Sponsored by:
Sponsored by: CARiD
VQ35 Swap Progress Thread
Old Nov 23, 2008 | 08:59 PM
  #121
95BLKMAX's Avatar
REPORT!!!!
Old Dec 1, 2008 | 08:49 AM
  #122
ajcool2's Avatar
Ok well Im sure you all think Im crazy by now because its not in the car yet lol but Im getting there. We out the alternator, Ac compressor, powersteering belt and oil pan back on saturday. The only thing stopping us from dropping it in is the rear headers. One of the bolts is stripped and I cant get it off. I tried removing the whole stud but broke off the tip. I went to sears and bought one of the stripped bolt removal kits but it didnt have the correct size in it so I have to go back today and find the right one. Also is there supposed to be some type of spacer on the idler pulley? Im trying to put it back together but something doesnt seem right about it.
Old Dec 1, 2008 | 09:31 AM
  #123
Aaron92SE's Avatar
NWP Engineering.com
Yes, there is a spacer on the idler pulley. It's about 3/8" thick. Without it, the pulley will hit the threaded adjusting rod.
Old Dec 1, 2008 | 02:14 PM
  #124
ajcool2's Avatar
Ok thanks I'll look for it when I get home.
Old Dec 1, 2008 | 02:29 PM
  #125
Aaron92SE's Avatar
NWP Engineering.com
Let me know if you can't find it. I may have another one you can have.
Old Dec 9, 2008 | 12:51 PM
  #126
ajcool2's Avatar
Small update: I finally got the #$%^&% rusted stripped bolt off the headers and removed them. So the next step is install the new headers and drop it back in. Also how many people rewired the CPS near the tranny instead of grinding?
Old Dec 9, 2008 | 02:25 PM
  #127
accordingtou's Avatar
VQ30 DE T
I did the first time. The car ran for a while then the sensor died
Now I have the 3.0 upper oil pan to make things more simple when it comes time to diagnose a problem.
Old Dec 17, 2008 | 03:53 PM
  #128
93altima's Avatar
Turbo 4th Gen
???????Is it running yet
Old Dec 31, 2008 | 02:26 PM
  #129
TJ_Max's Avatar
Paradox Systems Vendor
Got a question. Is there any reason why most people decide to shave the block instead of just rewiring the 3.5 CPS?
If you actually got the CPS from the junkyard, then they should use it and crossreference (or ask the org) about the 3 wire colors. They arent the same at all IIRC with the 3.0 sensor harness.
The last 3 motors I got that sensor was not there, and its costs over $100 for the sensor. I like the idea of swapping over the upper pan because at least you know you've resealed the motor with fresh sealant. ALSO, as KRRZ350 and I were discussing a while back, the CORRECT way to put back the motor, seal-wise is to bolt inner and outter timing covers and the upper oil pan should bolt up LAST. That's how the front and rear crescent shaped crank seals are designed.
Originally Posted by mastercater7
I have never seen that. The piston is always pushing out on the guide. I would get a new one regardless. They arent very expensive.
Zack
I REQUIRE this with ANY timing job. Its like 60-70 from the dealer, cheaper at other parts stores. I also requre the 3 $3 O-rings be new that go between the block and inner timing cover. Also the one for the oil pump. I also spend the 20-30 bucks for OEM Nissan Sealant.
Granted, its not REALLY a headache to change the tensioner while the motor is in the car, as per the access panels on the side of the motor for it, but still...A beyotch indeed, not worth a tooth skipping.
Originally Posted by dfownz
I'm really considering doing a partial swap into my 2000. The only parts I seem to not understand is how/what sensors are hooked up and what you need to do to stay 5spd.
You've got it easier than us since your injector connectors plug up just fine.
When doing your install, instead of unplugging sensors, just unbolt them and swing them out the way with the harness. When you drop the motor in just swing the harness back over the motor, plug in what fits, extend a few wires here and there, and bolt down the corresponding sensors. If theres an existing sensor on the motor already, just unplug the sensor off the harness and plug it into the new one.
Old Dec 31, 2008 | 02:28 PM
  #130
pmohr's Avatar
No more Maximas...
I've got 4 or 5 of them laying around if you know anyone that neeeds them
Old Dec 31, 2008 | 02:30 PM
  #131
TJ_Max's Avatar
Oh yeah, AJ, hope its coming along, this is a damn long project, lol. These are being done in weekends bro, watch a Fast and Furious Movie, get motivated and get out there, lol.
Do you have an adjustable FPR? I think this comes in handy when its time to convert the 3.5's returnless rail to the 3.0.
Old Dec 31, 2008 | 02:31 PM
  #132
TJ_Max's Avatar
STFU!!Really? Throw that in the box with the pedal real quick, LMAO. Really though, those things are free anywhere you go, ya know (trying to get a freebie here, lol).
Old Dec 31, 2008 | 02:47 PM
  #133
pmohr's Avatar
No more Maximas...
Heh. $40 and I'll throw all 4 of them in there. Last I checked (6 months ago or so), they all worked, but I as I don't have a 3.5 to test with I can't check them again.
Old Dec 31, 2008 | 04:08 PM
  #134
ajcool2's Avatar
Thanks for all the info man. I know its taking long but its been like 30 degrees here and I've been waiting for at least one warm day to drop it back in. No garage FTL. I do have an AFPR I ordered it months ago. I might just have to brave the cold and get it done.
