Sponsored by:
Sponsored by: CARiD
UpRev Cipher question
Old Jun 3, 2009 | 12:28 PM
97Maximus's Avatar
Shift_custom
From my understanding the Cipher program will not work with a 4th gen application? I am interested in logging data, and mainly in adjusting timing for my car. Thanks for your knowledge
Old Jun 3, 2009 | 01:23 PM
VQpwrdSpeC's Avatar
When I asked uprev to see if this would work on my car and they told me it would only work on with the newer style ECU's 04+ w/CAN BUS
Old Jun 4, 2009 | 02:43 PM
pmohr's Avatar
No more Maximas...
Cipher will work just fine with an A33B. Not all of the functions, but all of the data logging, timing advance, idle speed adjustment, etc will work.
Old Jun 4, 2009 | 02:48 PM
pmohr's Avatar
No more Maximas...
No. Cipher connects through the OBD-II port using the CONSULT interface, which is a separate connector for the A32.
You could always contact them to see if they've got a CONSULT connector cable, though.
Old Jun 5, 2009 | 05:18 AM
irax's Avatar
does anyone know WHAT functions do work on the A33B (5.5gen?) vq35de ecu's ?
Old Jun 5, 2009 | 06:13 AM
VQpwrdSpeC's Avatar
Oops you're right I asked them about Osiris not Cipher
Old Jun 14, 2009 | 07:58 PM
NmexMAX's Avatar
dot dot dot ...
Here's what it does for us (A33B).
Data logging / idle speed adjustments / base timing adjustments / fuel schedule reset / ECU reset code retrieval / fuel pressure test / coolant sensor test / cylinder pressure test / fuel injection test / clear learned fuel settings.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
