Sponsored by:
Sponsored by: CARiD
Auto 1st gear holding me back. Anything I can do?
Old Sep 16, 2008 | 06:41 AM
TDotMax's Avatar
Ok so my auto 1st gear is killing. After my swap and Greddy EU install my redline is now 7500. My first gear goes to early when pushed (6000). Is there any way or mod I can to hold it longer as it drops my rpm's too low for 2nd gear to kick nicely. I'm not looking for anything that great as I hope on doing a 5-speed next year.
Thanks,
Old Sep 16, 2008 | 07:09 AM
aznprid972's Avatar
I thought even if you extend your rev limiter, you would have to manually shift the auto in order to take advantage of the higher redline.
Old Sep 16, 2008 | 07:31 AM
pmohr's Avatar
No more Maximas...
This is where an RPM-switch automated shift_fast (or the new SupraStick bandwagon) comes very handy.
Old Sep 16, 2008 | 07:50 AM
Kevlo911's Avatar
Kevlo for President
Why not manually shift? That's what I did to use my 7200rev limit back when I was auto
Old Sep 16, 2008 | 08:00 AM
grey99max's Avatar
LandShark has Cosworth
^ ^ ^ he's got it nailed - but, if you want to experiment a bit. first do the DR-mod ( open one wire on the big resistor on the driver's shock tower) then pull the shift lever back to first gear and wind out your motor close to 7500 and click the shift lever up to 2nd gear.
If you like what you feel, then a different shifter is needed. Your stock TCU (transmission computer) is presently shifting at stock RPMs. Sounds like your motor is pretty healthy, so trying the manual 1-2 shift should be exciting...
Old Sep 16, 2008 | 08:09 AM
TDotMax's Avatar
Does any one have more info on the Shift_fast mod? I've read a bit but a lot of links are dead.
Also I was just concerned about about reliability with manually shifting. (FYI I have a VB and tranny cooler)
Old Sep 16, 2008 | 12:37 PM
grey99max's Avatar
Maybe you should look down below, through the rest of this thread... start here:
http://forums.maxima.org/all-motor/5...utomatics.html
Old Sep 16, 2008 | 01:10 PM
MorpheusZero's Avatar
Why not just keep the shifter in Low/first?
Old Sep 16, 2008 | 01:36 PM
Kevlo911's Avatar
Kevlo for President
Nothin wrong with manually UP-shifting. When you force downshifts, that's what hurts the tranny
Old Sep 16, 2008 | 01:44 PM
aznprid972's Avatar
It sucks when you let it bounce off the rev. limiter; especially at 7200-7500.
Old Sep 16, 2008 | 05:41 PM
TDotMax's Avatar
Not looking to spend that much. Might look into the Shift_Fast for now as I'm not sure if I'll be able to do the tranny swap next year.
Old Sep 18, 2008 | 10:18 AM
TDotMax's Avatar
For Auto's, Do I stay on the gas when shifting or do release until the shift is complete?
Old Sep 18, 2008 | 10:21 AM
pmohr's Avatar
No more Maximas...
Stay on the gas, no need to lift.
Old Oct 3, 2008 | 10:41 PM
FlipCpt45's Avatar
Isn't the "BANG" into gear kinda bad for the trans when manually shifting to another gear.. ex 1st to 2nd @ stock 6600 rev limiter?
James92SE
142
Jan 2, 2024 09:23 AM
sctludwig
Sep 1, 2022 01:32 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
pjgreek
Sep 9, 2015 09:30 PM
dcardello
Sep 3, 2015 11:44 PM
