Sponsored by:
Sponsored by: CARiD
Death of a VQ35DE....(semi winded)
Old Aug 28, 2009 | 02:20 PM
MDeezy's Avatar
Originally Posted by MDeezy
1996 Maxima Fed spec
5speed Manual Transmission
2002 Maxima VQ35DE
No engine modifications
No transmission modifications: Amsoil Gear fluid used
Untune... (for now)
No tack times (for now)
No post problems with the swap once everything was worked out.
spec Stage II clutch
VAFCII as the fuel controller
VIAS activation point: 4100 rpms
I believe that thread came around after I was done witht he swap. I believe it was around October 2006 I finished the swap (took 2 weeks due to waiting on parts).
Past couple of days I saw the oil light flickering if my rpms dip lower than 600prm. Checked my oil larter that night (after cool down) Dip stick couldnt even get a reading. The next day bought oil and filled up. Now When I drove I'm leaving a baby cloud behind as I roll thru 1st gear and it stops when I hit 2nd.
At this point when I'm at a light idling (670rpm) I would see the oil light just barely come on and flicker. After a long stretch on the highway then stop at a light, the oil light would be brighter as it flickered at a light, till I blip the throttle then it goes away.
Today: No more baby clouds out of my exhaust as i drive, but after 10 min of driving I get on the high way and I can now hear the bearing in the motor loud, and I had music playing. I decided not to take my 40mile trip to pick up parts and head home to switch cars. Motor then gets very very sluggish, and no power. I get up to 50mph and coast to the next exit. Car partly wants to stall at idle so I blip the throttle. the last 5 mile home the motor is loud, I hear clunking, the motor is more tolerant as long as its above 1k and below 2k, so I drive accordingly. Luckily I just make it home and pull her straight into the garage.
My motor had been making odd noises that led me to believe death might be on hand but that was over a year ago and since had been fine. For the past year I had been babying the motor as my transmission was on its last leg so I barely revved past 3k.
Going to pull the motor tomorrow, I believe the oil pump went/dying. Also I'm sure a bearing is loose or something but I'll tear into it early next week and get pics posted up.
Fortunately I now have a 26k 08 Max motor to drop in so I'll spend the weekend swapping again and hopefully be up and running for monday.
i was still breaking my clutch in
Bought her for $520 shipped about 4 year ago. She's been in 2 maxima, had 3 different transmissions, 3 different clutches, 2 sets of axles, and 2 alternators.
Rest in Peace
Old Aug 28, 2009 | 02:49 PM
Product_Of_Korea's Avatar
man i feel your pain man. I just dropped mine in not to long ago.(maybe 3 months ago)
And she has been knocking for the past week. Luckly i can get 3.5's for fairly cheap
Old Aug 28, 2009 | 02:57 PM
MDeezy's Avatar
Man.... if she's knocking look into it while she's still alive.
It hit me today as I was driving that it might be the oil pump, and I figured we'll I'll pull the timing case and visually inspect it and see if that is the problem. if so then get a rev up pump slap it on and maybe i'd be good to go. I was thinking this as I was driving two turns before she really decided to start giving out...
Old Aug 28, 2009 | 03:15 PM
That would be nice if it was a dying oil pump. At least it wouldn't require to pull the engine.
I think i have a bent rod or spun a bearing or one of the main bearing. Which would require a rebuild either which way. When it happened(i reved to 7k) it started missing then went home and #6 cylinder's plug was pretty smashed up
Err next time around im not extending my rev at all................. or i should of put arp bolts in
Old Sep 12, 2009 | 10:23 PM
93altima's Avatar
Turbo 4th Gen
both of you are 3.5 killers (knock on wood)
Old Sep 12, 2009 | 10:25 PM
MDeezy's Avatar
knock hard my friend... knock hard... Late and about to start my rounds of drinking (more like continue) but new motor is in and feels like a champ!! 26K is a lovely feeling
Old Sep 12, 2009 | 10:49 PM
nvsaccord02's Avatar
dam
Old Sep 12, 2009 | 11:14 PM
Damn you i want a new one
Winter will be coming soon, hopefully i might pick up a 3rd gen for a winter beater
Old Sep 12, 2009 | 11:18 PM
MDeezy's Avatar
I lucked up with mine... I hope others can find a deal like that...
Why? we'll you have snow. I dont I just have cold roads and occasionally rain. Going to keep driving this car till the heat comes back
Old Sep 13, 2009 | 08:52 AM
Eh it isnt that the max is bad in the snow or anything. It would almost be pointless to have a 3.5 swap maxima in the snow
There has been instances where it has snowed on Halloween out here.
Well atleast ill have all winter to buy,Build(probley just some arp bolts)and swap.
I miss my 3.5
Old Sep 13, 2009 | 08:58 AM
NiZMo1o1's Avatar
oh man sorry to hear deez... you might need to keep that motor your buddy is selling man..
that should be a healty motor
Old Sep 13, 2009 | 09:00 AM
MDeezy's Avatar
Thanks man...
I already swapped it in...and I love it!!
Old Sep 13, 2009 | 04:49 PM
NiZMo1o1's Avatar
Thanks man...
Well Damn.... you change your underwear as fast as your motors ? I keed I keed..
good to hear man !
Old Sep 13, 2009 | 05:27 PM
MDeezy's Avatar
good to hear man !
I wish I didnt have to change them that often but feels good to have new underwear on
PH98I30
Jan 9, 2025 08:08 AM
bigdogsteve
Jan 31, 2018 04:18 PM
Pixel
Sep 15, 2015 05:53 AM
16_SR
Sep 9, 2015 07:14 PM
adamgalazka
Aug 31, 2015 05:55 PM
