Oil catch can questions
Installed the home depot one last night. A few questions the catch can has to faced a certain way or it doesnt matter? Currently mine is in upright position does it matter? Also i got the husky one from home depot it has a lil vacuum leak at the bottom so i silconed it up anyone else do this?
are you talking about the correct way to face it as far as flow?
point the can with the arrow coming from your pcv valve if thats the case.
also, what vacuum leak are you talking about? the valve thing on the bottom to release all the oil?
if the valve wasnt seated right then it might have leaked,.. u might have been able to play with it and get it right.. oh well silicone works...unclear on what you were asking.. the 'cup' should remain down so gravity can hold the oil in there ..like this ' U ' lol..also many find, including myself, that removing the hard white filter thingy allows it to collect more oil....oh and there is an arrow indicating flow on the device,.. it only catches one way or else u will block airflow... the correct direction is from the pvc into the intake mani. hope that clears things up
yea the lil hole at the bottom is open. I have the arrow coming from the pcv valve pointing towards the maniford likle this manifold<. Installed it yesterday and no oil in the catch can yet. Its also tilted at an angle that might be way
yea it whistles when the car is on
yep^^^^^
i noticed mine has the valve on the bottom thats pointless as well.. i was like wtf if it dont even close lol. what fittings did you use and did u get em from lowes or home depot? gonna be installing mine soon .. thanks
Strong bump, but i feel this thread was left unanswered.
My Husky catch can also has the described valve that doesn't close under vacuum. Only under pressure. What did the valve look like on those who didnt have this vacuum leak problem?
Mar 12, 2020 12:06 AM
bbsitum
Sep 11, 2015 04:55 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
