Sponsored by:
Sponsored by: CARiD
4th gen full 3.5 swap engine/trans question
Old Apr 30, 2009 | 01:34 AM
The Godfather's Avatar
So when choosing a 3.5 engine, I can choose any year FWD 3.5 as long as I also get the 02/03 ECU, keys, and harness? Is this correct?
Even those new HR motors?
Even up to 2008 with the new black IM?
And which year manual trans can bolt up to which year engines? for example, can the 2005 trans bolt up and work with the 2008 engine?
Old Apr 30, 2009 | 02:13 PM
pmohr's Avatar
No more Maximas...
I wouldn't go with anything over, say, '06. That's just from a simplicity and economical standpoint.
There are no FWD HRs.
IIRC all of the FWD VQs have the same bolt pattern. I know this for up to '06, but haven't had my hands on anything newer (in FWD, anyway).
Old Apr 30, 2009 | 03:00 PM
ok, thats narrows that down a lil bit(note to self). Thanks
Old May 16, 2009 | 08:15 PM
Heres the deal:
I found out my boy has an 08' Altima front clip, and its got the 6 speed manual trans. Computer,engine/dash harness....6k miles on the stuff....
What do you say? Yay or Nay and if nay please explain why.
Thank you
Old May 16, 2009 | 08:16 PM
pmohr's Avatar
No more Maximas...
Originally Posted by The Godfather
Heres the deal:
Thank you
If you've got the whole front clip, then go for it.
Mind you, unless you swap over everything, you're still going to have to do a bit of wiring.
Old May 16, 2009 | 11:23 PM
Would the said components be easier or harder to swap than '02/03 setup? wiring wise of course. Or should I just pick up what he has, but also get a 02/03 ECU, Nats, dash harness and engine harness and use that with the '08 engine/trans?
Old May 16, 2009 | 11:25 PM
pmohr's Avatar
No more Maximas...
I would imagine it'd be slightly more of an issue due to the CAN system, if you weren't to swap everything over.
Old May 16, 2009 | 11:59 PM
You keep saying swap everything over....that is the plan, what would I not swap over that isnt everything?
Old May 17, 2009 | 12:04 AM
pmohr's Avatar
No more Maximas...
There's a lot of stuff in the dash that may or may not work with an '08 harness.
Do you plan on doing the cluster and everything as well?
Old May 17, 2009 | 12:21 AM
Cluster; yes I would plan to use it.
So since it is unknown whether or not an '08 harness will work, should I just get the engine and trans regardless, and pick up the 02/03 harness? The Altima 6spd trans and engine are the exact same as in a maxima right?
Old May 17, 2009 | 03:02 PM
What I meant to ask was if the '08 engine and trans will wire up plug and play with the 02/03 harness
Old May 21, 2009 | 11:47 AM
bump?
Old May 23, 2009 | 07:43 PM
bump it up again
Old May 25, 2009 | 06:48 PM
bump
Old May 25, 2009 | 10:34 PM
MAXC's Avatar
Well the 08 harness wont wire up to the 02\03 harness. if you have the 08 cabin harness then you wont need the whole harness, you'll have to trim it down cause you'll only need a few of the connectors from that harness. everything else will have to be spliced in. Wiring up a 6 speed is a hell of alot easier than wiring up an automatic. At least with the 6 speed you wont get a CAN cel code & you wont have to wire up a tranny. I have a full swap auto & i not to long finished a friend of mine 6 speed full swap. There is a hell of alot wiring when doing a full swap.
Old May 26, 2009 | 12:10 AM
What I meant was if the connectors on the '08 engine and trans, will match the connectors on the 02/03 harness?
Old May 26, 2009 | 05:15 AM
eng92's Avatar
You mean will an 02/03 engine harness plug into all the sensors, etc on an 08 engine and transmission.
I do not think anyone here will be able to tell you 100% for sure.
I am sure a lot of them are the same (but probably not all) If you have access to the fsms for both model years, it is pretty easy to compare the connector pin layouts.
You may need to get both harnesses and splice parts of the 08 onto the 02/03 for the connectors that are different.
Old May 26, 2009 | 10:44 AM
Thank you
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Finkle
Sep 27, 2015 09:53 PM
schmellyfart
Sep 25, 2015 04:47 PM
Blackwind
Aug 5, 2015 06:35 PM
