Sponsored by:
Sponsored by: CARiD
Kevin's VQ35 Cam Build
Old May 22, 2009 | 07:09 PM
Kgkeen101's Avatar
Old May 22, 2009 | 07:21 PM
Deckdout2's Avatar
Play with my balls
If you're going to be running the Utec, why would you waste your money on the Technosquare reflash? The Utec is capable of doing what you need and more.
I'm also a little skeptical about 300whp without rods, pistons, and headwork to increase your compression to hit your mark. There's only a handful that has hit it N/A on my350z, and they had upgraded rods, pistons, and headwork.
I have similar goals in mind, but my component list is a little longer. Good luck!
Old May 22, 2009 | 07:52 PM
Kgkeen101's Avatar
Old May 22, 2009 | 08:11 PM
NiZMo1o1's Avatar
Originally Posted by Kgkeen101
UTEC doesn't adjust the ignition and VTC maps which is a limiting factor.
There's a maxima guy that posted 275whp with less mods than me and no cams with the UTEC and TS flash. I'm adding the UR underdrive pulley, NWP spacers, removed the VIAS, will most likely get the SSIM since I'll be revving higher and am adding a pretty aggressive cam. Anyways I'll post the results when I'm done I don't know if I'd hit 300whp exactly but it's worth taking a shot at without diving into my pocket to get pistons rods etc. So we shall see
My current mods are the JWT clutch, Custom Headers, Custom Y-Pipe, 2.5 catless exhaust system, CAI, Spec V gears, Ported IM. With those mods I put down 250whp/268 tq. No tuning or anything done yet so I'll see if I can push it over 300! Woot. I'll definitely be close if I don't
I'm also going to be advancing the timing to 17* as well.
Umm which guy was that ? I dyno close to there but without the TS , just the UTEC itself.
Which Chris are you talking about ? Crispeed the tuner or another maxima owner ?
Looking forward to see the finshed product.
Old May 22, 2009 | 08:15 PM
Kgkeen101's Avatar
Old May 23, 2009 | 05:54 AM
NiZMo1o1's Avatar
My buddy Chris has a VQ35 Sentra as well he lives in Boynton Beach, I don't know his forum name on maxima.org he'll probably chime in to say hello soon though. edit - VQpwrdSpeC is Chris.
Puppetmaster was the one who told me about the guy at 275whp. He's got the TS flash and uses a SAFC not the UTEC my bad. I spoke to him a while ago on my build with what I was gona be doing. I think the name was Jay.
Hmm I guess puppet made more than me
http://forums.maxima.org/dyno-discus...-a34-dyno.html
you have a link to puppetmasters dyno ?
Old May 23, 2009 | 09:24 AM
ajcool2's Avatar
He's talking about Jay_pee99.
Old May 23, 2009 | 10:19 AM
Deckdout2's Avatar
Play with my balls
Understood. Would definitely like to see the outcome of this. What is your expected time frame of completion?
Old May 23, 2009 | 10:44 AM
Puppetmaster's Avatar
He wants to use the Z33 CVTC maps.
Old May 23, 2009 | 02:27 PM
Aaron92SE's Avatar
NWP Engineering.com
Very nice.
Also, I'm in Palm Beach County a lot with my Maxima. I'd definitely like to check out your project when I'm in town. I won't be able to make it down there until after MAXUS 09 though.
Old May 23, 2009 | 06:41 PM
Kgkeen101's Avatar
Old May 23, 2009 | 07:00 PM
Kgkeen101's Avatar
Old May 23, 2009 | 08:12 PM
NiZMo1o1's Avatar
I wouldnt mind check the car out as well , I was just at the last 2 Events at Moroso so im up your way often
Old May 24, 2009 | 01:20 PM
yogi b's Avatar
Hello
Rooting for you
And following right behind
I think you will love the feel of those cams
and raised redline
for us it saves a shift to 5th in the ¼
I see you’re due to finish mid July
I might have my alternator in by then [no I’m not laughing]
I need to come visit
Three vq35de sentra's
Oh my
And all above 250hp
Hmmm!
Mine does have the lower end and mild head work done
and Chris's car runs within 2mph [I think] of my 108mph
one more thing
what part number t-stat are you using?
Old May 24, 2009 | 01:34 PM
streetzlegend's Avatar
Very nice build, some feedback from my experience. I wouldn't spend the money on getting the UDP. It hasnt proven to be much of a gain to be honest. All it does is dim your lights/weaken your a/c (if you have one) at idle. as far as power, nothing.
Also, a cutout (3" opening) right before your catback will add a few hp's. this is based on 95blkmax's dyno's, I believe he gained about 10hp from opening the cutout alone, or more i think.
Also, another interesting thing you can do that may(should) yield a little power as well, is the "volt boosta" (what we call it lol), basically increase the voltage to the coils to about 16v, and increase the gap of your plugs, giving you a stronger, bigger, spark, better more efficient combustion.
