Sponsored by:
Sponsored by: CARiD
VQ35 Swap Progress Thread
Old Sep 22, 2008 | 09:17 AM
  #41
nismology's Avatar
Originally Posted by cardana24
good progress. Make sure you are careful with your brake lines. You may want to take your calipers off or prop your rotors up....just a suggestion, it really looks like they are being pulled on.
The simple and proper solution (as far as the line is concerned) would be to pop off the clip that secures the line to the strut. I though everyone did that...
Old Sep 22, 2008 | 01:23 PM
  #42
ajcool2's Avatar
The pics of the tb on the car are hard to make out but the other ones help. I do remember seeing that gold peice your using to turn the tps on the 4th gen tb but i think i have to shave some peices off of it to make it work. I never thought about mounting it sideways also I'll try it and see how it works. Hopefully someone will begin making these plates to make it easier for future swappers.
Old Sep 22, 2008 | 01:44 PM
  #43
t6378tp's Avatar
Turbo 3.5
I'll try to take some better pic's of the tb in the car and replace the other ones
the only thing you have to do to that peice is dremel out the center alittle so it fits on the shaft of the 3.5 tb
Old Sep 22, 2008 | 02:16 PM
  #44
ajcool2's Avatar
Cool. Then just mount the tps so that they touch right?
Old Sep 22, 2008 | 02:40 PM
  #45
ghostmax301's Avatar
for my tb, I had a pftb and a 3.5 gasket. lined them up so the openings matched then redrilled new wholes so it'll bolt right up to the 3.5 elbow...goes on perfectly like it was made for it
Old Sep 22, 2008 | 02:44 PM
  #46
ajcool2's Avatar
If I could find one for a good price I would definatly go that route.
Old Sep 22, 2008 | 03:39 PM
  #47
t6378tp's Avatar
Turbo 3.5
if you find another let me know, I want my cruise control back
btw I updated the pics hope these are better
Old Sep 23, 2008 | 05:48 PM
  #48
pmohr's Avatar
No more Maximas...
Naw I meant I'll let you convert it for me.
Those things are a PITA to do, and I've never done one before.
That was more of a small reminder that you still owe me for the TB.
Old Sep 23, 2008 | 06:11 PM
  #49
ajcool2's Avatar
Oh ok. I gotcha.
Old Sep 23, 2008 | 06:35 PM
  #50
ajcool2's Avatar
Well guys I'm at that point where it seems like its going to be forever for this to be done. I was kinda hoping to have it done for the big meet on saturday but I dont think it will happen so I'm going to slow down a bit. I broke a scew inside one of the cam guides and couldnt get it out yesterday so I'm about to go around there now to try again. I think its supposed to rain thursday friday and saturday so I might use tomorrow to get my test pipes and exhaust on my Z and replace the axles on my max. I'll take some pics of the broken screw and messed up drilling.
Old Sep 23, 2008 | 06:41 PM
  #51
maximariceboi's Avatar
great progress bro...but damn...gl
Old Sep 23, 2008 | 06:43 PM
  #52
95BLKMAX's Avatar
A rigged stock 3.5 TB for cable is te worse thing I did during my swap. I hated that thing. I hit a bump, the TPS would jump and car would bog around. Make it easier on yourself. PFTB+ stephenmax adapter plates. Bolt it on and go. Its even MORE $ going into it, but its def money well spent
Old Sep 23, 2008 | 07:30 PM
  #53
maxsapphire's Avatar
Here is the broken screw.
Old Sep 23, 2008 | 08:15 PM
  #54
t6378tp's Avatar
Turbo 3.5
that ^ sucks
but on a side note does anyone remember which year patherfinder tb is the correct one
Old Sep 23, 2008 | 08:48 PM
  #55
i2vicious2's Avatar
SCAMMER DO NOT BUY FROM FOR NOW
how'd that happen?
Old Sep 23, 2008 | 09:08 PM
  #56
ahhh, forget it, i got like 2 missing screws that hold my inner timing cover to the block.lol
i think for the TB its 01 and up 3.5 motor
Old Sep 23, 2008 | 09:11 PM
  #57
nismology's Avatar
01 and 02 pathfinder. 00 was still the VG and 03+ was DBW.
