Sponsored by:
Sponsored by: CARiD
VQ35 Swap Progress Thread
Old Oct 12, 2008 | 09:55 AM
  #81
ajcool2's Avatar
Originally Posted by t6378tp
put the bolt in the crank and turn it
Ok will I have to redo all the timing stuff?
Old Oct 12, 2008 | 11:21 AM
  #82
t6378tp's Avatar
Turbo 3.5
Well I had help when putting the main chain on wanted to make sure I did not screw it up, well Darryl put it on but it was not as hard as I thought it would be.
I ran into the same problem with the motor not being at tdc so we line up the secondary chains put water pump guides on. primed the tensior compressed it put the pin in to hold it in place, lined up the main chain on the cam sprockets and turned the crank to tdc so it lined up with the colored chain link
step back made sure all the colored links were lined up and the secondary chain were still lined up with pulled the pin from the tensior check everything again
not really sure how to explain it but there are these little tabs you can use as referance marks to make sure the crank and cam sprockets are in the correct location turn the motor by hand a few times and check everything again
I am sure someone else can explain alot better than me so maybe someone will chime in
Old Oct 12, 2008 | 12:43 PM
  #83
accordingtou's Avatar
VQ30 DE T
As stated above....
There are tabs on the rear timing cover to assits in alignment
Notice the location of the arrows & discolored timing chain links.(they both point to the tabs on the rear timing cover).
Left side
Right side
There is a line on the oil pump @ about 10 oclock.In order for the #1 piston to be @ TDC,the woodruf key on the crank should be aligned with the line on the oil pump
Align (timing marks)
Prime/release (tensioner)
Rotate (assembly)
Be sure to post start up & WOT flyby vid
Old Oct 12, 2008 | 12:50 PM
  #84
VQ30 DE T
Side note I just noticed the 3.5 timing chain tensioner..
I didnt know you could use it with te 3.0 equipment?
Old Oct 12, 2008 | 01:35 PM
  #85
t6378tp's Avatar
Turbo 3.5
Hey ^ post my startup on youtube so I can link it to my cardomain
Old Oct 12, 2008 | 01:57 PM
  #86
Tatanko's Avatar
Bacon Lover
Good work so far, AJ. I may just have to have you build me one
Old Oct 12, 2008 | 06:04 PM
  #87
Grand_hustle17's Avatar
we're sharing the same thoughts
Old Oct 13, 2008 | 02:58 PM
  #88
ajcool2's Avatar
Ok thanks for the help guys hopefully I can get a chance to work on it tonight. I'll try to get a pic of how it is currently and after I align it the way you guys say. I'll be glad when this part is over haha.
Since I've put most of the timing stuff on and and taken it off about 4 times so far it doesnt seem to bad. Especially once you start understanding how things work and what everything is. I can actually read those 3.5 swap thread and know what they are talking about lol. Maxsapphire is at a point that when I ask for a certain part she knows what it is which is cool. She cant wait to take it to the track. We will definatly have vids up once everything is done, of course she'll get the first drive.
Edit: ONLY USE THE 3.0 TENSIONER
Old Oct 13, 2008 | 03:12 PM
  #89
VQ30 DE T
Done
I used the 3.5 tensioner because thats what tavarish did in his writeup. I had to double check it after I put it on myself.
Maybe Ishouldnt have thrown away that tensioner.lol Good to hear though
Old Oct 13, 2008 | 05:15 PM
  #90
Aaron92SE's Avatar
NWP Engineering.com
I'm definitely paying attention to this thread. Thanks for updating it every so often.
Messing with the timing components can seem scary at first, but if you have the ability to read the FSM and understand it, then it's surprisingly pretty simple. Just take your time and follow each step. Once you have everything together, turn the engine over manually several times to make sure it rotates freely.
I'm planning on going a little deeper into my engine. If I have it on the stand, I might as well do as much stuff as I can to it like seals, HGs, cams, valve springs, rod bolts, port work, etc.
I can't wait to get my progress thread started! I don't want to start it until I have an engine though. That way people will know I'm serious. I hope to buy my engine tomorrow. We'll see.
Old Oct 13, 2008 | 08:30 PM
  #91
SouthFlMaxTech's Avatar
I just finshed my 3.5 swap and it is great!!! put in a 2008 engine from a maxima.. had 491miles on it when I put it in.. I hooked everything up and no check engine light on does anyone know if anyone else has done a 3.5 swap and had no check engine light I have EGR and EVAP system complety hooked up.. anyways any help or questions you have ask away..
Old Oct 13, 2008 | 08:36 PM
  #92
ajcool2's Avatar
No check engine light?? Good job. You got a dream swap. I'm sure I'll be posting more questions here as I go along.
Old Oct 13, 2008 | 08:41 PM
  #93
ajcool2's Avatar
Originally Posted by accordingtou
Done
I just triple checked the picture from the writeup and its a 3.0 tensioner. I guess its a good thing I checked again. I'll edit my post to keep good info here.
Old Oct 13, 2008 | 08:43 PM
  #94
ajcool2's Avatar
I'm sure its going to be a beast once its done.
Old Oct 19, 2008 | 01:26 PM
  #95
ajcool2's Avatar
PLEASSSEEE tell me this is right.
