Sponsored by:
Sponsored by: CARiD
80mm throttle body on eBay
Old Aug 17, 2009 | 08:19 PM
grey99max's Avatar
LandShark has Cosworth
Is this something new?
http://cgi.ebay.com/ebaymotors/UNIVE...Q5fAccessories
Old Aug 17, 2009 | 08:31 PM
Product_Of_Korea's Avatar
I think it would have to be modified a bit to make it work.
Unless you chop off that little peice off and make a cut in the beefer part it might line up...
Old Aug 17, 2009 | 09:26 PM
MOHFpro90's Avatar
Interested in using JUST the housing and plate and seeing how feasible a transfer of the other parts would be... hmmm....
Old Aug 18, 2009 | 07:10 PM
grey99max's Avatar
That's what I was thinking - an 80mm TB... hummmm.... Of course there's always the Q45 90mm TB, if you want BIG.
Old Aug 18, 2009 | 07:22 PM
MOHFpro90's Avatar
Hmm... I wish we just had something that bolted to the 00VI manifold with a larger opening port...
Old Aug 18, 2009 | 07:59 PM
grey99max's Avatar
Lookee - another 80mm TB - in a purdy blue color ! and cheaper... $98 + $14 shipping...
http://cgi.ebay.com/ebaymotors/80MM-...Q5fAccessories
Or a plain one:
Old Aug 18, 2009 | 08:04 PM
MOHFpro90's Avatar
Or a plain one:
I wonder if they would be willing to give us the bolt hole pattern. Haha.
Old Aug 18, 2009 | 09:19 PM
grey99max's Avatar
It can't hurt to ask....
Old Aug 19, 2009 | 02:23 AM
throttlehappy46's Avatar
SR16VE N1 Pulsar 70mm throttle body should bolt straight onto your manifolds and uses a Nissan TPS etc with the same bolt pattern...
Old Aug 19, 2009 | 05:43 AM
NiZMo1o1's Avatar
curse my DBW TB
Old Aug 19, 2009 | 08:34 AM
Nealoc187's Avatar
SLOW
waste-o-money
Old Aug 19, 2009 | 11:37 AM
MOHFpro90's Avatar
Old Aug 19, 2009 | 05:13 PM
Kevlo911's Avatar
Kevlo for President
Bolt on to a 4th gen, 00vi, or VQ35 FWD?
Old Aug 19, 2009 | 07:29 PM
NiZMo1o1's Avatar
A bit hard to find a SR16VE N1 Pulsar 70mm throttle body
ebay http://shop.ebay.com/i.html?_kw=SR16...286.m104.l1198
$680 for Tomei
http://www.rhdjapan.com/jdm-low/Niss...-SR20DET-16760
$610 here
Old Aug 19, 2009 | 07:46 PM
MOHFpro90's Avatar
$680 for Tomei
$610 here
I think I can have one custom machined out of a block of pure silver for that price...
Old Aug 19, 2009 | 08:22 PM
Block of pure copper better?
http://gspec.com/p-5010-vvl-n1-throttle-body.aspx
US$220
Price gouging at its finest for the other two links
TPS is easy to sort out as well
Old Aug 19, 2009 | 09:10 PM
nismology's Avatar
Exactly what I was wondering. lol
Old Aug 27, 2009 | 12:16 AM
Gorden Calogerus's Avatar
A Vision Motorworks 80MM High Flow throttle body for the 1998-2004 Chevrolet LS-1 and GEN III engines with the cable style throttle body. Vision Motorworks went to the best throttle body manufacturer in the world and bought hundreds of these to be able to get this quality piece to you at an incredible price. These throttle bodies are as good or better than anything being made by Edelbrock, BBK, Professional Products etc...
Old Aug 27, 2009 | 06:06 AM
DAVE Sz's Avatar
Hooooooonda.....
wtfrack?
Old Aug 27, 2009 | 06:22 PM
LushMoney's Avatar
could that actually work?
Old Aug 31, 2009 | 02:53 AM
Since I own an LS1 engine, I can confirm that the LS1 throttlebody does not work on the VQ35 or any other Nissan etc. Besides the IACV and TPS signals being wrong, the bolt pattern is definitely wrong.
The VQ35 manifold takes the N1 TB based on a few Japanese guys doing VQ swaps into S13/S14's etc. However, I have an N1 TB floating around which I can measure for confirmation this weekend. It is slightly larger than an SR20 bolt pattern and is the same as the SR20VET flange.
Old Sep 1, 2009 | 10:13 AM
doublea's Avatar
$680 for Tomei
$610 here
It's a steep invoice for a 70mm TB... You can take a stock TB and have it bore to 69-70mm, it only cost 100-150$ - I dont recall how much I paid for but it was done professionally.
Old Sep 2, 2009 | 03:10 AM
See post 16
Old Sep 2, 2009 | 05:33 AM
KRRZ350's Avatar
US$220
Cold start valve FTW.
