Sponsored by:
Sponsored by: CARiD
35 swap...no spark
Old Sep 13, 2009 | 09:07 AM
VenoMax647's Avatar
35 swap...no spark
hey guys well it is as stated...it gettin fuel....all my coils are new but its now gettin any spark....anysugestions?
Old Sep 13, 2009 | 10:21 AM
whlimi's Avatar
Check all relevant fuses.
Look up the ignition circuit under P1320 in the EC section of the FSM. Do the diagnostics for voltage and ground.
Old Sep 13, 2009 | 11:44 AM
t6378tp's Avatar
Turbo 3.5
check your connections and harness grounds
Old Sep 13, 2009 | 01:49 PM
Product_Of_Korea's Avatar
check the 2 ground harnesses that use to go to the lower intake manifold.
Old Sep 13, 2009 | 09:21 PM
MDeezy's Avatar
thought those were for the injectors? either way they need to be grounded.
Old Sep 13, 2009 | 11:09 PM
VenoMax647's Avatar
checked all grounds....someone said i should check the crank sensor....and i heard something about modifying the one on the tranny somehow but idk
Old Sep 13, 2009 | 11:12 PM
MDeezy's Avatar
that wouldnt cause no spark. Timing would be off but not no spark.
if you are using the 3.5 oil pan and 3.0 sensor you will need to grind it down 1/4
if your using the 3.5 oil pand an 3.5 sensor you will need to re wire
if your using the 3.0 oil pan and 3.0 sensor, nothing needs to be done.
Old Sep 14, 2009 | 12:48 AM
Gemner's Avatar
make sure the timing ring is not messed up. a dented timing ring will cause there to be no spark.
Old Sep 14, 2009 | 02:17 AM
VenoMax647's Avatar
yea i'm using the3.5 oil pan...but i didnt shave it...how hard is it to re-wire the 3.5 sensor cuz i dont have the 3.0 pan anymore(dont ask)....but as i said ive checked and re checked all grounds anything else?
Old Sep 14, 2009 | 02:21 AM
MDeezy's Avatar
we'll if you have the 3.5 sensor and its harness then its not hard. if you dont have it, then grinding it down and using your old 3.0 sensor might be the best bet....
let me guess you cracked your old oil pan trying to get it off but forgot there was a bolt still in and you Heman'd it and its now in 2 pieces?
Old Sep 14, 2009 | 09:03 AM
VenoMax647's Avatar
exactly what i did lol...but i can go out n but the 3.5 sensor easily....i dont trust myself grinding anything down
Old Sep 14, 2009 | 11:30 AM
MDeezy's Avatar
if you have a 3.0 oil pan for reference you'd see what you need to grind and its not as bad as you'd think. the 3.5 oil pan has a hump....
I think I have both pans in the garage. I'll snap some pics later (after I cook some hashbrowns and pancake )
Old Oct 1, 2009 | 04:16 AM
Augustus Maximus's Avatar
Today is October 1st...but you're prolly still cooking your hashbrowns and pancake, right?
Old Oct 4, 2009 | 06:49 AM
VenoMax647's Avatar
LOL^.....yea i jus ended up grinding it down....but then my bat died.....completely so i'm picking up a new 1 on wed
Old Oct 10, 2009 | 09:09 AM
VenoMax647's Avatar
WE GOT SPARK!!!....now jus to put these axles in n i'm up n running
Old Oct 10, 2009 | 10:59 AM
ajcool2's Avatar
wat was the problem?
Old Oct 10, 2009 | 06:31 PM
i2vicious2's Avatar
SCAMMER DO NOT BUY FROM FOR NOW
crank sensor......... engine and trans.. (didnt grind it down)
Old Oct 10, 2009 | 06:51 PM
VenoMax647's Avatar
yep...now just to figure out this egr from the rear header....maybe plug?....does the front header fit the rear?
Old Oct 10, 2009 | 08:27 PM
pmohr's Avatar
No more Maximas...
http://www.courtesyparts.com/14003k-...3-p-53839.html
Old Oct 12, 2009 | 01:48 AM
ajcool2's Avatar
I have an extra one sitting in front of me if you want it let me know.
Old Oct 12, 2009 | 05:28 PM
VenoMax647's Avatar
he!! yes.... r u comin down wed to curtis shop...if not fri at mcdonalds...i'll buy, trade, take for free it's watev
Old Oct 13, 2009 | 07:54 AM
ajcool2's Avatar
I'll probably be down at the mcdonalds on friday I'll bring it with me.
Old Oct 13, 2009 | 07:32 PM
VenoMax647's Avatar
SWEET.....
Need help
23
Oct 2, 2015 08:56 AM
Gingerheadman
Oct 1, 2015 05:11 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