Old Oct 19, 2008 | 05:04 PM
  #96
VQ30 DE T
Old Oct 19, 2008 | 09:23 PM
  #97
95BLKMAX's Avatar
all looks good from here sir. just be srue that you did in fact prime that primary chain tensioner with plenty oil. LAST thing you need is for there to be slack and you end up with a chain skipping a tooth at startup. Not trying to jinx it or anything [*knock on wood*] but that is a very important thing to do that will save you huge headaches down the road
Old Oct 20, 2008 | 04:57 PM
  #98
t6378tp's Avatar
Turbo 3.5
pic's please and what did you do with the egr
did you install the 4gen egr or did you rig it up somehow
Old Oct 23, 2008 | 03:25 PM
  #99
93altima's Avatar
Turbo 4th Gen
update!?
Old Oct 23, 2008 | 03:33 PM
  #100
ajcool2's Avatar
Originally Posted by 93altima
update!?
I'll be working on it tonight. I've been working late and havent had a chance to work on it this week. I need to prime that main tensioner, put the last chain guide on and install the outer timing cover. Then put everything else back together.
Old Oct 27, 2008 | 08:12 AM
  #101
ajcool2's Avatar
The outer timing cover is on and all the timing is set. I know it took a long time to do but I wanted to make sure everything was right so I dont run into any problems later. We'll be putting everything back together during the week. My goal is to have it running before november 9th.
Old Oct 27, 2008 | 08:28 AM
  #102
ajcool2's Avatar
Also if anyone is planning the swap in the future and want pictures of anything just let me know.
Old Oct 27, 2008 | 08:53 PM
  #103
vwracer1172's Avatar
looks good
Old Oct 28, 2008 | 09:38 PM
  #104
mastercater7's Avatar
VQ35 FTW
In your picture of the chain tensioner, I dont see the piston pushing on the guide? Make sure that piston didn't fall out. Also, I would recommend buying a new tensioner if you can afford it. 2 months after my swap my tensioner began to go out. I really did not want to have to pull the motor again... Looking great though!
Zack
Old Oct 29, 2008 | 08:05 AM
  #105
MOHFpro90's Avatar
Aj, never looked in this thread before now and...I bet you're glad you dont have to do this in your apt parking lot.
Nevertheless, nice job man. Really like all of the pictures! Good luck.
Old Oct 29, 2008 | 08:10 AM
  #106
ajcool2's Avatar
Zack
The piston is there its just not sticking out. Its really tight up against the guide. Would I be able to tell if a tensioner is good or bad before its all in the car? When I primed it it pushes in and comes out smoothly.
Old Oct 29, 2008 | 08:12 AM
  #107
ajcool2's Avatar
Indeed I am my friend lol. I need hurry up and finish this because it is getting really cold.
Old Oct 29, 2008 | 03:32 PM
  #108
VQ35 FTW
I have never seen that. The piston is always pushing out on the guide. I would get a new one regardless. They arent very expensive.
Zack
Old Nov 4, 2008 | 09:50 AM
  #109
ajcool2's Avatar
Got a question. Is there any reason why most people decide to shave the block instead of just rewiring the 3.5 CPS?
Old Nov 5, 2008 | 12:14 PM
  #110
ajcool2's Avatar
Zack
I turned the assembly and it did move out as I turned it around. I think I'll wait and see how it works once everything is back together.
Old Nov 7, 2008 | 05:45 AM
  #111
maxspeed88's Avatar
yo man i need help with my swap
Old Nov 7, 2008 | 11:18 AM
  #112
ajcool2's Avatar
What part do you need help with?
Old Nov 8, 2008 | 08:35 PM
  #113
93altima's Avatar
Turbo 4th Gen
Whats the Est. time until the start up youtube vid? lol
Old Nov 20, 2008 | 12:06 PM
  #114
dfownz's Avatar
I'm really considering doing a partial swap into my 2000. The only parts I seem to not understand is how/what sensors are hooked up and what you need to do to stay 5spd.
Care to clarify this for me?
Also, how did you get no codes SouthFLMaxTech?????
Old Nov 20, 2008 | 01:46 PM
  #115
ajcool2's Avatar
LOL Dont know but it will be in the car by sunday.
Old Nov 20, 2008 | 02:15 PM
  #116
ajcool2's Avatar
I just printed page EL-318 and EL-319 from my FSM and highlighted the sensors I'll need to bring over from the 3.0. I'll list them and if anyone sees anything missing let me know and I'll add it here.
3.0 02 sensors
3.0 Rear 02 sensor
3.0 TPS
3.0 IACV
3.0 CPS (Phase)
3.0 Engine coolant temp sensor
3.0 MAF
3.0 IATS
3.0 Map Baro solenoid
3.0 CPS (POS)
3.0 Knock sensor
3.0 CPS (REF)
I'm actually going to use the 3.5 CPS (POS) sensor and wire it up. My question is do I still need to switch over the AT driveplate if I do this?
Old Nov 21, 2008 | 10:17 AM
  #117
dfownz's Avatar
So all the 3.0 sensors fit on the 3.5 w/o modification? The only one you have to modify for is when using the 3.0 cps?
This seems almost too easy...
Old Nov 21, 2008 | 10:42 AM
  #118
ajcool2's Avatar
Yup so far I've just unbolted them from the 3.0 and bolted them on the 3.5.
Old Nov 22, 2008 | 08:55 PM
  #119
95pealmax's Avatar
well its 12am sunday morning well is it in???lol
Old Nov 23, 2008 | 06:53 AM
  #120
t6378tp's Avatar
Turbo 3.5
I reused all 3.0 sensors, but then again I used the 3.0 upper and lower pan also
