When in park and rev, car wants to cut out
Last night I had the car in park and started to rev it so a buddy can hear the motor. Didn't rev to high, maybe 2.5-3. As the RPM's dropped, you here like a clicking noise like the car is has no power (sorta like the starter clicking I guess?) then kicks back on to normal. Kinda weird and no idea why this happens? I know this was an issue when I first did the swap but never went back to the issue until yesterday.
Is the breather hose from the valve cover to the intake connected in bewtween the TB & MAF?
Did you get a chance to check the AFR?
If all you have is a small breather filter on the valve cover (VC), then you will run very lean when in P / N and will notice the behavior you described.
I have the stock hosing to the VC as I left that stock airbox by the TB on. I'm just tied up right now with some home reno's. I'll check it out hopefully during the week and figure things out. Hopefully next month I can dedicate more time when the DE-K spacer kit and I get a new muffler put on.
There is a section in the FSM that details the PVC system / process. If you can understand that, then you should be able to understand the concept.
I see you have replied to Jime when he briefly explained it in a thread back in 2007.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
