Sponsored by:
Sponsored by: CARiD
Return style set-up on 3.5 questions
Old Jun 2, 2009 | 09:27 PM
Product_Of_Korea's Avatar
So I want to cheap out and not run with a afpr. I know that the 4th gen FPR can be hacked to be put on the 3.5 rail. But has anyone tried using the de-k fpr and damper on the 3.5 rail?? Will it bolt right up or will there be some modification needed??
Old Jun 3, 2009 | 05:30 AM
oldngivout's Avatar
Willing to learn
Not sure if you can tell with this picture what I did. I used the A32 FPR mounted to the A34 rail. I had to turn it a little and drill new holes to mount it. There was fortunately enough material to do this. On the delivery side, I made a custom bracket to hold the tube that I scavenged from an A33B set-up. Kinda strange, but it really works well.
http://i188.photobucket.com/albums/z...t/DSC00123.jpg
Old Jun 3, 2009 | 03:30 PM
I kinda understand. So couldnt one just use the damper off the a33b on the delivery side(just keep it intact) and a 4th gen fpr or de-k fpr for the return side??? Pretty much how its setup on the de-k rail but just on the the a33b rail
I guess im just trying to keep the return style setup with little modification
Old Jun 3, 2009 | 08:28 PM
oldngivout's Avatar
Willing to learn
I guess you could. All you need is flow from the fuel pump going into the rail somehow, and the FPR on the other end takes care of the return.
Mar 12, 2020 12:06 AM
Maximan190
Dec 16, 2015 06:01 AM
RWCreative
Sep 21, 2015 11:01 AM
MaxRPM6
Sep 11, 2015 06:56 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