Old Sep 4, 2009 | 07:36 PM
Shift_Knob's Avatar
now the next question is how big is the hole in the intake behind the TB? putting a 100mm throttle body on an intake with a 60mm hole wont do much good.
yes i know the intake can be bored out and yadda yadda but im just wondering what it is stock? also how big is the stock throttle body?
Old Sep 8, 2009 | 05:39 PM
s1mply_v's Avatar
I honestly think the Pathfinder throttle body is large enough for a N/A DE-K. Its 70 or 75mm IIRC, and boring out the DE-K plastic manifold so flow wont be impeded, was already pushing the structure of the throttle body opening on the manifold.. Imagine 80mm. I dont even think 100mm will bolt on, it'll slip right over it since its so big.
Old Sep 9, 2009 | 04:57 AM
doublea's Avatar
On a DEK intake manifold, the diameter of the bracket between the IM and TB is about 57mm in diameter, now when you remove it and measure the opening of the IM, from top to bottom is about 59mm and from right to left is 56mm ( it's not round but more like an oval ). I see it's possible to bore it and maybe shave 1/4" to 1/2 roughly, that would increase the IM opening to maybe around 65-70 mm.
Old Sep 9, 2009 | 09:15 AM
MOHFpro90's Avatar
Well you also have to take into account the flow around the TB plate itself. In other words, a 70mm TB may only have the efficiency of a 65mm piece of tubing, due to the flow being reduced by the interuption of the TB plate... Sure it not much, but 70mm tb on a 65mm UIM port would be great.
Also, going into a smaller UIM port would speed up the velocity... not sure what the effects would be on the air flow, but yeah...
Old Sep 9, 2009 | 09:19 AM
nismology's Avatar
Velocity matters more at the intake port/IM runner level. As far as the throttle goes, airflow mass is king.
Old Sep 9, 2009 | 02:00 PM
Shift_Knob's Avatar
ok so that snawers my questions for a DE-K intake now what about a VQ30 intake? ho wmuch can the stock intake be opened up?
Old Sep 9, 2009 | 05:46 PM
MOHFpro90's Avatar
I assume you're referring to the DE? Not sure what the stock port is, but I know that it couldn't be opened more than 5 mm on each side safely. The metal isnt that thick.
Old Sep 10, 2009 | 06:04 AM
doublea's Avatar
I have checked my DEK IM yesterday and I found out the the metal bracket between the IM and the TB is smaller than the TB. I'm not to sure what this bracket is for but it is possible to increase the diameter but that would imply some custom work, ie: cutting and welding. The IM boring could only take few minutes to accomplish with air tool. I'm going to modify the bracket to at least have the same diameter as the TB and port match with the IM. I will post some pics tonight to support my explanations.
Old Sep 10, 2009 | 08:28 AM
MOHFpro90's Avatar
AA, most of us simply remove that metal bracket. There have been speculations for its purpose for a while, but I dont remember anyone having any 'proof' of it being useful... so most of us just dont use it.
Old Sep 10, 2009 | 08:49 PM
doublea's Avatar
I took a look at it tonight and I would say that this bracket is mainly for structural purpose, but it also to deflect the air flow a little. I'm going to modify it so it have the same diameter than the TB. I like the idea of keeping the plate between the IM and TB and make sure it's tight and there is no leak.
Old Sep 19, 2009 | 02:07 PM
3000vr4tt's Avatar
would you need an iac block in order to use the stock iac with these bigger t-bodies?
Old Sep 19, 2009 | 02:52 PM
MOHFpro90's Avatar
Depends on what generation you are... 4th gen no, anything with an 00VI, or 5th gen an up, yes. Not sure of the setup on the 3.5.
Old Sep 20, 2009 | 04:13 AM
SR16VE N1 70mm TB will bolt to the maxima VQ35 stock intake manifold BUT you need to enlarge the stock bolt holes in the manifold flange and retap OR use an 8mm drill bit and drill right through the holes and then use a long bolt and a nut on the back.
VQ35 manifold flange is 72mm stock, so a 70mm TB will create a great venturi effect.
Old Sep 20, 2009 | 03:15 PM
MOHFpro90's Avatar
Ugh whats with the 3.5 crap? Wheres the 3.0 support? hahaha. Might see if I can get ahold of one and see how it works with the 00VI...
Old Sep 24, 2009 | 06:30 PM
nismo_star's Avatar
5" D extrusion on 4th gen upper IM and 4th gen lower IM for sidefeed injector swapping.
Q45 flange on the way
http://memimage.cardomain.com/ride_i...0153_large.jpg
http://memimage.cardomain.com/ride_i...0154_large.jpg
http://memimage.cardomain.com/ride_i...0155_large.jpg
sorry no pics of the motor its going on, but you get the point.
Old Sep 24, 2009 | 07:01 PM
MOHFpro90's Avatar
Nice! Is that going to clear the hood though??
