Sponsored by:
Sponsored by: CARiD
Kevin's VQ35 Cam Build
Old Aug 28, 2009 | 10:11 AM
  #81
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by Kgkeen101
Car is back, untuned, driveable just need an idle adjustment bad for the cams! Sounds deep though and nice. I'll post some pics and try to get a video. It's moving along very smoothly, motor feels like butter with the balancing. After the break in miles (which I'm not rushing since I'm full time working) I will be getting the tuning done in 3-4weeks ish. Can't wait to rip her wide open!
That's awesome! We are having a mini-meet in West Palm Beach tomorrow. Can you find a way to idle the car to the meet? I'll be there with my 92 Maxima VQ35.
http://forums.maxima.org/southeast-u...t-anybody.html
Old Aug 28, 2009 | 06:43 PM
  #82
Kgkeen101's Avatar
Old Sep 1, 2009 | 08:16 PM
  #83
Kgkeen101's Avatar
Teaser video
Old Sep 7, 2009 | 01:13 AM
  #84
mt2marc1's Avatar
looks way clean bro, i cant wait till i have my vq in my spec..
Old Sep 7, 2009 | 01:23 AM
  #85
mt2marc1's Avatar
what kind of car did you get you motor out of? and can you email me alist of what parts you used total for your swap, and finally how do you have all the 02 sensors all setup so you dont throw a code?
Old Sep 10, 2009 | 02:51 PM
  #86
TurboS13Hatch's Avatar
We did Kevin's swap years ago.. His engine is out of a 03 Maxima, IIRC..
Congrats on getting her up/running, Kevin.. Let us know what she makes!
Travis
Old Sep 10, 2009 | 02:56 PM
  #87
Just wanted to show this little video of the car. You have to hear this thing pur, it really sounds wicked. You can watch it in HD.
http://www.youtube.com/watch?v=vz6VolmtRmE
So based on how the car looks, would you ever expect anything other than a 4 cylinder under that hood?
Are those C2's? Hardly noticeable at idle..
Here's what Barry's car sounded like with JWT C8's..
http://www.youtube.com/watch?v=BGKgk...e=channel_page
Travis
Old Sep 10, 2009 | 03:16 PM
  #88
Kgkeen101's Avatar
Old Sep 10, 2009 | 03:17 PM
  #89
DAVE Sz's Avatar
Hooooooonda.....
really? One cam has a very noticeable lope while the other sounds completely stock...
Old Sep 10, 2009 | 03:26 PM
  #90
Kgkeen101's Avatar
Old Sep 10, 2009 | 03:27 PM
  #91
Kgkeen101's Avatar
Old Sep 10, 2009 | 11:31 PM
  #92
Well on the first page is all the performance upgrades from the stock motor. It's the sentra transmission in the maxima bell housing. Everything else from the sentra is stock, axles, motor mounts, just a modified front mount on the motor. Really not as much to it once you know what it is. I have the wheel hop aid spacers etc. to eliminate the wheel hop. Cold air intake was chopped up but I think I'm going to get a JWT pop charger setup so I don't have to worry about sucking up water. I have the crappy shorty header set too. Need to get some equal length headers later on. I have a 2.5in catback exhaust as well.
Oh and I have plenty of codes on my swap the check engine light is disabled. If you use the 2002 6 speed ECU apparently you can wire it up to be codeless, some New York City sentra club figured out how to make the swaps codeless. I guess there was an earlier model that didn't have the CAN system.
That's not very accurate.. EVERY mount is different, with the exception of the transmission side. To do it properly, takes a little bit of craftsmanship.. It's not "hard" to do.. but, it's not necessarily easy, either. It's taken me 3 years to perfect everything. There were changes to the design, even after you swap.
The wiring is by far, the most difficult aspect.. With a little bit of help, we have been able to get our swap codeless, but, it's a little bit of a pain in the @ss, and takes a certain ECU to make it happen.
No swap is ever "perfect".. but, give credit where it's due. I think that we've had a pretty good track record with these swaps. Your car ran for how long, without nearly any issues?
Travis
Old Sep 10, 2009 | 11:34 PM
  #93
Yep they the C-2s, I can't tell the difference between the videos personally. In person it sounds beast though all I can say I can always swap to C-8s later, but most of the NA 350z builds on my350z used the C-2 grind so figured I'd start there. Most did not recommend the C8's based on the specs down here so I went with their recommendations.
I dunno.. Barry's car is an absolute animal with the C8's.. and driveability is perfectly fine. I've never had a chance to run C2's, but, Barry is making some incredible power for just having a generic reflash.
I'm interested to see what your car puts down with the C2's and the work that's been done.
