Sponsored by:
Sponsored by: CARiD
NEW CAMS ?????
Old Jan 30, 2009 | 05:45 PM
knightmelodic's Avatar
NEW CAMS ?????
Okay. The engine has been rebuilt with high dome pistons bringing psi to 190-200. Headers, full exhaust. CAI. Underdrive pulley. Heads ported and polished with HD bolts and gaskets. So it's cam time. Now, Jim Wolf has some with .460 lift!!!!!! Too high. Then some with .430 which is still high but drivable. Two questions: any other cam dealers out there? And what is the lift on stock cams. Thanks.
Old Jan 30, 2009 | 06:46 PM
pmohr's Avatar
No more Maximas...
Are you running a VQ35 or VQ30? You haven't filled in your information in your profile. This question would be best placed in AM, most of the regulars in the general forum aren't too keen on cams.
Old Jan 31, 2009 | 09:07 AM
Puppetmaster's Avatar
Moved to All Motor. Some cam specs and discussion is here:
http://forums.maxima.org/all-motor/5...me-decide.html
Old Jan 31, 2009 | 11:29 AM
Tnx
Thanks for the moving this thread. Some more info. The car is a 2003 6sd man with LSD. Short throw mod too. It's pretty hot right now (ask the gold max I toasted on the Taconic the other day) but misses below 1600 rpm. I know I need a remap for that, so I figured what the hell? Gotta be dynoed to be tuned might as well drop in some cams. It was mapped a few years ago by technosquare. Oh yeah, springs and struts drop it by 2 inches and tighten the ride along with anti-sway in the rear and strut brace in the front. Also sub-frame bushings and motor mounts from cattman kill that wheel hop.
Old Jan 31, 2009 | 11:34 AM
pmohr's Avatar
No more Maximas...
Just throwing this out there, I hope you understand just how much labor goes into 'throwing in' a set of cams in the VQ. You just have boltons, so I don't know if you're aware of that or not.
Old Jan 31, 2009 | 03:00 PM
Yep, I do. That's why I'll let my speed guys do it. Actually, the hardest part is getting the timing and cam chain cover off. They have dyno and ECM tuner to advance timing etc. Also, my engine was balanced during the rebuild so should be good to go. I'm just looking for something like .414 or so, so I'll have WHP increase from bottom to top.
Old Feb 1, 2009 | 12:18 PM
nismology's Avatar
Cam lift itself means nothing without knowing what the other specs are.
And there are a handful of other manufacturers that produce cams for the VQ35. Tomei, JUN, Nismo, Brian Crower, HKS, and GT Motorsports come to mind.
Old Feb 6, 2009 | 03:09 AM
like what?
Wudduya need to know for cams? Comp is 10.7. Psi is 190-205. Lift and duration are what cams are all about.
Anyway thanx for the suggested sources. Those crowers look good. Anyone had experience with them?
Old Feb 6, 2009 | 03:14 AM
pmohr's Avatar
No more Maximas...
FWIW, you mentioned lift but didn't say a thing about duration, and there's a bit more to cams than just those two.
Old Feb 6, 2009 | 09:08 AM
nismology's Avatar
+1
Duration @ .050"/ramp rates and LSA are much more important than max lift or advertised duration. Area under the lift curve and valve event timing makes all the difference.
Old Feb 7, 2009 | 12:25 PM
yup
True. But not really for PnP's.
Old Feb 7, 2009 | 12:31 PM
yup +1
+1
Just had it dynoed and it's being strangled by the stock cams. Torque is a straight line. HP climbs and levels. It's very happy @ 6k+. But every pull you could tell the motor wanted to do more. So, I think I'll drop in the crower 2s and remap the ECM. With the other mods the tuner was talking possible 30 @ the wheels. We'll see.
Old Feb 15, 2009 | 09:26 PM
Blackmax1924's Avatar
picture doesnt work for me curious what it is???
Old Feb 16, 2009 | 12:03 PM
MDeezy's Avatar
subscribing
Old Feb 16, 2009 | 05:07 PM
Dyno sheet. Funny, it shows up on prview post, my post and your quote.
Old Feb 17, 2009 | 02:41 PM
soseihin's Avatar
For you. I DLed your file and am hosting it elsewhere.
t3h dyno
Old Feb 18, 2009 | 04:56 PM
yup
t3h dyno
You are right my friend. Why I didn't use a photo host I don't know. But it's up now. Thanks for your help.
Old Feb 18, 2009 | 05:11 PM
crazthe1nonly's Avatar
for all that motor work and ur only pushing 230 TTW's omg u need to slap whoever build that motor
Old Feb 18, 2009 | 07:31 PM
coinage's Avatar
Jesus thats lean as hell!!!
Old Feb 18, 2009 | 07:44 PM
nismology's Avatar
There are a few things that you can do for power without opening up the motor. You have definitely not maximized your current setup.
Old Feb 18, 2009 | 07:48 PM
MDeezy's Avatar
thats very lean, even for a stock car! Was there a wideband or sniffer after the cat (if there is one). I would seriously hope so and your not running the car hard with ratios like that.
Old Feb 19, 2009 | 05:54 PM
no
LOL. No, the re-build is fine. I have 2% leakage on my vavles, which is sick. 190-195 psi in the cylinders. Balance is a dream. It's something else.
Old Feb 19, 2009 | 05:57 PM
suggestions?
Well, I'll be dropping some of those Brian Crower cams in and adding an Apexii 2. But before I do any of that, what would you suggest? BTW, the ECM goes back to TS with the dyno sheet next weekend.
spazma7ik
Jan 12, 2017 09:38 PM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
conansriver
Sep 11, 2015 10:26 AM
