Sponsored by:
Sponsored by: CARiD
Timing Case Issues...
Old Feb 6, 2009 | 03:13 AM
mastercater7's Avatar
VQ35 FTW
As some of you may know, I have a supercharged VQ35 in a 4th gen. The motor is on 3.0 timing. Anyways, I had a buddy help me install the supercharger and he managed to strip almost every hole on the timing case where the supercharger bolts up. I noticed a good size oil leak and found out about the stripped cover. I bought a tap for the holes but I am a little worried there isnt enough metal around the holes. The bolts are 6mm so I bought the next size up bolts and the tap for them which is standard. The plan is to just tap without predrilling because they are so badly stripped. Is this ok to do? Has anyone done this before?
Zack
Old Feb 6, 2009 | 12:41 PM
pmohr's Avatar
No more Maximas...
What size are you going to try to tap the holes out to, 1/4"?
Old Feb 9, 2009 | 12:30 PM
VQ35 FTW
Yes I am planning on using 1/4". Sorry I was out of town. Will this be alright?
Old Feb 10, 2009 | 11:27 PM
VQ35 FTW
Bump! Should I use this tap or buy helicoils?
Old Feb 11, 2009 | 06:33 AM
mtrai760's Avatar
'Trynna' is not a word
I'd only recommend using helicoils if you have experience with them.
Old Feb 11, 2009 | 06:18 PM
VQ35 FTW
Ok then I guess I will just use the tap. 1/4" will be an ok size right?
Old Feb 13, 2009 | 09:44 PM
Weimar Ben's Avatar
Helicopters! Money!!!
Screw standard, why not use metric like the rest of the car?
I'd go with an M8. I stripped out the threads on a 3.5 LIM which has M8 threads, IIRC. I tapped some M10 threads without drilling, with no problem at all. Since Al. is a soft metal, you can get away with not drilling it.
The key to tapping is use a lot of lubricant and make more than one pass. WD-40 works well as a lubricant. So you would start your cut, twist three or four times then back out to clear debris. The hardest part about tapping is getting the tap to start straight. If you get that down you're golden.
Old Feb 14, 2009 | 01:18 AM
liqidvenom's Avatar
brotherhood of tq
this car is going to drive you insane man...
Old Mar 7, 2009 | 06:41 AM
doublea's Avatar
I would only tap with metric size, it would match the previous thread better but helicoils would be A1.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
intimidator
Sep 5, 2015 07:23 PM
umnitza
Sep 1, 2015 01:03 PM
tnewbs
Aug 28, 2015 10:15 AM
ffcbairn
Aug 27, 2015 11:55 AM