Travis
Old Sep 11, 2009 | 05:46 PM
  #94
Kgkeen101's Avatar
Old Sep 13, 2009 | 11:35 PM
  #95
Hold up a second.. No, it's not rocket science, but if it was easy.. there's be a LOT more shops doing this swap. It is fairly complex, if you want it to function properly (gauges, A/C, NATS, drive by wire, etc..) You don't have a CLUE.. you drop your car off somewhere, and pay to have work done. So, for you to make claims about the level of difficulty, isn't very realistic. If you have a problem with me, then, that's fine, but, you're not going to publically bash me like that, without provoking a response on my end.
Kevin.. I have NEVER put stock mounts in ANY of my swaps.. So, I don't know where you're getting that from. You show me a SINGLE picture of one of my swaps that was done that way.. Stay Tuned uses stock rubber mounts, that are cut up and welded together. I have NEVER done a swap that way.
The torque mounts have ALWAYS been solid.. We press out the stock, rubber mount bushing, and we used to weld in 316L stainless, 1/4" plate that was water-jet cut to the size needed, along with the holes in the proper spots to line up with the VQ brackets. The front torque mount has a CNC'd 1" thick billet aluminum adapter, that goes from the solid mount, to the VQ bracket.
Since late 2007, we've switched to solid nylatron inserts..
This system has worked phenominally, and we have yet to see a failure.
You have a huge f*cking chip on your shoulder, Kevin.. and I'm not really sure why. But, it's pretty sad.. Your car ran awesome for several years, and put up some pretty damn good numbers. What was not solid about your mounts? Of course they are modified QR BRACKETS.. it has always been that way. I've posted tons of pics from dozens of swaps, showing exactly how I mount the motor into the car. So, where do you get off saying that I lied about something with the mounts?
Shops love to dog other people's work.. and that's fine.. and, yes, your swap experience did not go as smoothly as 99% of the others have.. but, the car ran great, Kevin.. and I have bent over backwards to be courteous towards you. In return, all you have done is dog me, and accuse me of lieing/doing shoddy work.. My swaps are damn near perfect.. And, 99% of the people who leave with one from my hands are happy as hell with it. You want to see top notch work?
Give me a break, man.. You have knit-picked me to death on small stuff with your car for a long time, now.. I'm honestly tired of it. None of this stuff is EVER 100% perfect.. Hell, a STOCK car isn't perfect most of the time. Small stuff comes up, and I'm pretty sure that's the ONLY kind of issues that you've ever had.
So, please take the damn chip off of your shoulder, Kevin.. This is really getting old..
Travis
Old Sep 13, 2009 | 11:37 PM
  #96
Oh.. and your swap, when it left my hands..
As cosmetically appealing as my latest work? No.. but, it's still clean as hell, and done properly..
Travis
Old Sep 14, 2009 | 09:01 PM
  #97
97Maximus's Avatar
Shift_custom
interested to see track times, and maybe even dyno #s
Old Sep 15, 2009 | 08:59 AM
  #98
Kgkeen101's Avatar
Old Sep 15, 2009 | 09:55 AM
  #99
DAVE Sz's Avatar
Hooooooonda.....
seems you're talking about the side mounts and turbos13 is talking about the front and rear mounts. Mis-communication...
Old Sep 15, 2009 | 11:21 AM
  #100
Exactly, Dave.. And honestly, I've never said that the side mounts were solid.. No one has ever offered a solid side mount setup for this car, and every pic that I've ever shown shows that we modify the stock Spec V SIDE mounts with the swap. I can't make the side mounts solid, because there has to be some flex in those, in order for the torque mounts to properly line up. Every car is slightly different, and typically, the angle at which the side mounts sit can change a few degrees.. which is enough to throw off the bolt alignment if it would be solid.
The torque mounts, which are the most critical, have ALWAYS been solid. It's no secret.. I've never lied about it, or tried to hide anything.
Yes, I did cancel the AFC install, because it would have interfered with the tach adapter that we were using at the time. And, yes, I did go with the 2.5" versus 3", because it would have taken several more weeks to get the 3" tubing in from VRS. I refunded you partially, and there were a few things that I did extra.. so it was a wash, Kevin.
You can't please everyone, unfortunately, and this is just one of those instances.. It's easy for you to sit there and bark out claims, when you have no friggen clue as to what it takes to make this stuff happen. It's just this type of uninformed jibberish that starts trouble for no reason. I have never been ugly with you.. and I've put up with a lot of complaining.. I'm just sick of it, and I'm not going to sit here and let you trash me for no goddamn reason.
Go ahead and build your car, Kevin.. But, it won't be the fastest N/A Sentra.. I can assure you. We took that crown last year, and we'll up the ante again this fall with Barry's car.
Travis
Old Sep 15, 2009 | 12:09 PM
  #101
Kgkeen101's Avatar
Old Sep 15, 2009 | 01:18 PM
  #102
accordingtou's Avatar
VQ30 DE T
How aout those gators? I hear the eagles are getting rid of Mcnabb..