Old Jan 3, 2009 | 11:57 AM
  #135
ajcool2's Avatar
Ok everyone please tell me I didnt do all this work for nothing. I was removing the drive plae today and notice a crack where one of the tranny bolts go. Here are some pics.
Old Jan 3, 2009 | 12:00 PM
  #136
pmohr's Avatar
No more Maximas...
I broke mine off too, a long time ago...that's how I learned to not draw the trans in with the bolts.
Honestly I just left it off until my 5 speed swap, it was just sitting in my toolbox as a reminder. When I did the swap I bolted it back on place because that's where the 5 speed control rod bolts up, I've never had a problem with it.
It'll be fine once everything is bolted up, especially if it isn't all the way off yet.
Old Jan 3, 2009 | 12:08 PM
  #137
VQ30 DE T
JB WELD.... yes im serious
Old Jan 3, 2009 | 12:13 PM
  #138
ajcool2's Avatar
Thanks man. I'm off to bolt up the drive plate. Oh you wouldnt happen to know how much torque is needed for the driveplate bolts would you
Old Jan 3, 2009 | 12:14 PM
  #139
ajcool2's Avatar
Yeah that was the first thing I thought of when I saw it.
Old Jan 3, 2009 | 12:35 PM
  #140
ajcool2's Avatar
Another quick question what did you all use to block the egr bung on the rear headers.
Old Jan 3, 2009 | 01:58 PM
  #141
ajcool2's Avatar
This is more of an informational post but theres a small hole in the 3.5 auto driveplate that isnt in the 3.0 so it will need drilling to make it fit.
3.5
3.0
Old Jan 3, 2009 | 02:46 PM
  #142
t6378tp's Avatar
Turbo 3.5
I ordered a egr block off plug from courtesy nissan for 8bucks
Old Jan 3, 2009 | 03:54 PM
  #143
kzoosho's Avatar
Hey you can tig weld that also if you dont want to jb that ish
Old Jan 3, 2009 | 04:40 PM
  #144
ajcool2's Avatar
Ive never tig welded so I'll be jb welding it.
Old Jan 3, 2009 | 05:11 PM
  #145
ajcool2's Avatar
Thanks I'm looking for it now.
Old Jan 3, 2009 | 06:27 PM
  #146
pmohr's Avatar
No more Maximas...
Dunno actually, skimmed through the FSM but didn't see a mention of it.
http://www.courtesyparts.com/14003k-...3-p-53839.html . That's the one I'm running on mine.
Yea, it's that damn alignment dowel to make sure you get the VQ35 timing ring lined up correctly. You can just yank the dowel out of the crank too, either way it doesn't matter.
Old Jan 3, 2009 | 07:18 PM
  #147
t6378tp's Avatar
Turbo 3.5
yeah thats it
Old Jan 3, 2009 | 07:24 PM
  #148
grey99max's Avatar
LandShark has Cosworth
According to the '99 FSM, they need 61-9 ft-lb... Section EM - Cylinder Block. Not the first place you would look, but I thought I remembered where.
Old Jan 3, 2009 | 07:36 PM
  #149
pmohr's Avatar
No more Maximas...
Heh, I pulled up my last open EM section of the FSM and it was centered right on the torque specs for the flywheel/flexplate bolts. It figures I didn't look right in front of me before giving up...
Old Jan 3, 2009 | 07:49 PM
  #150
TJ_Max's Avatar
I'd also advise you to simply JB weld that piece.
The drive plate bolts should be torqued to 61-69 ft/lbs and the threads should be lubricated with new engine oil. That's per the 02' FSM.
Edit: Just saw someone already posted the answer.
Old Jan 3, 2009 | 07:53 PM
  #151
ajcool2's Avatar
I got the driveplate bolted up and I'll torque them tomorrow because its freezing out. I really want to get it in tomorrow if it doesnt rain and I get some extra hands. Thanks again everyone.
Old Jan 3, 2009 | 07:54 PM
  #152
TJ_Max's Avatar
I didn't understand why it would affect the fitment. That's just to line up the hole in the crank, but nothing bolts to it or goes through it IIRC.
Old Jan 3, 2009 | 08:09 PM
  #153
pmohr's Avatar
No more Maximas...
If he's got a dowel in it, it'll keep the flexplate from laying flat to the crank.
Old Jan 3, 2009 | 08:52 PM
  #154
ajcool2's Avatar
Yeah theres a dowel that goes through the hole on the 3.5 driveplate. I drilled through the 3.0 plate and bolted right up.
Old Jan 3, 2009 | 11:21 PM
  #155
TJ_Max's Avatar
Hmm, interesting, I don't know why I always remember there not being a dowel there. Good stuff though.
Old Jan 4, 2009 | 11:59 PM
  #156
nismology's Avatar
Been saying this for years but nobody seemed to listen so I gave up.
Old Jan 5, 2009 | 07:56 AM
  #157
TJ_Max's Avatar
Only 10 more bolts away from a job correctly done.
Old Jan 7, 2009 | 09:43 PM
  #158
maxboy325's Avatar
Red = Tru Story
Old Jan 24, 2009 | 07:37 PM
  #159
93altima's Avatar
Turbo 4th Gen
soooooooooooooo................................... .................................................. .....................
Old Jan 24, 2009 | 10:12 PM
  #160
t6378tp's Avatar
Turbo 3.5
I was going to bump this thread
whats going on why isn't this motor in yet
