Sponsored by:
Sponsored by: CARiD
3.5 heads on a 3.0 block?
Old Jul 27, 2009 | 07:14 AM
TDotMax's Avatar
Based on the mods I have, would this be beneficial? Would I have to use a 3.5 intake manifold also?
I looked at the FSM and it seems like a straight fwd swap (exception would be putting in my cams possibly and HR valve train). Heads are going for $100cdn.
Old Jul 27, 2009 | 08:02 AM
DrunkieTheBear's Avatar
Turbo'd Saab
It can be done, and IIRC it has been done
but your compression will drop...ALOT.
My personal opinion...I don't care much for heads that don't line up with the cylinder walls...just seems like a bad idea.
Old Jul 27, 2009 | 08:06 AM
MOHFpro90's Avatar
http://forums.nicoclub.com/zerothread?id=284103
http://forums.maxima.org/all-motor/3...q30-block.html
Drops compression for boost. You will lose power n/a.
hi dave
Old Jul 27, 2009 | 08:18 AM
TDotMax's Avatar
DAMN, another sign I should go FI lol. Just recently had a chance to pick up turbo hardware (minus the snail) for dirt cheap and I passed on it!
Old Jul 27, 2009 | 08:42 AM
nismology's Avatar
3.5 combustion chambers are already ineffiecient as far as knock supression goes. If you factor in the fact that the diameter of the 3.5 c/c's is wider than the 3.0 block you have a detonation-prone combo. I'd do some headwork on the 3.0 heads instead if you're worried about flow or dished pistons if a reduced C/R is what you're after.
Terrible idea IMO.
Old Jul 27, 2009 | 08:05 PM
Turbo'd Saab
Take doublea's porting as an example of the most extreme you should do on 3.0 heads.
Old Jul 28, 2009 | 06:48 AM
Nealoc187's Avatar
SLOW
Or just leave the 3.0 heads stock and boost it since you can make enough power on stock 3.0 heads to break motors and transmissions every day of the week. Put the money into a proper turbo setup and tune instead of throwing money at the motor when it doesn't need it to make more power than likely will ever want anyways.
Old Jul 28, 2009 | 07:35 AM
essential1's Avatar
My axles cry for mercy...
Couldnt have said it better.
Old Jan 27, 2013 | 08:56 PM
roninautotech's Avatar
why can't you do nit like the honda civic mini me engine on the v tech y16z head and the lower hours power block of the 94 civic you can swap if you remove oil regulator from non v tech block to get the need oil to the head to gain compression that also turns the non v tech in to a v tech with a v tech head and adds to sqelch area.
is thare a oil reg in the block to the head of a nisson maxima or in the block to the pan like a toyta?
Old Jan 28, 2013 | 05:45 AM
Unklejoe's Avatar
good talk
Old Feb 24, 2013 | 08:20 PM
Turbo'd Saab
Wut?
Old Feb 25, 2013 | 07:27 AM
ABIGBRAIN's Avatar
This "Honda language" of which you speak sounds more like baby babble.
Old Feb 26, 2013 | 01:11 AM
carsnwomen91's Avatar
?? Every manufacturer of vvt actuates differently. Honda is not nissan... Or toyota lol
Vtec for ****s sake V-FCUKIN-TEC.
Old Feb 27, 2013 | 05:14 PM
asand1's Avatar
And you can run it off of a v-tech standalone
and tune it with a v-tech programmer
Old Feb 27, 2013 | 07:39 PM
nismomaxgtr18's Avatar
^^^lmaoooo
Old Feb 27, 2013 | 08:29 PM
asand1's Avatar
Wut?
Nice Avatar flcl rocks
Old Feb 27, 2013 | 11:43 PM
Rods03Max619's Avatar
Old Mar 9, 2013 | 08:43 AM
Maximeltman's Avatar
too funny im at work and cant stop laughin at that one with the teeth lmao
howardis
Dec 11, 2019 06:10 PM
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
jaydot901
Sep 29, 2015 01:18 PM
wiseguy6199
Sep 29, 2015 05:00 AM