Whats that? this is not "off topic"?.. Oh sorry, mods can delete this post now.
Old Sep 15, 2009 | 01:57 PM
  #103
Kgkeen101's Avatar
Old Sep 15, 2009 | 02:07 PM
  #104
VQ30 DE T
Great Goodluck @ the dyno.
Old Sep 15, 2009 | 04:17 PM
  #105
Hey I'm not the only one with work from you that's had an issue, I've talked to others so nobody else bothers to mention anything. That's why it just started to build on me with some of the crap, multiple end users of your work with issues... Anywho, fi-r.net was supposed to be public wasn't it? Didn't know you were going to control things and stuff. Funny how you blew up and banned me instantly. The Specvforum and thespecvboard guys are right about you... Man and I had never talked to anyone interested in getting a swap about how mine went I just directed them to ask you for more information. Now all Florida meets will be ill advised about that I can assure you =). Once again Travis with his excellent customer service shutting out a customer. Can't you accept criticism and then move on, you gota learn that the customer is always right but this industry has trouble with that. Oh well. Moving on.
You know that when I first received the car back it didn't have a front mount at all. And that's when it broke up side mounts instantly. I was like WTF.
Sure, Kevin.. Dozens upon dozens of people are all lieing to me when they tell me that they are happy with thier cars..? Why don't you let me know who those people were? Get real man..
I banned you from my site, because you talk out of both sides of your mouth. You have no problem asking me about something, then, turning around and calling me a liar on this site. No site is "publically owned". It is a privaledge to post on ANY forum.. I don't care to have you on MY site any longer, if you're going to act this way. Again, I have NEVER been ugly with you, and this was uncalled for. Thespecvboard, I could care less about.. but, I know damn good and well that Kael and most of the crew over at specvforum have a ton of respect for me.
You are NOT right, in this case.. and I have a firm belief that you simply cannot please EVERY customer. Some people have screws loose, or just can't comprehend the whole picture. You can tell people whatever you want, Kevin.. Do you really believe that you're going to ruin my reputation with outlandish claims? People see my work, and they know that I don't mess around. But, I'm not a push-over, and I'm not going to sit here and take bashing from someone (customer or not), when it is not justified.
You have very unreasonable expectations, Kevin.. and I simply can't deal with that. I will say that you car ran just fine, with the exception of some minor teething issues, that come with ANY swapped car. Also, your car was one of the earlier ones that we did, and it had a few more issues than most. But, that's just the nature of this game. It doesn't mean that I f*cked you over, or lied to you.. or whatever.. It simply means that at that time, the swap wasn't 100% perfect. You want to try and crucify me for that? Then, that's your choice, but, I won't associate with you, and I won't have you on my forum. Good luck with your car.
Travis
Old Sep 15, 2009 | 04:20 PM
  #106
Sorry to the people on the .org.. This should not have gone down like it did. I am done in this thread, as I feel that I have defended myself and said what I had to say.
Travis
Old Sep 15, 2009 | 05:26 PM
  #107
Kgkeen101's Avatar
Old Sep 15, 2009 | 11:36 PM
  #108
505max94se's Avatar
Old Sep 16, 2009 | 03:47 AM
  #109
po8pimp's Avatar
Anywho, back to business as stated before, get ready for a real NA build the right way. =)
I am envious of your build. I want the funds to do this. Sales must be hoppin??? As much of the crap you may or maynot have experienced in your build, it still was done and is your current building block. You might have your differences, however this guy did do you a service that about 98% of shops wouldn't shake a stick at due to liability issues. You would not be at this stage without his help, and personally I think you owe him at least that credit. You two have differences that should be discussed in private, or court if it's that bad, not here on the forum. Your current build is nice and can't wait to see the results. that is what this thread should be about. As for Motor mounts, Nissan motor mounts suck even for our 6th gens. They are not strong enough for the torque this engine puts out stock. Might want to look at inserts or making your own poly mounts. There are kits out there. Post some pics of the build if you would and dyno sheets. Also do you plan on tracking your ride. Curious to see what numbers you put up for the quarter mile. If 300whp I would venture to guess mid 13's n/a. With your build I bet a 75 shot of NO2 would put you in the low 12's. There is a 6th gen that has a 75shot in a stock vq who ran a 12.8 1/4 mile.
Old Sep 16, 2009 | 07:04 AM
  #110
Kgkeen101's Avatar
Old Sep 16, 2009 | 08:19 AM
  #111
po8pimp's Avatar
I agree once you know an engine they are pretty much all the same until you get into hybrids and what not. Just watching builds on HP tv helps alot. With the right tools and basic knowledge anything is possible. I have never torn down a transmission but plan on doing it soon. Record everything I take out in order and replace in reverse order. Use torque specs from a repair manual I am getting. sounds complex when you think about all the gears and parts, but should be pretty simple. That's pretty cool that the transmission bolted up. Did you have to do anything to beef it up? Our 5 speed auto trannies suck.
