouling or detination.
Man I would disconnect one coil @ a time to see if there is a significant change in performance during idle & under load.
I dont know how old the fuel filter is but I would replace/ bypass that too.
Old Oct 23, 2008 | 10:12 PM
  #93
93altima's Avatar
Turbo 4th Gen
^^listen to the master mechanic disconnect the cat (run open y pipe) get a 95 300zx Fuel Filter get some NGK Iridium IX plugs (or some v-power ones for the time being gap them properly please) and get one rear coil and try it on each cylinder until you find the bad coil
Old Oct 24, 2008 | 07:08 AM
  #94
ill try swap a rear coil at a time. I already have new vpower plugs,gutted cat and 300zx fuel filter.
I believe when I checked the coilpacks though, they all came in between 1.4-1.7ohms but ill check again
Old Oct 24, 2008 | 08:23 AM
  #95
VqMoNsTeR's Avatar
get a tune for god sake. ur running bigger injectors, bigger pump and no tune ftl...
Old Oct 24, 2008 | 09:58 AM
  #96
ajcool2's Avatar
^^IBagreeingwithhim
Old Oct 24, 2008 | 11:10 AM
  #97
VQ30 DE T
I sooo thought he had some sort of "tuning" device
3.5 swaps with stock pumps run pig rich....
This thing is seeing low 11's/ high 10's... And I aint talking about 1/4miles.lol
Old Oct 25, 2008 | 07:06 AM
  #98
chillin014's Avatar
Mine was in the 11's and 12's. I was hoping it'd be lower so I could see more of a gain since supposedly some n/a guys RUN theirs in the 12's. What irritates me is that you have to get a dyno tune to really find out what the motor wants to run at..so I could very well have negligible gains after tuning my A/F to 13.5 from high 11's and 12's.
Actually I take that back here is my original log
but it didnt cause anything like what the OP is experiencing.
Old Oct 25, 2008 | 10:04 AM
  #99
VqMoNsTeR's Avatar
he has an afc but not a dyno tune..
Old Oct 25, 2008 | 12:14 PM
  #100
VQ30 DE T
A dynotune will allow you to see what afr your setu likes...
high 12's low 13's is good for a N/A car.
He doesnt need a dyno tune. All he needs is a wideband & some open road.
3rd gear
Partial throttle from 2krpm till redline
4th gear
Wot from 2kish 40mph ish to red line
Otherwise dont post a thred with little to no info on the "setup" & expect a miracle to happen....
Old Oct 25, 2008 | 12:34 PM
  #101
VqMoNsTeR's Avatar
dyno tuning is safe compared to running on the street and trying to read ur afr's and watch the road at the same time. but at the same time you will not get the same afr's on the dyno as u will on the street. the car will run a tad bit leaner on the street. this thread goes ftl, the 4th gen 5.5 swap/run ratio is crap..
Old Oct 25, 2008 | 12:57 PM
  #102
VQ30 DE T
Agreed.
Street tuning by yourself without a dataloger is hard.This is why you bring someone along to make the corrections while you drive.
Me & a local member have swaps that run strong(right)
I def understand why sooo many 3.5 swaps are crap.
Its nowhere near plug & play
Old Oct 25, 2008 | 02:50 PM
  #103
VqMoNsTeR's Avatar
this guy ran faster before the swap lol and im no where near a fan of the 3.0's
Old Oct 28, 2008 | 09:28 PM
  #104
Well, I unplugged the CPS(REF) sensor today and the car ran WAAAAAAYYYYYY better!
from anywhere in 1st gear, it spun the 20"s over with NO problem.
I have a afpr and 255lph pump and DEK injectors but no afc anymore. Currently unemployed so Dyno will have to hold off for a little.
Im not getting a code for the CPS, but still trying to figure out why it runs sooo much better unplugged. Grapped 2 good sensors today from the junkyard and theyre showing 520ohms. Im going to check the sensor on the car and the harness tomorrow to see if anythings wrong.
Pmohr had told me it might not throw a code but will send the wrong signals to the ECU so, we'll see.
Hopefully its not ignition timing related.
But as stated, the car feel as good now as it did when i 1st got it.
now(ssim, 290cc injectos,afpr,255lph,stock ecu,20"s,2-12" subs)
1st runs(JWT ecu,stock wheels, no subs or any of the above mods)
Old Dec 26, 2008 | 05:13 AM
  #105
NameGoesHere
Is the car still running with the cps ref unplugged?
Have you resolved the issue?
Old Dec 26, 2008 | 05:58 AM
  #106
maxboy325's Avatar
^^^ Still unplugged I believe. Car ran 13.5 1/4 at Imp. vs Dom. see 1/4 mile section or DC forum
Old Dec 29, 2008 | 01:58 AM
  #107
yep, still running with it unplugged...takes a few trys to start it but ill deal with it for now.
I still haven't tried another crank pulley yet to see if that was the problem though
Old Dec 29, 2008 | 03:53 AM
  #108
NameGoesHere
Thanks for the quick responses. Dont forget to update us when you have a chance to check the pulley!
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