Old Sep 24, 2008 | 04:26 PM
  #58
t6378tp's Avatar
Turbo 3.5
thats not a good habit to have
Old Sep 24, 2008 | 06:21 PM
  #59
i know but,hey.. i have LITERALLY replaced every moving part on my car.. ask the DC area lol
Old Sep 24, 2008 | 06:27 PM
  #60
ajcool2's Avatar
Ok not sure if this a problem but the gold links on the chain do not line up with the dot on the rear intake cam. You can see in the pic that the gear is on the cam adapter and the dot is on the lower right of the gear.
Old Sep 24, 2008 | 06:39 PM
  #61
ajcool2's Avatar
The other side lined up perfectly.
Old Sep 24, 2008 | 07:56 PM
  #62
ajcool2's Avatar
Bump for some help.
Old Sep 24, 2008 | 08:38 PM
  #63
ok, the side that doesnt line up.. itll be a little off, just MAKE SURE the dots on the sprockets line of up with the gold links on the chain. to do this, you might have to rotate the exhaust or intake cam A LITTLE BIT. once it goes on, put the bolt in the exhaust sprocket and take the pin out the chain tensioner. when it comes time to set ignition timing, youll have to turn that bank A LITTLE bit to get everything to line up.
let me know if it something you dont understand about it
Old Sep 28, 2008 | 02:57 AM
  #64
ajcool2's Avatar
Its been raining since thursday so I havent had a chance to do anything more with the swap but I'll this once we get started again.
Old Oct 8, 2008 | 12:16 PM
  #65
t6378tp's Avatar
Turbo 3.5
any updates, oh I installed the pftb so if you still want the tb brackets it's yours
Old Oct 8, 2008 | 12:40 PM
  #66
ajcool2's Avatar
Well I got the gears on the other side but I'm not sure its correct. It looks like the pic below but upside down. Is that right?
Old Oct 8, 2008 | 12:42 PM
  #67
ajcool2's Avatar
I'll definalty take that bracket thanks. I need something until I can find a pftb. Where did you end up getting yours from?
Old Oct 8, 2008 | 01:17 PM
  #68
alicious's Avatar
the org...not what it was
keeping watch in this thread AJ
Old Oct 8, 2008 | 01:32 PM
  #69
ajcool2's Avatar
Hopefully It runs once its all together.
Old Oct 8, 2008 | 02:25 PM
  #70
Grand_hustle17's Avatar
i sure hope it do
Old Oct 8, 2008 | 08:03 PM
  #71
t6378tp's Avatar
Turbo 3.5
got the pftb from ebay 141shipped and the adapter from stepnmax
Old Oct 10, 2008 | 12:08 PM
  #72
ajcool2's Avatar
ok i'll keep a lookout.
Old Oct 11, 2008 | 01:08 PM
  #73
ajcool2's Avatar
OK so were out working on it again today. Just torqued the cam bolts to 85 ft/lb and maxsapphire is installing the valve covers. I'm about to attempt to install the secondary chain.
Old Oct 11, 2008 | 01:13 PM
  #74
ajcool2's Avatar
Old Oct 11, 2008 | 03:26 PM
  #75
t6378tp's Avatar
Turbo 3.5
looks fine to me just make sure to post a pic when you intall the main timing chain
and are you going to get the bolt out
oh and my paypal is inzom@yahoo.com
Old Oct 11, 2008 | 04:16 PM
  #76
ajcool2's Avatar
How would I get it out? I was going to leave it there. I sent the money. Thanks again.
Old Oct 11, 2008 | 04:17 PM
  #77
ajcool2's Avatar
Its dark now and i left my flash light at my house so these may be the last pic.
Ignore how the chain is aligned I fixed that already. The yellow link ended up near the crank sprocket.
Old Oct 11, 2008 | 04:49 PM
  #78
ajcool2's Avatar
OK so I was reading over the instructions and realized that the engine is NOT at TDC as you can see from the pic above. Is it possible to turn it so that it is or is it to late?
Old Oct 11, 2008 | 06:59 PM
  #79
ajcool2's Avatar
bump
Old Oct 12, 2008 | 06:02 AM
  #80
t6378tp's Avatar
Turbo 3.5
put the bolt in the crank and turn it