Old May 24, 2009 | 04:26 PM
Kgkeen101's Avatar
Old May 24, 2009 | 05:15 PM
Thanks for the suggestions, I don't have a cat in my exhaust system right now though. Interesting volt mod too. Thanks.
I have the UR underdrive pulley put on already actually, my feedback is that it feels as though it revs up faster. My lights don't dim and my audio system is still beast. I'm running about 700watts RMS through 2 amps 4 way channel speakers and 1 12in sub. So I haven't had any bad results with it. I like it. The weight difference between the stock crank and the UR one is pretty substantial. Could be I notice the difference more cause my vehicles a lot lighter?
As for the cats, yea eddy (95blkmax) didnt have any cats either, however he still got a good amount of power from opening the cutout, Perhaps a 2.5" catback dosent flow enough, but proven fact, open cutout WILL make you more power.
Thats good that the pulley didnt affect your car as much, yea it does rev quicker, but while driving, none of us (3 or 4 of us that did it locally) noticed a difference. U already have it so thats good.
Talk to Grey99 about the volt boost thing, he'll link you to the place that sells the device, or you can look for his thread on it.
Old May 24, 2009 | 08:02 PM
Kgkeen101's Avatar
Old May 24, 2009 | 08:49 PM
grey99max's Avatar
LandShark has Cosworth
Hi Streetz - the link would be:
http://www.powerstream.com/dcdc.htm
and the part I used for ignition boost was: PST-P90W in this section:
http://www.powerstream.com/ADC-p006.htm
Got my fingers crossed for your new engine build...
Old May 24, 2009 | 09:44 PM
mtrai760's Avatar
'Trynna' is not a word
I have been using the same thing for several months now with zero issues
Old May 26, 2009 | 05:16 AM
VQpwrdSpeC's Avatar
Sweet cant wait to tear it apart
Old May 26, 2009 | 06:55 AM
VQpwrdSpeC's Avatar
Kev we should race before you get all the work done... Do like a before and after run lol
Old May 26, 2009 | 08:40 AM
Kgkeen101's Avatar
Old May 27, 2009 | 09:07 AM
essential1's Avatar
My axles cry for mercy...
Yeah definitely. Whenever one of us isn't busy let me know.
I cant wait to see this project done.
It's funny, I live in boynton too, but we never seem to run into each other. You guys should come out to the sonic meet on wednesdays if you dont already do.
Old May 27, 2009 | 10:52 AM
VQpwrdSpeC's Avatar
I've rolled through there once a little while ago but I'm usually working so its hard for me to get out there, im suprised i've never seen your car
Old May 27, 2009 | 02:44 PM
NiZMo1o1's Avatar
I thought it was Mondays?
Old Jun 1, 2009 | 05:03 PM
Kgkeen101's Avatar
Got some parts
Old Jun 1, 2009 | 05:38 PM
nice nice, are you going to be shaving down the entrance of the cooling passage for better flow?
Old Jun 1, 2009 | 05:45 PM
cobradb's Avatar
nice
Old Jun 1, 2009 | 09:57 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Not bad. Have you considered a 96mm bore? Won't cost much more to get pistons that size and a little extra displacement never hurt anything!
Old Jun 1, 2009 | 10:33 PM
NiZMo1o1's Avatar
Quick View on the JWT Flywheel.
Alot of the Z guys are having issue that the JWT clatters alot.
Just a heads up. GL
Old Jun 2, 2009 | 04:13 AM
Kgkeen101's Avatar
Old Jun 2, 2009 | 06:23 AM
VQpwrdSpeC's Avatar
Yup
Old Jun 2, 2009 | 11:14 AM
Kgkeen101's Avatar
Old Jun 3, 2009 | 02:43 PM
NiZMo1o1's Avatar
Yeah, I ordered Wiseco Pistons 96MM 11:1 and Eagle Rods, figured why not just go the whole way with the build. And you're right they didn't cost that much as a set. That's why I said might as well. Was gona be a surprise post when I get them!
I read up about that, and Chris has it in his car already I didn't notice it driving in his.
Chris is VQpwrd ?? how many miles /years has he been running it ? if thats the case I could lean getting the JWT flywheel.
Old Jun 3, 2009 | 02:46 PM
nismology's Avatar
Did you consider the HR pistons?
Old Jun 3, 2009 | 02:58 PM
Jeff92se's Avatar
I'm needing a caw
Nice to see so many NA builds. It's revatively rare on the G and Z boards. They all go boost.
Old Jun 3, 2009 | 09:57 PM
Kgkeen101's Avatar
Old Jun 4, 2009 | 05:36 AM
VQpwrdSpeC's Avatar
Yup that would be me. Probably about a year and a half now with about 15K miles and all is well...
Old Jun 7, 2009 | 08:38 AM
essential1's Avatar
I'm always out there. That meet is cancled for good now though. Now it's just the thursday meets at the Hooters on palm beach lakes blvd. right off I95. It's an organized meet by the guys at bizspeed. http://www.bizspeed.net/
Different sonic.