Old Sep 16, 2009 | 11:15 AM
  #112
VQpwrdSpeC's Avatar
With 300whp he'll be running low 12's n/a maybe better. With a 75 shot he'd easily be in the 11's. I dyno'd my car and it netted around 235whp and I ran a 12.9 on drag radials...
Old Sep 16, 2009 | 12:59 PM
  #113
Of course I'm happy that I got the VQ in the car to begin with. But everytime someone other than Travis decides to mess with their car it's always, are you sure you can do that, VQs are difficult and it sounds intimidating. I took it to a performance shop here, the car was tore down in 1 day. Machinist took a while for the other stuff. And it was rebuilt in a day and a half once all the parts were there. After this whole build not only do I understand 50x more about engines, it's really just not as hard as people make it sound on these online forums. I am excited about the results and the issues with Travis were from a couple years ago and not worth the time in a court or anything like that. The guy who did my build has put RB26DETT in G35s. Custom everything and then swapped back to VQ35s, A/c working and all. I trust if I decide to build another VQ swap for boost he'll be able to build his own harness and get it up and running ( this would be my 2nd spec v)
I never meant to come off like that.. I got into it with Stay Tuned, but I appologized to them, publically, and since, have worked with them on getting codes taken care of.
This is an easy swap.. for a shop/person that deals with VQ's in/out, on a daily basis. It's not just a simple swap for the average person, with basic wrenching skills. And, that's not an insult.. it's just the way that it is.
I appologize for the problems that you had.. and I appologize for fightning with you on here. Good luck with your build..
Travis
Old Sep 16, 2009 | 01:05 PM
  #114
That's really all I've ever wanted.. Credit for doing the swap.. I put a lot of time into each and every one of the cars that I build.. and, while some of the early cars weren't as "complete" as the ones that were built later.. I still gave it 100%. When you have that credit taken away.. it really sucks.. and it's something that eats at you.
As far as his ET/MPH.. A bolted spec at 235-240whp will run 12.90's @ 104-105mph on a 24 x 8" slick. We've done it numerous times.. along with customers.
Barry's car ran 12.20's @ 110-111mph.. He had bolt-on's, C8 cams/springs, ported heads (stock valves), and 11.5:1 C/R. Tuning via T/S generic reflash.. from his MPH and weight.. I'm guessing that his car is making around 300whp.. give or take..
So, Kevin should be right around those times on a cool day, with good traction.
Travis
Old Sep 16, 2009 | 06:41 PM
  #115
Kgkeen101's Avatar
Old Sep 16, 2009 | 11:48 PM
  #116
Thanks.. that's all that I was really looking for..
Barry's car has a decent tune, His biggest problem is 11.5:1 C/R on pump gas, and 100 degree heat. Combined with repeated floggings at the drag strip.. and he had some detonation issues. We're going to knock the compression ratio down just a tad, and go with a big bore/sleeved setup.. which should more than make up for the small drop in compression ratio. This will allow him to run more aggresive timing on pump gas, without detonation, and should yield more power from the 1/2 liter bump in displacement.
Travis
Old Sep 17, 2009 | 01:38 PM
  #117
VQ30 DE T
Travis
I'm 100% sure you have thought of this (meth) but what is your/owners reason for not using meth to control knock on his setup?
Old Sep 17, 2009 | 02:45 PM
  #118
nismology's Avatar
Travis
Hate to really get this too off-topic but all else being equal a larger bore may diminish a particular engine's knock suppression ability; especially with the aready knock-prone VQ35 heads. Simply more area for the flame front to cover (when flame travel speed is a constant). Despite the fact that this could nullify (or partially offset) the drop in compression this setup should probably make more power overall due to raw mechanical advantage, as you said. Just wanted to sprinkle in another angle.
P.S. I wonder if the smaller than spec squish clearance had anything to do with the knock he was experiencing or if it actually helped.
Old Sep 17, 2009 | 11:44 PM
  #119
I would think that it would have helped.. but, who knows..
11.5:1 on today's "93 octane", with healthy timing and a lot of heat, could definitely push an already detonation prone engine over the edge.
Travis
Old Sep 17, 2009 | 11:47 PM
  #120
The car wasn't pinging when it was tuned.. as it was cold outside when we built it. And, the owner couldn't hear it pinging when he ran it this summer. I don't really care to rely on alky/meth injection.. to me, it's just another thing to worry about failing.
But, from the start, we didn't feel that it was necessary.. as the car showed no signs of detonation.
Travis
